Question about HP AU165AA Webcam
How to fix camera - HP AU165AA Webcam
  • HP Master
  • 27,725 Answers
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer Hope this helps.
Posted on Dec 30, 2012
Camera says lens error, restart camera...
Hi, On Canon camera's that error is typically seen when the camera's been dropped and the lens is now out of place. For the A490 specifically that's something that can't be fixed as it's such an inexpensive camera and fixing that problem, if it can even be fixed, costs upwards of $300.
Aug 29, 2011 | Canon PowerShot A490 Digital Camera
How do I reset my canon powershot camera, I am get the message Lens error, reset camera
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Jan 30, 2011 | Canon PowerShot SX100 IS Digital Camera
Turn camera on lens error comes up 0xo41100000 how can i fix this?
lens error is not so easy to fix. this error comes if you have make a pressure on the camera lens..or the camera have becom a knock or is falling down.. this problem can you solve with the lens changement. this fixing is for professional fixer. if you was in italy i can fix you this problem with 50 euro but in uk i dont now what is the cost for change the lens of your camera... i am sorry that i can t help you better..but if you dont have knowledge for camera fixing, is impossible that you can fix it alone
Oct 10, 2010 | Pentax Optio E60 Digital Camera
Lens error, reset camera, how do i fix?
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 20, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Camera sees upside down.
Do you remove the camera when u fix the camera? if not, most properly is the camera's software itself need to be adjust.
Jul 31, 2009 | Lenovo IdeaPad Y510 Notebook
Lens error 20e,1,0,0
Apr 24, 2009 | Kodak Easyshare C813 Digital Camera
Lens error, restart your camera
I've had similar problems with various versions of this camera. Here's the fix, if all else fails. These are step-by-step instructions to take apart and fix the camera's lens error. http://johnsmouth.wordpress.com/2010/12/01/lens-error/
Jan 20, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lens error message
Dec 28, 2008 | Canon PowerShot A560 Digital Camera
Lens Error
Dec 24, 2008 | Nikon Coolpix S210 Digital Camera
How do you fix 'lens error restart camera'
Dec 02, 2007 | Canon PowerShot 600 Digital Camera
HP AU165AA Webcam Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
