I have a ge washer that spins very slow barely at all..i was wondering if it could be the mounting board that sits on top of the motor... the model number is wpre6100gwt
  • Randy Jan 01, 2013
    is the circuit board that sits on top of the motor a motor control board...does it control the spin speed like the front load speed queens have?? i removed the belt so it was just the motor turning and it was still very slow..so i'm thinking its either the motor or the circuit board that's bad but both parts are expensive so i wanted to make the right diagnoses
    it agitates and it drains but very slow spin..there is voltage to motor
  • 4 Answers
SOURCE: GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
Tell me more Is there voltage to motor? The transmission makes it agitate .
Posted on May 30, 2009
  • 56 Answers
SOURCE: GE washer agitates but won't spin
I think you may have a stopped up pump does it drain the water out if not it will not spin. A putty knife inserted 2 inches in from each side will release the spring catches and gently pull on front as you release sprins then look to the bottom right hand side and there is the pump clamp the tub to pump hose or **** water out with a shop vac take off tub to pump hose and then two 3/8 in screws that hold down the pump turn over where you can look in the pump may have an obstruction as always disconnect power before service.
Posted on May 31, 2009
  • 714 Answers
SOURCE: MY WASHING MACHINE AGITATOR WON'T SPIN. I CAN HEAR
then your motor coupling has broken cost for part is about $20 can buy from your local appliance shop or order from REPAIRCLINIC.com
Posted on Jan 09, 2010
heatman101
  • 43501 Answers
SOURCE: GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 12, 2010
  • 18 Answers
SOURCE: washer clunks and bangs hard when spinning. The
This is a simple repair. The main spring may have come loose from the top (need to check the top two springs ny removing top panel. The reaslon it bangs is from the dampeners being broke. Take off the bottom panel and look inside left and right at the bottom to see if the dampeners are broke. Fairly easy repair - takes some muscle. John<!-- from fixya rte -->
Posted on Aug 11, 2010
Slow spin
http://www.youtube.com/watch?v=YZKqpoVX3t4
watch this video to reset the computer board,if it doesn't help you have to replace the motor,this is not that good of a washer,whirlpool duet is a good washer but that's my choice
9 flashes - The brake resistor failed. This code will limit the motor to 50 rpms. Try clearing the code and if the code comes back replace the motor.
Jun 13, 2013 | GE Washer Motor - WH20X10058
Tip
How it works: Late model Ge top loading washer
The late model top loading GE washer is much different than it's original models that were so much more dependable than these newer ones are. To access the innards you must forst remove the front panel. Older models had the top pop up first but these newer models have the top bolted down. To get the top up you must first remove the front panel by using downward force on the top between the tiop and the front panel. It is not easy even for eperienced techs but cuss it a minute and it will come off. Once it is off you will notice the washer has an elecetric pump. Strings and junk get into this pump. It is easy to take apart and cleanup. The tub is suspended on 4 rods and the lateral movement is kept in check by 4 rubber cord mounted to the top called bungies. The motor and tranny can easily be accessed by removing the tub from the washer. After disconecting the power cable and pump the tub lifts out. Not all GE washers use the same motor or the same transmission method. Some do not even have a tranny. I have some GE washer service manuals.
GE front access late model washer
on Dec 13, 2010 | Washing Machines
GE washer WPRE6100G0WT not agitating or spinning
Depends on how old the machine is. It might me a transmission problem
Jul 25, 2012 | GE Profile WPRE6100G Top Load Washer
I have a GE washer model WHRE5550K2WW. we had a power surger which stopped the wash completely. I replaced the curcuit board behind the control switch witch the allowed the machine to fill,but would not...
Built into the wire harness from the machine control to the inverter board for the motor is a fuse..saddly the only way to replace the fuse is replace the wire harness
GENE
Sep 08, 2011 | GE WHRE5550K Top Load Washer
The washer is powering up but the motor is not spinning as strong as it should it is moving back and forth but very slowly, water is filling up and draining but the cloths is still wet and did not wash,...
Sounds like you may need a motor. If the electronic brake fails it will cause the washer to slow down. there is a led on the board in the motor. See if you can find it and count the number of flashes. 9 flashes is bad brake.
Mar 25, 2011 | GE WBSR3140DW Top Load Washer
Washer goes half way through wash and starts clicking. Motor will go into overload. When turned to manual spinn will click but spin slow. Switching to another cycle will sometimes start it working. In...
Barings probably over heating and expanding due to either dampness, lack of lube, bent broken or misaligned coupling. Is a warranty issue either way unless it was dropped during transit or used exessively on uneven surface. If its out of warranty you might be better of with a new one, trade in if possible.
Oct 31, 2009 | GE WBSE2090A Top Load Washer
GE washer no main motor run so no agitate or spin
This is the electronic washer. Unplug for two minutes, plugin then open and close lid 7 times. This will reset motor. Also make sure belt is not broken.
Jun 07, 2009 | GE WBSR3140DW Top Load Washer
GE Top load washer 15years old. noisy when spinning
washer making a load cluck noise when the spin cycle starts.
It only happens when the motor turns slow for the first minute during the spin cycle. Otherwise it works fine.
if the motor is proper then the bearings in the motor got rusted and that needs replacement.the beasrings are located on the back of the motor.
Apr 03, 2009 | GE WVSR1060A Top Load Washer
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
