Question about Toshiba Satellite 2400-S251 Notebook
Open an bios password - Toshiba Satellite 2400-S251 Notebook
  • Toshiba Master
  • 27,725 Answers
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. select safe mode with command prompt Then type at the C:\> prompt: type
DEBUG
and hit Enter. You'll see a dash (-) at the DEBUG prompt. Now type:
o 70 2e
which will show as -o 70 2e at the DEBUG prompt. Hit Enter. Then type:
o 71 ff
and hit Enter. Finally type:
Quit
and hit Enter one last time to quit DEBUG back to the C:\> prompt.
Now you're ready to reboot your PC, and press the appropriate key or key
combo (look it up in your motherboard manual if you don't know it) to access
your BIOS Setup. Youll notice the password is gone. If this fails try typing At command prompt type debug
you will get a - prompt where you can type the following (<enter> means press enter, not type enter*)
A <ENTER>
MOV AX,0 <ENTER>
MOV AX,CX <ENTER>
OUT 70,AL <ENTER>
MOV AX,0 <ENTER>
OUT 71,AL <ENTER>
INC CX <ENTER>
CMP CX,100 <ENTER>
JB 103 <ENTER>
INT 20 <ENTER>
<ENTER> just hit enter on this line
G <ENTER>
Q <ENTER>
Basic BIOS password - works 9.9 times out of ten
If this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password http://www.tech-faq.com/reset-bios-password.html At some stage you might need to press Ctrl+Enter rather than just Enter if on a Dell Latitude E5410 http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. Hope this helps.
Posted on Dec 30, 2012
DG31PR backdoor bios password
You can't. you need to read your manual, locate the cmos reset jumper, and open the case. There is no such thing as bios reset software as it's at the hardware level that bios operates.
May 11, 2012 | Intel DG31PR Motherboard
I have lost the bios password... any body help me to recover without opening case
This is a tricky one because the BIOS password is made to be the hardest password on a computer to break. Some manufacturers allow you to enter BIOS without the BIOS password but most do not. Here are some troubleshooting methods starting with the easiest and moving on to the hardest.
To enter BIOS hit the F2 key repeatedly as the computer boots up. You should enter BIOS after the first loading screen. If this does not send you into BIOS, try the ESC, DEL, and F1 keys. Once in BIOS find where you can set the password and reset it or enter a blank password as your new password.
If you can't access BIOS or are prompted for a password once you enter BIOS, try the following methods to flush the BIOS password cache:
1. Contact your manufacturer's support and ask if they have a backdoor BIOS password that they will allow you to use. This works to allow you to enter that password instead of your own and easily fixes the whole problem, but not all companies will tell you their password. You can also do a google search for your manufacturer's backdoor BIOS password since many of them have been discovered.
2. Send your laptop to your manufacturer to have them reset the password manually, although this takes an undisclosed amount of time and they will often make you pay a fee if you are not under warranty.
3. If you don't want to pay your manufacturer, open your laptop and locate the motherboard. On the motherboard there is a CMOS battery, if you don't know where this is use your PC manual. Remove the CMOS battery for an hour and then place it back on the motherboard. This should reset the password. After this turn on your computer and enter BIOS. This will reset all your BIOS settings so it may take a few minutes to open. After it is open, just exit BIOS and everything should be working properly. Just be very careful when opening the laptop and handling the CMOS battery because you can severely damage your laptop if you don't handle it properly.
Thanks for using FixYa and good luck!
May 23, 2011 | Computers & Internet
1.how to reset bios password ? without opening cabinet? 2.where can i get the user manual ?
1. Without opening the cabinet, you can start the computer, and enter the current password.
Then, you can change the password.
2. From the manufacturer's web-site: http://www.acer.ca/acer/service.do
Select Driver Download
Select Server
Select Altos
Select G700
Select "User Manual Acer User Manual 1.0 14.8 MB 2009/01/16"
Jun 15, 2010 | Acer Altos G700 Server
Acer aspire 2920 bios password removing
The password to by-pass bios password are these, hope they will hope you, once you enter BIOS using these passwords you can reset it to normal
Phoenix Backdoor BIOS Passwords:
  • BIOS
  • CMOS
  • phoenix
  • PHOENIX
Mar 18, 2010 | Acer Aspire 4720 Notebook
How to reset bios password for xps m1210 dell laptop?
what kind of Bios are you running? Here are some that might help. AMI Backdoor BIOS Passwords Reported AMI backdoor BIOS passwords include A.M.I., AAAMMMIII, AMI?SW , AMI_SW, BIOS, CONDO, HEWITT RAND, LKWPETER, MI, and PASSWORD.
Award Backdoor BIOS Passwords One reported Award backdoor BIOS password is eight spaces. Other reported Award backdoor BIOS passwords include 01322222, 589589, 589721, 595595, 598598 , ALFAROME, ALLY, ALLy, aLLY, aLLy, aPAf, award, AWARD PW, AWARD SW, AWARD?SW, AWARD_PW, AWARD_SW, AWKWARD, awkward, BIOSTAR, CONCAT, CONDO, Condo, condo, d8on, djonet, HLT, J256, J262, j262, j322, j332, J64, KDD, LKWPETER, Lkwpeter, PINT, pint, SER, SKY_FOX, SYXZ, syxz, TTPTHA, ZAAAADA, ZAAADA, ZBAAACA, and ZJAAADC.
Phoenix Backdoor BIOS Passwords Reported Phoenix BIOS backdoor passwords include BIOS, CMOS, phoenix, and PHOENIX.
Backdoor BIOS Passwords from Other Manufacturers Reported BIOS backdoor passwords for other manufacturers include:
Manufacturer BIOS Password VOBIS & IBM merlin Dell Dell Biostar Biostar Compaq Compaq Enox xo11nE Epox central Freetech Posterie IWill iwill Jetway spooml Packard Bell bell9 QDI QDI Siemens SKY_FOX SOYO SY_MB TMC BIGO Toshiba Toshiba Remember that what you see listed may not be the actual backdoor BIOS password, this BIOS password may simply have the same checksum as the real backdoor BIOS password. For Award BIOS, this checksum is stored at F000:EC60.
Oct 31, 2009 | Dell XPS M1210 Notebook
My toshiba equium just wont except the main password, cant reboot..cant get into bios
At this time you need to cleat the BIOS password first so that you can get into BIOS. To cleat the BIOS password you need to open your laptop you just remove the battery first. Remove the screw and open the back cover. Locate the CMOS battery, all password are stored in CMOS memory.
Remove the CMOS battery to clear the stored BIOS password, Or you can remove also the CMOS jamper near the CMOS battery and turn on the unit with in 10 second and turn off. Reinsert the jamper. Now the BIOS password are already clear you can get now in BIOS to change some settings. Good luck
Oct 08, 2009 | Computers & Internet
I know bios password but i want to remove it without removing the battery
log in bios and set bios password again hitting enter
this will reset your current password
Jul 09, 2009 | Acer Computers & Internet
I NEED A PASSWORD TO OPEN MY DELL SYSTEM LAPTOP
You need to find a BISO/CMOS password reset tool, try googing them.
Apr 27, 2009 | Dell Latitude D600 Notebook
Toshiba Satellite 2400-S251 Notebook Logo
73 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
