Question about Harman Kardon HKTS 5 System
Sub woofer when on sounds of distant rolling thunder
I have AIWA NSX-RV85. The sub-woofer surround tore leaving just the cone. When I play, The woofer just makes a rattling sound coming out of vibrating cone.Any advise on how to fix my speakers.Thanks
Refit the rubber, you can find itbon eBay, its called reconing actually in this case the cone is the inlybpart wich you dont want to replace... The rattling is beingproducer due to the fact the rubber normally holds the cone ibto positionering over the coils. This rattling is not good can defect your cone. So dont play it roll you got a new rubber fitted!
Nov 08, 2016 | Aiwa Audio Players & Recorders
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
My Onkyo sub-woofer sounds like something is loose in it or rolling around...the sound is similar to shaking a can of spray paint. When I plug it in to the system it sounds crackly. If i turn the volume...
sub woofers are very powerful bass , with incredible sounding technology. your problem might be with the woofer wall around the circle. open the box and take the woofer out.Check if there is any tare over the corners of the cloth. sometimes there might be a crazy noise because of a little opening in the cloth caused by small tare.. if so better change it with a new 1 and make sure that the new cloth has guaranty
damaged sub woofer eg. images?q=tbn:and9gcqv8lxhmuosnjkfywvef7uujnntmudkhhpl-pghy0i7xushrda- torn cloth- images?q=tbn:and9gctcogf_osbsmo3vmcu1vjnpozksylq4nojwpbojuo3w28zvb3honw
Thanks for rating good luck
Feb 08, 2011 | Onkyo SKW-200 Subwoofer
If i increase the sub woofer volume the voice distorts and gives a buzzing sound. it works fine on low volume
Your sub woofer is not mean for voice sound...check that you have connected the systen up properly and that you have put the sub woofer into its wn connection..if it is in the right connection the woofer could be blown.also try decrease the midrange hurts on the woofer
Jan 03, 2010 | Audio Players & Recorders
Had the subwoofer tested at an audio shop but they wanted to sell me a woofer. It makes no sound at all. A power issue? there was no problems with the 300 watt Kicker amp.
if the speaker cone moves it should produce some sound if it doesn't move when power is applied then the voice coil is frozen.
not really a power issue unless its a "powered sub" and if that's the case then you should not be running in high level sound using speaker wire (especially off a 300 w amp) but instead a low level signal via RCA cable.
Dec 28, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
RCA Sub-Woofer
Did you try making sure the subwoofer is turned on under the set up menu on the Sony Receiver?
Press Set Up, Press the left or right button above the scroll wheel until you get to SW. It should say SW: ON or SW: OFF. If it says SW: OFF, use the Scroll wheel to scroll right until it says SW: ON. Also, make sure you aren't in 2CH mode, try A.F.D or surround sound.
Jul 26, 2008 | Sony STR-DE445 Receiver
Carlos
i have a 81000d for sale for 250 dollars car money still in perfect condition i am pushing 3 12 inch alpine type r subs
Apr 25, 2008 | MTX Thunder 81000D Car Audio Amplifier
No sound
Can you physically move the cone or is it siezed? hook up a wire to its + and - and then do a pop test using a 9volt battery + to + and - to - on the battery if it doesn't make a sound then the woofer is blown, if it does pop then the problem lies within your amp.
Nov 07, 2007 | MTX Thunder 8000 T8154A Car Subwoofer
Harman Kardon HKTS 5 System Logo
53 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
