Question about Epson Stylus 1400 InkJet Photo Printer
Can't find ink levels in windows 8
I just got a new laptop with windows 8. I am out of ink in one of the cartridges and I can't find where to see the ink levels in windows 8 so that I can change it? I have now spent 3 days trying to figure it out. Please help.
Download the driver from epson.
For example I downloaded epson375130eu for a stylus dx4450.
then right click on the downloaded file and select "solve compatibility problems", select fix the program, select program was working with previous windows versions, select xp.
you should be able to have the ink levels. At least it worked for my dx4450
Posted on Oct 15, 2013
Buy a new printer compactable to windows 8.....:P
Posted on Jan 12, 2013
printprakash
  • 56 Answers
SOURCE: I have an Epson Photo R200. The low ink light was
Dear friend,
I assure you the newly put black ink catridge has problem.try with another one,it'll solve the problem.
Posted on Mar 08, 2011
  • 65 Answers
SOURCE: new ink cartridge not working properly
if you open the lid of the printer you should have the ink slide to have you take it out.
I would unplug the printer for about 5min and then plug it back in and then it should ask you to redo it again.
Nikki2913
Posted on Dec 02, 2008
SpeedBullet2
SOURCE: Status Monitor 3
In reply to SOLUTION #1 by Basti i have vista and have forced it to work with this status monitor 3 software i will post how i did it now.
First i downloaded the status 3 monitor so that i could fiddle with the programs and files inside from this link here
http://driverscollection.com/?file_id=24410
Ill skip right to the part on how to fix it you extract the file you just downloaded open the folder it went to right click E_SIINS2 with a bandaid icon goto properties then click compatibility at the top of the new window that opened check the box run this program in compatibility mode for: then in the drop down box below that windows xp (service pack 2) also i checked at the bottom run this program as an administrator and boom it worked i can see my ink and everything.
Posted on Dec 06, 2008
gwbm
  • 353 Answers
SOURCE: The new ink cartridge is not dispensing its color.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three
cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If these actions produce no positive results, or if you have already done lots of head cleans with no result, and you're sure you have a good ink cartridge properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer
on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way.
Look inside the print head parking area on the right and you will see a rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean again. Repeat this process again if necessary.
If still nothing, it looks like you may have a failed cyan print nozzle I'm afraid, or some other internal problem. This will require checkout by a Technician. Make sure you compare the cost of repair with the cost of a new printer!
Posted on Feb 28, 2009
jacklee366
  • 541 Answers
SOURCE: Using the SSC software the ink freezer doesn't work on the RX620
ink freezer dont work only on some printers
Posted on Sep 17, 2009
How do i find ink levels in Windows 8 for HP Office Jet J4580
It depends on what type of ink cartridge you have installed.....with HP genuine ink cartridges and HP Solution center installed, everything should be there. However, if you get an HP integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901, 92-98....currently offered at Costco or Frys today) or if you buy a remanufactured/compatible HP ink cartridge, the ink levels will not be displayed nor can they be reset (HP has a smart chip embedded within the nozzle plate at base of ink cartridge which counts the drops and then registers as empty).....so you'll just need to live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and similar while you are using these types of aftermarket supplies. The first video below provides an overview of the 'low ink' phenomena.
NOTE: These types of 'SEVERE' cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print cartridge(s) problem" etc.) typically indicates the internal micro-electronics of the HP #901 / 901XL cartridge are damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure. I suggest you first run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on all models which use HP 901 cartridges. Refer to Inkjet411 youtube videos below:
HP Officejet J4500 J4600 4500 Printer Error Messages -HP 901 & 901XL Cartridges
http://www.youtube.com/watch?v=RivHgvWCkJ8
HP 901 & 901XL Ink Cartridge Alerts - Low Ink Warnings:
http://www.youtube.com/watch?v=hzLM5mlkTt4
HP Officejet J4500 J4600 4500 Printers Tap 41 Diagnostics - HP 901 Incompatible Print Cartridges: http://www.youtube.com/watch?v=S6uATgXxQlE
HP Officejet J4500 J4600 4500 Cartridge Error Bypass - HP 901 Cartridge Errors: http://www.youtube.com/watch?v=I4-m_RLdRE4
HP 901 Ink Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=jTtNj6rN4g4
Apr 12, 2013 | HP OfficeJet J4580 All-In-One InkJet...
