When we receive a FAX on our super Phone the message sent is not printing out for us this end
Thank you but we had put the fax paper in upside down.. it is now fixed.. thank youspan.jajahWrapper { font-size:1em; color:#B11196; text-decoration:underline; } a.jajahLink { color:#000000; text-decoration:none; } span.jajahInLink:hover { background-color:#B11196; }
Posted on Jan 26, 2009
Thanks for your reply.. it seems we had put the new roll of paper in back the front... it is now working well ,..... thanks
M.DeBono
Posted on Jan 19, 2009
How to confirm message sent what is the code so i know the party is sent it to received it
There is a transmit report which can be auto printed for every fax message sent out. Go to menu, under the fax sub-menu, turn on the transmit report (under report).
Apr 10, 2014 | Brother IntelliFAX 1270E Plain Paper Fax
How can I get a FAX Confirmation printed out on the HPJ4680?
If you require printed confirmation that your faxes weresuccessfully sent, follow these instructions to enable fax confirmation beforesending any faxes. The default fax confirmation setting is Off. This meansthat a confirmation report is not printed for each fax sent or received. Aconfirmation message indicating whether a fax was successfully sent appearsbriefly on the control-panel display after each transaction. NOTE: You can include an image of the first page of the faxon the Fax Sent Confirmation report if you choose On Fax Send or Send &Receive, and if you scan the fax to send from memory To enable fax confirmation
1.Press the (Setup) button.
2.Press right arrow to select Print Report, and then press OK.
3.Press right arrow to select Fax Confirmation, and then press OK.
4.Press right arrow to select one of the following, and then press OK. Off Does not print a fax confirmation report when yousend and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every faxyou send.
OnFax Receive Prints a fax confirmation report for every fax you receive.
Send& Receive Prints a fax confirmation report for every fax you send andreceive
Jan 10, 2011 | Office Equipment & Supplies
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
I can not receive a fax
Hi there, Fax machines are still in common use today despite the widespread adoption of computers along with their multiple communication tools, including e-mail and social networks. Fax problems can include trouble receiving faxes, dialing issues, faxes not printing and poor print quality. Performing periodic maintenance can help with fax problems. Check any visual indicators for trouble. Many fax machines have a display panel and use it for reporting error messages. Often the messages are in plain text and can be understood without referring to the instruction book. Refer to your fax machine'smag-glass_10x10.gif instruction manual for any numeric error codes.
  • Step 2.Replace the cables. In particular, replace the telephone line cable that runs from the wall to the fax machine. The plugs can become lame, and the wire itself can break inside, providing no visual indication it's broken.
  • Jul 31, 2010 | Sharp UX-B750 Inkjet Fax
    I can receive faxes but cannot send them
    Is it possible that the RECEIVING FAX-unit caused the "not sent" message? It could be out of paper, and thus would be unable to print the FAX, after receiving it. So, it would signal "not sent", meaning that "not successfully received and printed".
    Jul 20, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
    Confirmation page shows zero pages sent. Is there a way to set to show the number of pages sent
    I would first test a fax to see if it completes on your end then is received on it's entirety on the receiving end. Then print a fax transmittal report to confirm. Once that shows success, print your polling fax report and verify.
    If it says zero pages sent, chances are the fax failed.
    Jan 14, 2010 | Brother IntelliFAX 4100e All-In-One Laser...
    Sharp FO-4700 Fax Not Received Even Though OK Fax Confirm Given
    It's gone forever, once your machine received a EOT (end of transmission signal), your fax machine thinks it was received OK and clears it from memory.
    Oct 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
    How do I get a fax conformation?
    This is an excerpt of the User's Guide for your machine. You can download from here:
    http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
    Print fax confirmation reports
    each transaction.
    1. Press Setup.
    2. Press 2, and then press 1.
    Send & Receive Prints a fax confirmation report for every fax you send and receive.
    User Guide 65
    Fax
    Tip
    If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
    Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
    How can i generate incoming call report ?
    To print a report:
    1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
    2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
      • Phone Book: Phonebook list
      • Sent Report: Sent fax report
      • RCV Report: Received fax report
      • System Data: System data list
      • Scheduled Jobs: Scheduled job information
      • MSG Confirm: Message confirmation
      • Junk Fax List: Junk fax number list
    3. Press [Enter] to print the selected information.
    Your machine can print reports containing useful information. The following reports are available:
    • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
    • Sent Fax Repor: This report shows information of the faxes you recently sent.
    • Received Fax Report: This report shows information of the faxes you recently received.
    • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
    • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
    • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
    • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
    • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
    • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
    NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
    Aug 04, 2009 | Xerox PE120i Laser Printer
    Brother Intelellifax 2820
    On some fax there are reports that you can print out, it is in the setup for printing out received message, sent messages etc. Try that, if you have a book it will explain how if not ask again and I can talk you through it...
    Aug 22, 2008 | Brother IntelliFax-2820 Laser Fax
    jasbo
    jasbo
