Question about Maytag Epic Z and Performance Series 2000 Washer / Dryer
Epic Z sounds like a jet airliner with no error messages.
I have an Epic z, we purchased it in 12/09 in 2/10 it had to be replaced because of constant error messages. So in September of this year after we returned from a two week vacation the washer now has turned into a jet airliner...I kid you not when it goes into the spin cycle my whole house sounds like we are on take off. I have contacted Maytag which was a waste of my time. There is only 2 of us and we don't do that much laundry. We do not get any error message. Any help would be appreciated...
  • 409 Answers
SOURCE: maytag epic
hi there,
the FH error means it's either you have a drain problem if there is water in it or if if there is now water in it, make sure that both water inlets are turned all the way up. check to make sure that you don't have any water leaks anywhere visible.
Posted on Oct 03, 2008
  • 79 Answers
SOURCE: MAYTAG MAH6500AWW-WASHER WILL NOT AGITATE/SPIN
Check out the motor control board near the floor on the right side. These have a high failure rate on the Neptunes. Maytag redesigned both the motor and motor control board to be more reliable. While inspecting this board, you are looking for a blown 10 amp fuse and /or burnt components. If you have either... then you will need the the new 12002039 motor conversion kit which includes the motor, motor control board and the wire harness.
See http://www.neptunehelp.com/index_files/Page667.htm.
This kit takes about an hour to install.
Don't forget to replace your door latch wax motor. See www.neptunehelpsong.com to hear a funny song explaining the faulty door latch failure.
Posted on Feb 08, 2009
sivaranjini
  • 241 Answers
SOURCE: Maytag Epic giving F11 error code!
ths.gardenweb.com/forums/load/.../msg1012004912002.html
Posted on Jun 22, 2009
  • 12 Answers
SOURCE: Maytag Epic-Z F-28 error code
F28 is a misc error,
most of the time it is because the washer is NOT LEVEL.
1. Unplug waher,
2. Relevel washer. (make sure all legs are equally distributing weight, so as to ensure no shaking). See owner's manual.
3. Plug in, and use.
Hope this helps.
Jay
Posted on Oct 04, 2009
  • 274 Answers
SOURCE: Maytag washer (model PAVT244AWW). Won't spin.
Its the clutch ,And it sounds like it time for a new washer,the clutch is expensive and washer are cheap try a second hand store that sale scratched or almost new machines
Posted on Jul 05, 2010
Testimonial: "Response was helpful to figure out our options!"
What do we do? We get an error on our Leveler. "Retract Timeout" Return to Leveler for service on our Windsport 34E
Take it in to the service department where you purchased it. Sounds like you have picked up on of those stow away hitch hikers that hide out in the retractables, like those airliners have had happen. Just a little humor. Take it to the service department...just like the message says....sort of.
Mar 01, 2015 | Thor Motor Coach 2013 Windsport 34E
Video camera problems - Sony Video Camera problem
Error code 94:01 is an internal memory error. If you still get the error after reformatting the card or trying a different one, it's an electronic issue usually used by component failure and requires replacement of a circuit board within the camera.
Jul 12, 2014 | Cameras
Fatboy 1991
did you blow through the jets with airline and look through them ? sounds like low range jet is blocked , mixture screw turned out 1.5 turns to sart with and + or - turns when running and blip throttle for responce , does the carb have an extra spit jet that gives extra fuel just as you start to throttle up ? you can see this if youve got the airfilter off ! P...
Dec 06, 2013 | Harley Davidson FLSTF Fat boy Motorcycles
How to unblock rear window wiper water pipe on I10
Firstly have someone operate the rear washer while you listen for motor operation at the front wheel well of the car (same side as the washer fluid reservoir).
If you can't hear the motor, then the motor is likely faulty and requires replacement.
You can operate the front washers to locate where both motors are. (under the car, beside the wheel well.)
If the motor is working but no water is coming out, then remove the rear washer jet and disconnect, then using a high pressure airline, blow backwards into the jet to clear out any blockage. If you don't have a high pressure airline with nozzle, then use something like the nylon filament from a yard brush to poke into the jet, to try and clear the blockage.
Nov 05, 2012 | Cars & Trucks
Driver side windsheld washer not spraying
Check the pipe feed under the hood for any kinks in the line.
Remove the pipe feed carefully and using a high pressure airline, blow back in the reverse direction of the water, back down the washer jet. This fine washer jet is prone to becoming blocked. If you don't have a high pressure airline, then you will need something very fine and flexible, yet stiff enough that when you insert it down the washer jet holes, it can disturb any blockage down there. Although I haven't tried one, you might use a yard brush nylon brush filament.
Nov 04, 2012 | Cars & Trucks
Maytag Epic Z error code
I need a clear code for maytag epic z front load washer
code f-o1 is coming up
says intall new ccu, I did but still the same
do I need to clear the code if so how.
please tell me.
Jun 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic Z and Performance Series 2000 Washer / Dryer Logo
20 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
