Question about Coffee Makers & Espresso Machines
I want to reset Nespresso citrix d 120 to Factory settings.
    Genius:
  • Coffee Maker... Master
  • 1,669 Answers
Try this:
http://search.aol.com/aol/search?&s_qt=sb&q=hespresso+citrix+d120+reset+factory&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
Posted on Jan 24, 2013
The 2 buttons keep flashing & the water won't heat up
You must re press both buttons at once again sow you will remove mashein from descaleing mode
Oct 09, 2016 | Nespresso Coffee Makers & Espresso...
1.My Nespresso Pixie Lights never stop flashing. 2. I also want to reset to factory settings because the cup portions are off. 3. I feel the water temperatures is never hot enough for the coffee
1: Depending on how long you've had your machine, it may need descaling. The machines are preset for hard water - if you're in an area with soft water, try pressing and holding the Lungo button while you turn the machine on. Hold until the lights stop flashing.
2: The Pixie can be reset to factory settings by holding both buttons down before and when you turn the machine on, again until the lights stop flashing - this will reset to factory settings.
3: The temperature is preset to be the optimum temperature for the extraction process. If, after following the above steps, the temp is still too low, call the Nespresso Club and they will advise you.
Hope this is of help to you!
Mar 18, 2015 | Nespresso Coffee Makers & Espresso...
HOW TO ADJUST WATER QUANTITY AS THE LONGER BUTTON WILL NOT ADJUST, SHORT CUP IS OK
Try resetting to factory settings by holding both buttons down while turning the machine on - hold till lights stop flashing. Then programme both espresso and lungo buttons again in the usual way.
Hope this helps!
Mar 13, 2015 | Nespresso CitiZ & Milk Espresso Maker
My nespresso stops half way though making a cup of coffee and have to press the button again repeatly to start it again
Has anyone operated your machine that was unfamiliar with the correct method. It sound as though the quantity has been reset. Try holding both buttons down while turning the machine on - hold till buttons stop flashing. This will reset to factory settings. Then, you can programme each button by holding it down whilst extracting, then releasing when the correct amount is extracted. It will remember this until you return the machine to its factory settings as above.
Hope this helps!
Mar 12, 2015 | Nespresso Coffee Makers & Espresso...
My nespresso is only creating 3-4 oz of coffee using the 6 oz button. Have descaled with no change. Any ideas?
Try holding both the buttons down and then turning the machine on while still holding the buttons till they stop flashing - usually about 2 - 5 seconds. This will reset to factory settings. Then you can reprogramme the Lungo button if necessary, by holding it down white the coffee is being extracted, till the amount you want is processed. The machine will remember this till you reset to factory settings.
Dec 06, 2014 | Nespresso Citiz C110
Both lights on my older model machine won't stop flashing
Try holding both buttons down while you turn on the machine - hold down till they stop flashing, usually 2 - 5 seconds. This resets the machine to its original factory settings.
Oct 11, 2014 | Nespresso Coffee Makers & Espresso...
Delonghi problems
Try pressing all 4 buttons on top of the machine simultaneously after turning on the machine for a few seconds. That resets all volumes to the original factory settings.
Aug 02, 2014 | De'Longhi En520.W Nespresso Lattissima...
I have a Pixie but the large cup does not shut off
Hold both buttons down while you turn the machine on - for 5 seconds - which will reset the machine to its factory settings. Then you can reprogramme to suit your taste, as in the instruction book. Good luck - hope this helps.
May 27, 2014 | Nespresso Le Cube
Magimix M190 CITZ
Are you using genuine nespresso capsules? Are they seating properly. Open the slot where you put the capsule in and check its very clean and nothing is stuck in there.
Have you tried resetting to factory settings?
Apr 03, 2014 | Nespresso D300 Espresso Machine
Coffee not hot enough Is there a way to modify the factory settings to make coffee/milk warmer for the Nespresso Latissima machine?
Before placing first coffee capsule in the machine, run the large espresso cup button into a cup (clear water will come out). This primes the machine and makes for hotter coffee.
Oct 03, 2009 | Nespresso Lattissima 660.R
Coffee Makers & Espresso Machines Logo
842 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
