Question about LG WM-2277HW Front Load Washer
Water leaking from bottom of washer
Just got this washer delivered today. First load, only a few towels, HE soap in soap dispenser and washer turned on. Water begins coming out from underneath the washing machine - quite a bit of it. We turned off the washer and the water continued to come out for another minute or so. There is no water on the wall behind the washer, connections are checked. The washer is solidly sealed and the only place the water could be coming from is underneath but how, where why.....we don't know. A little additional history: we bought floor model matching washer and dryer from Fry's electronics, paid cash for them Tuesday and they arrived this morning (Friday). Dryer is fine but what is wrong with my washer?????? Anybody???
  • 1 more comment
  • gotwater May 09, 2008
    We had the same problem with water leaking out of the bottom
    somewhere. LG replaced the first washer because they could not
    find the problem. Now the new washer is doing the same thing --
    but not all the time! Even with the same loads, one time it's
    okay and then another time it will leak. Very frustrating -- not
    to mention having spent so much for a washer. We also purchased
    the pedestal. Sure would be great if someone knew what was going
    on.
  • caroline willi Jul 12, 2008
    I have the same problem, it even leaks if I pour a couple of cups of water directly into the drum, even before I turn it on!
  • md dad Nov 15, 2008
    water leaking out the bottom, I've got a base, so it is hard to see what's wrong.
I had the same problem of a mysterious leak. Had repair man out for 2 years no help. Now that it is out of warranty and I am mechanically inclined I decide to take the thing apart.The leak is actually near the coldwater inlet valve but it is so intermittant that I cant ever catch it actively leaking. All I know is that it leaks when it is not being used. I have even gone around to other water sources in the house thinking that the change in water pressure might cause it. No use> Went to bed no leak woke up 3 hours later water on the floor and wetness under the top cover( i said I took it apart) Not sure if a new inlet valve will fix until I actually see it leak!!!!
Posted on Jan 08, 2011
VERY POSSIBLY A SMALL PIPE PULLED LOOSE OR A LARGER PIPE COME OFF DUE TO TRANSPORTATION. DONT THINK ITS A BIG ISSUE . TAKE OFF BACK COVER AND REPEAT CYCLE ONCE AGAIN. YOU WILL PICK UP PROBLEM QUICK ENOUGH.
Posted on Jul 26, 2007
CHECK YOUR FILTER IT HAPPENED TO ME 2 WEEKS AGO
Posted on Jul 11, 2007
    Sergeant:
  • 236 Answers
You need to fill it up a little then switch it off. tilt it backwards and if it hasnt got a base you should be able to see where the water is coming out of. check the bottom hose and around the element location.
Posted on Jun 23, 2007
Kenmore front load washer is leaking water from soap
We had a similar problem with water coming out of the soap dispenser when the washer was run. I assumed that it was a problem with the water draining as everyone else posted here. I took off the front panel, got rid of the junk and drained it. Although this was great, it did not solve the original problem. It turns out that there was a sock stuck in between where the water comes out of the soap dispenser and in to the main compartment. Pulled it out with a needle nose plier and good to go. Thanks to everyone for their input here.
May 28, 2010 | Kenmore HE2 Plus Front Load Washer
Frigidaire gallery series front load washer leaking water on side where soap dispenser is. Have had two different repair places take a look at it- replaced soap dispenser- still leaks - repair people can't...
turn down the water pressure on the water line to the washer if the water pressure is to high it will splash out of the filler. there should be a vale on the main water line to the washer.
May 19, 2017 | Frigidaire Gallery Supreme Series...
Water leaking into soap dispenser when machine off
faulty water valve turn both off to see if it stops then turn on one at a time if it leaks thats it
Dec 15, 2009 | Miele Touchtronic W3033 Front Load Washer
GE whre5260e1ww zh133346g top load washer is leaking small amount from the bottom of the machine during wash cycle? I took the back of the machine off and the pump and motor assembly had broken off from...
