Question about Poulan Garden
Poulan 3400 needle valve adjustment (chainsaw)
Have rebuilt the carb, but kit did not have gauge for adjusting the metal
flap, w/spring under it and going to the needle valve. The rebuild kit is
from Poulan for this carb. No instructions for adjusting the flap. Saw
will not start. Fuel and spark showing. New fuel hose and filter. Believe this is the problem.
  • David Ford
    David Ford May 11, 2010
    generally this flap is already preset. I have never seen a guage to adjust. Do you have another spark plug that you can try? I would also check the settings on the high/low screws on carb. I believe the initial adjustment is around 1 turn out after gently seating.
I do not have a ring tool so I made me one. take a rad. hose
clamp and a beer can or coke can cut about a 4in long strip and
1 1/2 wide. glue one end on the inside of the clamp leave the
rest of the strip loose. Place over the rings and piston and
tighten but not to tight and bump the cylinder on the piston.
It does work. I do it on all the saws I work on.
Posted on Aug 20, 2014
3 Suggested Answers
  • 4088 Answers
SOURCE: poulan saw wont run
Clean the muffler spark arrestor screen and check the cylinder port for carbon build-up at the upper edge. Try presetting both carburetor H and L adjustments (from lightly CW stops) 1-1/2 turns CCW each. Start the engine and allow to warm up. Pull the throttle wide open and adjust H CW until the engine speed increases, but still 4-stroking. Correct setting is when the engine 4-strokes, but immediately 2-strokes when cutting. Allow to idle and adjust L for smoother running, yet allows the engine to 'follow the throttle'. Set idle speed to keep the engine running, but doesn't try to move the chain. You may have to look closer at your carburetor if the above doesn't help. Go to:
for an excellent article (but poor pix) on Walbro carburetors, but related to most all 2-stroke carburetors. Hope this helps!
Posted on Feb 24, 2010
  • 743 Answers
SOURCE: poulan 2600 chainsaw. the saw starts ok but then
If the carburetor has been rebuilt that leads me to believe that there was an adjustment made. The problems that can be encountered is that we like to adjust the carburetor to reach maximum performance. However, this ends up blowing the engine since there is a prescribed RPM for each saw, which is probably around 7k rpms. Now, we don't have enough vacuum to draw the fuel. There is another important area to check though before rebuilding the motor, and that is the adapter, or gourmet, that goes to the engine from the carb. Inspect it for can do that by taking it off and turning it inside out to see if you have any holes or simply looking to see if it is dry rotted. If you have a hole, you can get the Black Sealant RTV at Advance Auto and fix it since no company no longer supplies that part for the Poulan Chain saw. If the motor is blown, you can rebuilt it rather simply, but unless you had a good ring tool to put the ring in the cylinder, you will want to place the piston/ring in the cylinder prior to putting the wrist pin and snap ring on wrist pin to avoid breaking the ring. You will need a good vice to hold the chainsaw in place though. This can be done by leaving the piston out far enough to get the wrist pin in with one snap ring on the one side then place bearing in then slide wrist pin in, then be careful no to pull the cylinder head off too far and now place the last snap ring in...of course you will need some sealant on the head gasket first prior to all of this. The reason I am telling you all of this is because on a chain saw, you must be willing to go the whole way since one problem leads to another and the truth of the matter is that if you are willing to go the whole distance, you can get that saw back running perfect...make sure mixture is good even if you need to make up a new mix... Good luck.
Posted on Oct 03, 2012
Why 2-Cycle engine poulan chainsaw will not idle
It sounds like you have an air leak from carb to carb adapter.
Jul 24, 2014 | Poulan 2050 2055 2975 2150 2155 2175 Air...
Adjusting needle valve on poulan chainsaw?
needle valve has no adjustment but there is an air fuel adjustment the two screws on the carb i always go all the way in the 3 full turns out the half turn adjustments until its right..
Jul 17, 2014 | Poulan Garden
Do I have to remove carb. on mac pro 10 chainsaw to clean needle valve
I have not seen a chain saw that must have the carb removed to remove the needle valves. The needles are nomally exposed so they can be adjusted while the saw is running. There are 2 of them.before you take them out turn them gently in till they stop counting the turns.. then pull them out and spray some carb cleaner on them and into the hole they came out at a time because the tip of the needles may be differnt. then gently turn them all the way back in and turn them out the number of turns you counted.
Sep 23, 2013 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Macculloch mac 436 carb setting wont idile
Get rid of all the old fuel Start afresh
Strip out the carb noting which needle screw is which
Make a slot in the screw head for a screwdriver adj. with a fine toothed hacksaw
Lay the carb parts on a white cloth removing the fuel needle and watch the spring, do not drop , it,ll bounce to some dark place
Blow the orifices with compressed air, reassemble Fit the fule valve needle and then slide the spring onto a fine scewdriver and offer it under the flap
Screw both screws in til they seat--not hard, back off 1 and one quarter turns
Now refit the carb, its a mission unlike a Husky or stihl
It should fire now with full choke
If it runs and does not accelerate --flat spot, then slowly ease the Lo screw out until it accelerates freely
If it still will not, fit a carb kit
Nov 24, 2011 | McCulloch Garden
Poulan WT usually starts Ok but after it is used for 8-10 minutes it cuts out when when trigger is released. Happens mostly when you're cutting & then release trigger when cut is done.
If the carb hasn't been rebuilt in a few years, often the fuel pump diaphram gets weak or the little flap check valves get deteriorated. Carb kits are about $20.
Feb 11, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
When i pull the cord to start it gas is spraying out the exhaust. What is the problem
The problem is the needle valve inside the carb is stuck open causing fuel to fill the cylinder. This why gas is coming out of the muffler. You have to rebuild the carb but you have to determine if you have a walboro or zama style carb in order to get the right rebuild kit. make sure you get the full rebuild kit that comes with a new needle valve and adjust the needle valve so that its flush with the slot that it fits in. Also remove the spark plug and pull the starter until all the fuel is out of the cylinder.
Dec 07, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Saw won't run at full throttle. Can't find toolto
sorry theres no adjustment on most of the 2&4 cycle engines especially if its a california carb you can try to clean or rebuild the carb or buy a new one
Apr 02, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulin p3314 gas runs out carb
Set the H and L jet screws CW to stops (lightly), then CCW 1-3/4 turns each. This is a basic setting and both need to be turned CW somewhat when the engine runs. Recheck the lower chamber in the carburetor for correct installation of the needle, seat, spring, fulcrum, and diaphragm. Go to: for a detailed look at Walbro brand carburetors. Even if you do not have a Walbro carburetor, the principles are much the same. Make sure the fuel tank vent is open.
Mar 27, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
High & low carb needle settings
I would start with both the "H" and "L" needle valves at 1.5 turns CCW from lightly seated then adjust for performance as follows:
Carburetor Adjustment by
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Mar 16, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
There shouldn't be an adjustment to it. It is held in place with a pin & small piece of metal. The tiny spring goes under the small piece of metal and it hooks to the needle valve.
Jun 09, 2009 | Homelite Garden
Garden Logo
721 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
