Question about Vizio GV47LF Television
Where do I find fuses for vizio - Vizio GV47LF Television
  • Vizio Master
  • 8,617 Answers
Hit the contact us button from the homepage www.tvrepairworld.com and let them know your model and what you're needing they will have them and they respond quickly.
Posted on Dec 30, 2012
How do I locate the fuse on my 32" led vizio after a power outage it has no power
take the back off its in there,if the fuse is bad,replace with the same fuse,some blow fast and some blow slow
Jun 15, 2015 | Vizio Televison & Video
HOW DO YOU REMOVE THE FUSE ON A POWER SUPPLY FOR VIZIO DPS260HP-1.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 21, 2014 | Vizio Televison & Video
Where are the fuses in my vizio vf550xvt
the main power supply fuse will be located on the power board. Just follow the power cord to the power board, the fuse will be close to the power connector. FYI, there are also fuses located on the main board, t-con, and inverter boards.
Dec 09, 2012 | Vizio Televison & Video
Fuse locations vizio e470vle
The fuse will be located on the power supply board. The power supply board is the one that the power cord plugs into. The fuse should be close to where the power cord plugs in at.
Dec 06, 2012 | Vizio E470VLE 47 Class Widescreen LCD HDTV
VIZIO LED TV MAIN BOARD FUSES
Check and replace the board. It will have some direct shorted component/s on it.
Aug 19, 2012 | Vizio GV47LF Television
27' inch flat screen (vizio) i think it mayhave experienced a power surge. I was told to check the fuses since vizio uses a cheap fuse...what is your suggestion? It's only 5 months old hate to...
try to check the main power supply and replace the fuse with the same type,but be sure to unplug it first, it's printed in the pcb beside the ac supply. if the vizio uses a cheap or under rated fuse. then your unit will work fine again.
Jul 05, 2011 | Televison & Video
My Vizio vp50hdtv20a has no video but has audio. any solutions??
A lot of Vizio sets had a habit of the T-Con board fuse opening for no apparent reason. It's a rather small surface mounted devise (smd) that does not look like a fuse your accustomed to. Best to let a professional make sure.
Dec 07, 2010 | Vizio VO47L 47 in. LCD TV
No power to tv after power outage
The power boards go bad alot in vizio's, Most likely 4 bad cap's need to be replaced, $10 in parts,,
Feb 12, 2010 | Vizio Televison & Video
Vizio has no power want to check fuse
remove back, only exposed board there is PS, look where blue/brown AC wire plugs into it, fuse (F1) is there (5amp-250v)
if fuse is good and you get no power or front light replace that board, or start component level troubleshooting (usually regulator trans or SM fuses (000)
Jun 24, 2009 | Vizio VX37L Television
Vizio GV47LF Television Logo
67 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