Hello there:
Here is a few tips that might help you out
Hope that they are very helpful for you
Best regards Mike
Washing machine is leaking Washing machine leaks are very common. There are many places a washing machine can leak from although most leaks come from the same few places. The most common cause for a leaking washing machine is the door seal. Door seals often get holes in them and water leaks down the inside of the washing machine which then runs out under the front. Water leaking down the front of the washing machine from the door can be caused by a worn door seal (the flange part that the door glass presses against when closed) or something trapped between the door seal and the door glass which breaks the seal. If the door seal doesn't look worn, or it's too young to be worn, then try cleaning the door seal's flange and the door glass on the inside of the door. Bits of cotton, un dissolved washing machine detergent etc can cause a leak.
Soap dispenser leaks
The next most common cause of a leaking washing machine is the soap dispenser. Leaking water from a soap dispenser is often caused by a blockage, or water pressure that is simply too high. Despite seeing many leaking soap dispensers, I've never seen a soap drawer with a seal, they just rely on water not getting to the front which is not really good enough. Some Hoover soap dispensers in particular, are renowned for leaking, and over the years Hoover have had to introduce modified soap dispensers twice.
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and the hose wasn't wide enough. Un dissolved powder from a tablet or lumps of detergent through poor hot water pressure can block this hose solid. (Note: water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning)
Finally, black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases I've had to replace the dispenser.
Tips for finding a leak on a washing machine
  • If you have a leaking washing machine, and you can't see where it's coming from, shove some newspaper underneath the washing machine. The slightest drop will give a clue where the water is leaking from. Pull the sheet out regularly to check for water leaks.
  • Water can run round things and drip onto other parts. Be careful with your diagnosis, as water dripping from a hose at the bottom could actually be leaking from somewhere else higher up.
  • Leaks usually leave marks, so it's possible to see something is leaking even without witnessing it. The soap suds that come out with the leaking water leave white trails. Rust is a good indicator of a water leak too. However, if you have had a previous leak cured, the "evidence" of a leak may still be present so be sure you don't blame a part that was repaired in the past.
  • If the washing machine leaks only at the end of the wash, when water is being pumped out. Make sure water isn't backing up and cascading over the top of a blocked drain pipe in the plumbing.
  • WARNING: Don't get electrocuted trying to witness a leak. It's dangerous running the washing machine with the top or back off.
Nov 13, 2009 | GE WDSR2080D Top Load Washer
Kenmore Elite HE3t Front Load Washer leak from dispenser
I was just about to call the service teck when I decided I shouldn't be this stupid and try and fix it myself.
I took the tray out and looked in with a flashlight.
Saw nothing.
Cleaned the tray and then checked the drainage hole inside the opening where the tray normally feeds the machine the soap.
I found a inside of the liquid XXXKing laundry cap partially blocking the drain.
Took it out and works fine.
Sep 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Water Leaking really bad from the Dispenser area
Disconnect the plug from the outlet. Remove the top of the washer panel by removing the 2 back hex screws then sliding it back to lift it off of the washer. Take off the front control panel by removing the phillips screws holding it in place. Remove the dispenser drawer. Check the dispenser housing for clogs or lime build up at the bottom of the dispenser housing. Or the drain hose (large black hose attached to the front of the drawer housing) to the washer may be crimped or clogged.
Aug 14, 2008 | Maytag MAH6700AWW Neptune Front-Load...
WATER LEAKING FROM FRONT BOTTOM
try onscrewing top panel on machine...when machine agitaes strongly a hose my pop lose up from top.
Jan 22, 2008 | GE WBVH6240F Front Load Washer
Lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
Jan 16, 2008 | LG WM1814CW Front Load Washer
Whirlpool Duet Washer 8500 Dispenser Leaking
Ok try not to pull the dispenser too far out. When you pour the liquid detergent in the dispenser I belive it should say in the cup. For the shaking if the washer is not on a solid surface like a cement floor it will shake and walk if the floor is weak. Also make sure the delivery guys removed the 4 shipping bolts in the back. If the dispensor still leaks call for service bucause its new. Also some stores will exchange it if there is a problem within 30 days.
Jul 12, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
LG WM-2277HW Front Load Washer Logo
1,123 people viewed this question
Top LG Washing Machines Experts
Marvin
Marvin
jimorris77
Paul
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
