In samsung la32b450.. power suply is ok .but inverter is not worked.main pcb is also ok ..what parts will be changed in i.p. pcp .or any other idea for repear the ip pcb
  • 8,617 Answers
Replace the inverter board.
Posted on Dec 30, 2012
mgomolinski
  • 4 Answers
SOURCE: will not turn on or off
I had the same problem. I work for a mother board manufacturer w/offices in New Jersey and brought mine into our engineering lab after Samsung told me tough luck. Anyway, one of my engineers fixed it in 10 minutes. Essentially, he replaced the 1000uF capacitors on the power supply board with 2 cent capacitors instead of the 1 cent capacitors that had blown out on the CHEAP SAMSUNG POWER SUPPLY BOARD. You can tell the caps are blown via visual inspection. The top of the cap should be perfectly flat and a blown cap will be convex on top. Unfortunately, there are also 2500 uF caps by the same cheap manufacturer on the board as well and we don\'t stock that value for our products. According to my engineer, those will most likely blow next since he replaced the others with better caps, but I\'m getting samples of those and will replace them shortly. After that this piece of junk should last me at least another 2 yrs! It\'s been working for about a week now w/no problems. Hope this helps.
Posted on Dec 24, 2008
  • 50 Answers
SOURCE: My Samsung (LA32B350)32'LCD TV worked for only 30
check remote control battery.
Posted on Aug 12, 2009
  • 1779 Answers
SOURCE: Samsung HD 42inch TV Model No. PS42S5H Y Board
Your board numbers should start with LJ92. They will cross to both Samsung and LG. Oh, your model number goes nowhere, double check it.
Posted on Aug 25, 2009
budmrtn
  • 11361 Answers
SOURCE: Samsung LN-T4665F when powered on
You more likely to need to backlight inverter boards, thpower supply should have 24vdc for the backlight inverter board, the 24vdc power supply get the trun on command from the controller board, that is what should have been checked first. So look for 24v or measure it directly on the inverter board connector pin. The invereter board also has a couple surface mounted fusesYou can get the inverter board here but make sure to match the number: http://www.shopjimmy.com/catalogsearch/result/index/?q=LN-T4665F+&limit=100
Posted on Dec 14, 2009
Testimonial: "I think I can proceed with trying to fix this TV. Thanks for the expert help! thanks for the link to parts also! Cheers, Jim Mulholland aka cutterz"
  • 1684 Answers
SOURCE: Would an inverter from a Samsung Syncmaster 910MP work in a Samsung Syncmaster 940MW?
The Samsung SyncMaster 940MW monitor has an issue with the power supply # IP-46135T going out. The flashing power light or not turning on are the classic symptoms of this issue. Check out our web site at: www.ccl-la.com We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jan 19, 2010
Samsung 60 inch lost video; sound and controls ok. Any idea??
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jun 04, 2016 | Samsung Televison & Video
Could the new main PCB and/or invert PCB be faulty or is TV completely waste of time? I replaced both main power & inverter or interrupt power PCBs now I have no power at all.
Liza-Maree; sorry all boards not created equal , you may have gotten faulty parts. Always make sure to ground yourself before doing this work.
press the helpful button
Jan 26, 2016 | Cars & Trucks
TV HAS AUDIO SCREEN DOES NOT LIGHT UP. CLEANED ALL CONNECTIONS ,INVERTER PCB ,POWER SUPPLY AND MAIN PCB
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Jul 29, 2015 | Televison & Video
Samsung LED40"UA40EH5000R no picture sound ok
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
May 16, 2015 | Samsung Televison & Video
CH52 is flashing on the controller. Unit will not switch on.
CH-52. Communication error between inverter PCB and main outdoor unit PCB. Check wiring fuses and LED's . If OK either inverter or main PCB defective. HELPFUL?
Jan 12, 2011 | LG Heating & Cooling
CH 52 is showing on controller. Unit will not switch on.
CH-52 Communication error between inverter PCB and main outdoor unit PCB. Check wiring fuses and LEDs . If OK either inverter or main PCB defective
Samsung LN-T4665F when powered on picture is ok for 4 secs or less then screen goes black. Sound ok. I think the video is there just no back-light. Following some online advice I replaced the power-supply...
Dec 14, 2009 | Samsung LN-T4665F 46 in. LCD Television
Samsung LN S3238DX display issues
Hi, Your LCD controler is bad. Part number...
320WTC4LV1.0 Also does it do it on the tv menu?
If not it is the Main Pcp board "logic board" part number ...BN94-01011C
Oct 27, 2009 | Samsung LN-S3238D 32 in. LCD HDTV
How hard it is to replace by yourself main board Samsung LN-T4065
You need to do some more diagnosing of the problem. If you get sound and change channels take a bright flashlight and place it again the screen. Look for an image around the edge of the flashlight.
If you see an image that means the LCD controller board (TCON) is probably good.
The problem is probably one of three causes;
1) Inverter board is bad
2) CCFT (cold cathode fluorescent light) are bad.
3) Power to the inverter board is bad. You can also check the connectors.
Mar 30, 2009 | Samsung 32 in. LCD Monitor TV
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
