Question about LG FLATRON W2353V 23 inch LCD Monitor
How do i get my w2353v screen out of cinema mode
Screen is in Cinema Mode, everything is blurry.
  • 230 Answers
SOURCE: Have a home cinema HDD/DVD recorder receiver
Try and go into the hdd/dvd setup menu and change the audio output from digital to analog or vice versa.
Posted on Aug 18, 2009
  • 4090 Answers
SOURCE: Audio keeps reverting to "cinema"
try unplugging unit for several hours ( overnight) this is a hard reset, then when its repluged it should revert to standard mode.
thanks for using fixya
Posted on Nov 25, 2009
panchal643Ja
  • 243 Answers
SOURCE: I hvea 42 plasma tv. I have bought a cinema
Please checked Sound System with your remote menu it should be B/G,D/K,I,M which is not proper.
Posted on Feb 17, 2010
SOURCE: I have a home cinema system LG HT503 - the pciture
Lee algunos DVD y otros no, sobretodo no lee originales
Posted on Aug 18, 2010
  • 85 Answers
SOURCE: I have an LG TV
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Posted on Jan 07, 2011
DVD leaves 1/2 border on left side of screen in wide mode. what is Cinema aspect ratio for? Distorts Adjustment?
you have to adjust with the dvd players settings.
google your make and model #, manual and manual should show.
press the helpful button and follow me on fixya for more tips
Feb 01, 2016 | Proscan Televison & Video
I'm trying to set up my Panasonic smart viera as650 the picture quality isn't as good as it should be its fuzy around the edges of words and when footballs on things that move fast seem to have a slur to...
Check the anti-judder settings and also the viewing mode (Cinema, Sports, Game?) and refresh rate in the TV setup options. Depending on the source input and resolution, the anti-judder settings can actually make screen motions worse and blurry.
Feb 12, 2015 | Panasonic Televison & Video
My epson projector center is blurry
Hello, if it's mounted you may have never adjusted the "focus" on it before. Just slowly turn the end grey colored lens one way or the other with a stationary picture such as the menu on the screen, adjust it to where the lettering is the sharpest.....tks
Nov 09, 2013 | Epson Powerlite Home Cinema 8100 Home...
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
Screen is blurry
Check all the Settings to make sure everything is all Set. Use the Camera in another Mode, if Possible and check, if that could improve the Situation.
If not, Sounds like a Problem with CCD.You need t contact Polaroid, if the are offering any Free Replacement as most of the Other Brands Does.
http://www.imaging-resource.com/badccds.html
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 25, 2009 | Polaroid T831 Digital Camera
Blurry Display Screen and 2 beeps with shutting Off
check the mode that the camera is in try to put it in auto mode, if its in other mode like fast motion etc it can cause this blurry pictures
Jul 13, 2009 | Samsung S860 Digital Camera
RCA 52inch Big Screen.
On your remote push "Info" then push right or left to get OFF zoom mode, Cinema view looks pretty good.
Jul 20, 2008 | RCA HD52W56 52" Rear Projection HDTV
Widescreen cinema mode
Make sure the DVD player is set to 16:9 screen mode.
If you still get the bars at the top & bottom, then its probably because the DVD was filmed in true cinema widescreen, (21.7:9) whereas the TV is only 16:9.
There may be other settings on the DVD player to expnad the picture out, but you will either lose the edges of the picture, or it will be stretched.
Apr 03, 2008 | Televison & Video
Image/screen shifting with mouse position
I realized my issue was that the screen was "slightly" zoomed in using the universal access panel in the system preferences. Turning it off, or zooming out completely solved the problem.
Feb 21, 2008 | Apple Cinema Display 23" HD Monitor
Lcd screen is blurry!!
http://www.imaging-resource.com/NEWS/1164376280.html
Nov 30, 2007 | Canon PowerShot A85 Digital Camera
LG FLATRON W2353V 23 inch LCD Monitor Logo
35 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
