Question about Cameras
Manual for rbhc-17j14shd
Manual
RBHC 17J14SFD not blowing any air
Phillip: According to FamilyHandyman.com: "free up the condenser fan. Coils on the back of a fridge create their own airflow as they heat up. Models with coils underneath have a fan to push air through them. Dust buildup can slow the fan; wads of paper or other trash can stop it altogether."
May 21, 2015 | Refrigerators
Rheem heat pump
Model number of the inside unit is required
Jul 02, 2013 | Water Heaters
RBHC 21J211. No heating (electrical). What to check?
Check Heating sensor/Heating element for closed circuit.Keep temp 30 degree with mode in "Heat"
Dec 16, 2010 | Heating & Cooling
I need to replace my out side heat pump my air handler is steel good it is a rheem rbhc 14j11sfd what do i need
they like the name brands to match but it dosnt matter.you need to get the model and serial#s off the coil to find out what ton it is and just get the same size out side unit.
Sep 24, 2010 | Heating & Cooling
Ineed to now how many ton is a rheem model number rbhc-14jo7nfd air handle
Hello, that unit is 800cfm on High speed. One ton of cooling requires 400 cfm. Thus your unit is a 2 ton capable air handler.
May 19, 2010 | Heating & Cooling
Rheem RBHC-17J14SFA elec furnace fan won't stop
sonds like u have a bad safety switch they r round and have 2 wires on them usually and u can check them by taking the wires off of them and checking continuity thru them there might be one on the blower housing also either that or ur blower relay may be bad and stuck closed
Feb 18, 2010 | Heating & Cooling
WHY DOES MY RHEEM RBHC-14J11SFD BLOW ONLY COLD AIR? THE AIRCONDITIONER WORKS, HOWEVER THE HEAT DOES NOT TURN ON. THE THERMOSTAT IS SET TO ON AND TO THE HEAT POSITION.
Heat pumps tend to blow a much lower temperature outlet air than a gas fired unit would. Is this your first year with this furnace?  Depending on your outside temps, an auxiliary heat strip may not be operating properly.
Jan 05, 2010 | Heating & Cooling
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