Ink levels lights flashing but ink is full
Might be cartridges are refilled.
You may got doubt why its not measuring the ink levels?. When printer found new catridge(printer/system based on design) will treats that new cartridge installed & estimated level will display fully.After couple of print outs printer/system will displays estimated ink levels depend upon the ink usage. But there is no mechanical ink level sensors or any other device for mesuaring the levels..Once the ink level trated empty you need to replace new cartridge straight away,if you refilled the same catridge it wont measure the levels, because of the cartridge data code already stored in printer. ..
Nov 02, 2011 | HP DeskJet F4280 All In One Printer InkJet
After refilling my cartridge it shows ink level low for one cartridge and gives two error messages for every printing but prints. But for another cartridge it does not print and give message to buy a new...
Original Printer manufacturers do not recommend refilling in cartridges.
Different inks used in different cartridges differ in density, color, acidity etc. Usually refilling ink is made as universal ink. i.e. They produce the ink for 'any printer'.
The differences in the original and refiling inks might lead to the printer not recognizing the ink level.
Either buy a new cartridge or just ignore the messages.
Sep 24, 2011 | Lexmark Z1320 InkJet Printer
I have a photosmart C4700 and it won't print in black How can I tell if it's out of ink?
Follow these steps to check the ink levels: >Click Start . >Click Printers and Faxes . >Right-click the icon for your printer , and then click Printing Preferences . >Click the Features tab. >Click the Printer Services button. The Toolbox window opens. >Click the Estimated Ink Levels tab. A window opens that indicates the estimated ink level of each cartridge.
NOTE:Depending on the printer, the estimated ink level indicators can vary in appearance.
>If the ink level indicators show that a cartridge is low or empty, replace the cartridge.
Aug 13, 2011 | HP Office Equipment & Supplies
I installed new b&w & color cartridges and the
in your printer try to press on the restart button and hold it for about 8 to 10 seconds. by the way the ink cartridges that you installed are the genuine ink cartridges, if not then its gonna be normal that it won't detect as new.
Jul 11, 2011 | Dell Office Equipment & Supplies
I have changed the colour ink on my canon mp460 but it still say empty
CL41, this is the one you are using for your cartridge.
Did you change your cartridge with brand new one or refilled one??
If you did with refilled one, the ink level won't go back with full.
This is the method how printer measures the ink level.
1. Each cartridge has a serial number.
2. As soon as installation in printer, printer recognizes the cartridge by serial #.
3. And the printer starts to count the printing document.
4. After reaching certain print counting, the ink level will show "low ink"
So my answer is even if you refilled your cartridge, the ink level won't change,
since printer cannot weight the cartridge or.....some other technology to measure each color ink level.
Thanks.
Jun 15, 2011 | Canon PIXMA MP460 All-In-One InkJet...
Printer (HP5650) has full ink cartridges.window sez almost empty
That is normal, the printer "sees" the cartridges by their serial number, so when you pop in a refilled cartridge, the printer thinks you have put in old cartridges and continue to show low ink level. When you pop in a new one, with a new serial code, the ink level will reset, showing that the cartridges are full again.
You can try this:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
Doesn't always work, but you can try.
Here are links, so you can see:
http://www.misterinkjet.com/hp56reset.htm
http://www.misterinkjet.com/hp57reset.htm
Hope that helps!
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
My fax won't print, neither faxes nor copies. The paper goes through & it makes sounds like it is printing but nothing on the paper. The machine says the ink level is 6/8. I "aligned" and...
Though the ink level it said was "6 / 8", when I removed the cartridge to examine it looked bone dry empty to me. I replaced the ink cartridge. It works fine, and reports the ink level as "8 / 8".
Sep 09, 2009 | HP 1040 Plain Paper Inkjet Fax
IP 3300 refilling of ink tanks possible or not
Yes it is possible, Try injuctions to refill your cartidates.
Feb 22, 2008 | Office Equipment & Supplies
Epson Stylus  1400 InkJet Photo Printer Logo
1,913 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
