Question about Kitchen Appliances - Others
We have a HOBART HFD50 Fryer 208V 3 phase. The inoperative unit has power to it but when turned on and as soon as the power is sent to the heating coils the unit completely shuts off? No errors indicated?
    Problem Solver:
  • 19 Answers
You have a short or other malfunction in the electrical/electronics/computer system and the system is shutting down on safety systems.
Posted on Feb 05, 2009
  • Stephen Kish Feb 05, 2009
    one further thought, CHECK BETWEEN ALL 3 LEGS, power to ensure 208V, line 1/2, line 1/3, line 2/1, line 2/3, line 3/1, line 3/2. A blown fuse on one leg might very well be your problem!
    A quick way to test the fuses, take one side of your voltmeter and connect it to the metal case. Set the meter to a range capable or reading 208 volts. Your 208 volts might also read 220 volts, or your 220 volts might read 208 volts. Checking from the fuse in to ground should give you between 100 to 120 volts. Check both sides of the fuse hot line to the ground. If you find any fuse/breaker, or wiring connection that doesn't continue to read the 110/120 voltage, that line is open or not carrying power!
I have Hobart D300 mixer which operates at 220V, 3phase supply and whereas the facility has 208V, single phase supply. Is there any recommended phase converters available for this product. Thanks
Hi Bill
I may be wrong here......
But I've been around Electricity for a long time.
Have Never seen a device that does phase conversion.
A Building site or home will either have Three Phase or Single Phase Power Available
BUT...A portable (Hired) generator could be "three phase" and you could use any one of those phases individually or all three phases.
I have 3 Phase supply to my house!
But I use 230 volt Single Phase for appliances.
My Bore Pump uses a 3 Phase Motor,
(so with a voltmeter it would read about 440 vAC to the pump motor).
Some Further Info:
A GENERATOR is basically a motor used the opposite way. Rotate a motor and it Generates.
The Phases refer to the THREE Windings in the supplying generator in your suburb.
A Large Magnet passes each winding in sequence giving you the three ripples in the supply.
Our houses can choose to have 1 Phase or Three Phases from the street when you set up your electric supply.
So... to confirm, look at the wires on the supply poles to the premises. Usually three in our area (Oz)
Most people are not aware that a car Alternator is actually three phase. The Rotor is the magnet that rotates.
The only difference with an Alternator is that each "Phase" is connected to 2 Diodes (6 total) to convert the three phase to DC to charge the vehicle.
The Regulator controls the voltage to the Rotor, thereby controlling the output.
So.... An Alternator could in theory supply 3 Phase in a mobile generator. Custom Made. Constant speed would determine the frequency of 50Hz or 60Hz.
Not sure what country you are in
Hope this Helps or gives you food for thought!
Three phase electric power
Jul 08, 2015 | Hobart Food Mixers
Looking for wiring diagram hr7 rotisserie
need tech(trouble shooting) manual HR7 and wiring diagram
any help?
Sep 04, 2012 | Hobart Hr7 Double Rotisserie Oven 208v 1...
Taking my P660 out out a building with 3 phase power and into one with only single phase. Converter says motor will run on 2/3 power. Good or bad idea????
Good!
MOTOR:
21?2 H.P., Hobart designed, high torque ball bearing,
ventilated within mixer enclosure. Single-phase is
capacitor-start, induction-run type.
Three-phase is
polyphase squirrel cage, induction-run type.
Single Phase 208V 20.0 Amps
240V 17.0 Amps
Three Phase 208-240V 8.6 Amps
Nov 26, 2010 | Hobart P660 Stand Mixer
Ok we have a fry master natural gas fryer serial number 0401LP0001 model number BIH252CSD and we are trying to figure out if it has to be hooked up to a 220 plug or if we can use a 110?
look on the back of the fryer for an info sticker/plate that lists the specs for the unit...you'll see the voltage and phasing required for it...as an example, the picture below shows a 208V 3 phase unit...in general, i think 110V full size fryers would be rare if they exist at all...
Oct 16, 2010 | Microwave Ovens
HOBART FRYER CK20
Most likely solution is to replace the reset. If the new reset trips, check the amperage on the elements. At 208V all three phases should be around 47A, 480V around 20A each. Check all wiring connectors for good connections and no evidence of corrosion or overheating.
Feb 25, 2010 | Hobart 1HF50D Deep Fryer
How to install a 208v outlet for a stove
if its a single phase panel you will only have 120/240 v.a.c. you can wire it for 240 volts and it will heat faster anyway the only way you could have 208 volts would be if you had 3 phase delta or open delta 3 phase or buy a special "dry-type" transformer for 240 volt to 208 volt step-down,otherwise it will be red-& black will be your 2 hot phases of 120 volts each/white-neutral/and green or green-yellow will be the case safety ground
Nov 14, 2009 | General Electric Profile PP945 30 in....
Change 208v heating elements to 240v.
If your supplying 240 vac to a 208 vac element it will work but shorten the life of it.Goto 3wire.com and register,they should have a 208vac element.The wild leg could also be an issue but if you get a 208 vac element it shouldnt hurt it that much.Why you would be getting a reading of 240 vac on l1-l2-l1-l3-l2-l3 is strange.Let me know.
Mar 25, 2009 | Cecilware EFS-40 Deep Fryer
Frymaster fryer mj45eusd
If this is an electric fryer you may have a shorted element that will continue to heat when ever the fryer is turned on,even when it is not calling for heat. If it has 3 phase power, the elements could be wired wrong
Sep 08, 2008 | Frymaster Dean Kitchen Appliances - Others
Kitchen Appliances - Others Logo
109 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
