Refrigerators Logo
A
Anonymous Posted on Dec 30, 2012
TRAULSEN URS 48 DT - Refrigerators
2 Related Answers
Anonymous
  • 401 Answers
  • Posted on Dec 30, 2009
SOURCE: Need replacement R12 refer and freezer
You can use R134a compressors with the Poly oil in them and use R12 or R134a (flush the remaining old mineral oil out of the system first). Match your BTU requirements.
Anonymous
  • 93 Answers
  • Posted on Mar 01, 2010
SOURCE: the coils behind the stainless back panel are
may be you have problem with the Evaporator fan motor not running, defrost heater, defrost timer, open gap on door gasket and bad thermostat (cold control), it may kept the compressor constantly running. Good luck.
How to install lock on traulsen glass refrigerator
https://www.traulsen.com/service/service-parts-manuals
since your question is non specific to a certain model, try their web site and see if you can find what you need.
1helpful
Traulsen freezer with intella true continuously frosting the evaporator coil and blocking the air flow?
Your defrost circuit ... should (about twice each day) gently warm up.. and remove the frost to an evaporation tray at the bottom of your FREEZER (refrigerator?)...
Regardless of the design...
THERE are only two reasons for excessive FROST.
- massive air intrusion (check seals & gaskets)
- defective defrost circuit (check defrost timer/controller)...
EZ trouble to fix...
Post comment reply: 7/3/2016...
In general... there are only three elements to the defrost circuit:
- 1st failure is usually the "timer" (in your case (other cases it is being replaced by the power control board (do remove power: line voltages present).
- 2nd failure (inside ... usually atop the evaporator) is the "DEFROST THERMOSTAT" (designed the keep the heating element from getting much hotter than 55 degrees Fahrenheit, ("failing" = open.. prevents the heater element from being energized at all).
- 3rd the heating element... itself goes open (usually below the evaporator (caution: line voltages on 2nd & 3rd)).
Anytime you don't feel you've got this surrounded just comment me back... I'll be around.
Go to Bing homepage
http://www.bing.com/search?q=traulsen+freezer+wiring+diagrams&qs=AS&pq=traulsen+freezer&sk=LS1AS5&sc=8-16&sp=7&cvid=47349AEC29CA4E1D8902F3954D86C0BF&FORM=QBRE&ghc=1
Hi i'd like to have the plan of traulsen's refrigerators and freezers model URS 48DT
https://feg.hobartcorp.com/resourcecenter/ProductDocumentation/TR35749%20Rev%200503.PDF
Only manual found is the UR48DT. Try to access this site for the manual. If you can not, let me know and I will try to email it to you.
Need replacement R12 refer and freezer compressors. OEM Americold compressors no longer available. URS 48 DT model should also work. Thank you.
The coils behind the stainless back panel are caked with ice. I have defrosted them...now what.Fridge won't stay cold and ice keeps building up.Unit is 17 yrs. old. traulsen freezer/glass door fridge ERS...
How do you adjust temps (Traulsen URS 48 DT)?
You can go to traulsen.com and download the owners manual for your model and serial number. I did and it was VERY helpful to me. Let me know.
Traulsen URS 48 DT Freezer in Freeze/Thaw Cycle/Fridge Side O.K.
I'm not intently familiar with this particular brand, but here's some ideas to check. If the thermostat sticks on, the freezer coils can freeze, blocking air flow and jamming circulation fan. This will cause the temp in freezer compartment to rise. When the ice on the coils thaw, the compartment starts to cool again, but the cycle will continue. Another thought is if this unit has a defrost timer that could be defective. Without seeing the unit, it's hard to determine the exact cause.
Hope this helps.
Reference manufacture date
Hello Rob,
I called Traulsen with your model and serial # and was able to ID the manufacture date, Oct 4, 1989.
We specialize in cooler/freezer gaskets. We also sell refrigeration hardware & accessories. We can get many Traulsen OEM parts below list price. We'd be happy to help you locate the parts you need.
Shoot us an email to [email protected] or call toll free at 855-288-2259
Thanks,
Matt
Coolergaskets.com
Traulsen ur 48 dt freezer want go below 10 deg
The first place to look is to check the charge. Using guages check the low and high side pressures and their relationship to one another. I'm assuming your unit is a R-404 unit which, if fully charged and the condenser is clean, and the fan is operating, should have about 210 to 250 high side pressure. Other things to check: evaporator coil ice/frost free; defrosting properly to obtain a clean coil; all evaporator fans running. If low side pressure is above 30 PSI you have a weak compressor. Whatever, fix the Traulsen unit, its head and shoulders above anything else on the market today.
Nov 23, 2008 • Freezers
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
