Question about Coffee Makers & Espresso Machines
Water leaking under my krups 8250 - Coffee Makers & Espresso Machines
3 Suggested Answers
espressonist
  • 1711 Answers
SOURCE: krups xp 4050 leaks water under unit
There are many possible points that the leak can be.
All points of the water supply from water tank to the pressure pump then to boiler and finally to coffee group. All this are connected together with plastic or Teflon pipes with easy fit unions secure with clips
You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
Posted on Sep 27, 2010
SOURCE: krups kp 2000 water leak
I had the same thing happen. It turned out that the rubber hose connecting the water reservoir to the heating element had disconnected, probably due to grinding vibration. I found a triangular screw driver to open the coffee maker up at MicroCenter: http://www.microcenter.com/single_product_results.phtml?product_id=0332974
After removing the bottom of the coffee maker, the repair took 1 minute and it is brewing coffee again like new!
Posted on Feb 02, 2011
Filling machine necessary press ok'. HOW KAN I FIX THIS PROBLEM
The magnetic float in the water tank is probably not floating, jam something plastic between the float and tank bottom or buy a new tank.
Apr 29, 2016 | Krups Coffee Makers & Espresso Machines
Krups ea 8250
If it doesn't grind , than there is no coffe , it will surely come as water .
Grind it first , and than brew the coffe .
Oct 24, 2013 | Coffee Makers & Espresso Machines
During a cleaning cycle my krupa ea8080 bean to cup machine started leaking water from underneath the machine. After trying to make a coffee once it had finished, some coffee is coming out correctly, but...
I have the same problem and have now just located where the water is coming from, it is seal within the boiler/plunger and I am now on a mission to find a service kit. It took many hours to get to this problem and unless you are feeling brave I would consider sending it off to krups!!
I will let you know my progression
Mar 26, 2011 | Krups Small Appliances Espresso Machine
My Krups espresso 7260 is not producing full shots and water comes out under the machine each time I pull a shot or make a (not so) long coffee. Help!
if the machine is old it could be leaking due to lime/calcium build up limeaway and clr should fix the problem, if not you probably have a cracked hose inside
Jan 12, 2011 | Krups XP7260 Espresso Machine
Krups xp 4050 leaks water under unit when sitting on counter
Jun 13, 2010 | Krups Small Appliances Espresso Machine
KRUPS XP7240 leaking water
My XP7240 has the same problem. I went through all cleaning cycles and the filter in the boiler still gets clogged up with coffee oils. This causes back pressure and blows the boiler seal out. Easy replacement if you can turn a screw driver.
Part number for Seal: MS-5015004. You might as well change the Jack too. (the part that slides into the boiler that compresses the ground coffee. (this is a redesigned double seal unit) Part Number MS-0697072.
Both these parts you can get at http://www.krups.com/Tools/Contact/Contact.htm choose your country and email the parts list. Mine cost in Australia $27.00 including shipping.
Good luck.
May 31, 2010 | Krups Small Appliances Espresso Machine
Krups kp 2000 water leak
May 25, 2009 | Krups Coffee Makers & Espresso Machines
Krups Orchestro Leaking
This is a common fault on these machines i have replaced every seal on mine and it still leaks,unless it is really bad i would advise that it be left alone.p.s they are a bit of cuckoo clock inside a proper strip and clean takes about two hours and the parts are hard to come by.
Jan 06, 2009 | Krups Orchestro 889 Espresso Machine
Leaking from the water Chamber
The Krups heats the water through a horseshoe shaped aluminum tube which the heating element is wrapped around the tube in the same fashion, the tube is corroded or cracked most likely, if you poured cold water into the machine when it was hot, this will crack the tube, they are made by Cesod ? which is stamped on the element with a number on it,  and I have seen between 700 and 1100 watt elements. I have the same problem with my 7 year old krups coffee maker, Im trying to repair the tube with aluminum welding or find a new element.  It could also be the high temp tubing may be cracked.  You need tamper proof Torx bits to remove the bottom cover on some models.
Jan 21, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Coffee Makers & Espresso Machines Logo
53 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
