Baxi 80 eco fires up then goes out after 5 seconds, red light comes on.
Hi all...im new here so hello. My boiler has got a red warning light on the front panel, i reset this by turning the knob to the "R" on the controls. The boiler then fires up, but goes out after 5 secs or so.....any idears where to start to look? Cheers Graham
4 Suggested Answers
  • 30 Answers
SOURCE: overheating
you could have a flow problem due to sludge or scale in the boiler, it could be a pump problem as it may not be circulating enough water around the system. or it could be a faulty thermostat if it is not cutting out soon enough.
1st try turning the boiler stat down to its minimum, if it still over heats then it is probably the stat.
if you have a switch on your pump to increase the speed make sure it is on setting 3. if the pump is old then it may be time for a replacement.
Posted on Mar 30, 2009
gary1121
  • 332 Answers
SOURCE: Baxi 80 overheating on hot water circuit
thermostat on the gas valve needs to be replaced,, which you will probly have to change the hole gas vale ,, check on the parts and labor and if it is over 6 years old wheigh the diffrence between it and a new unit good luck
Posted on Jun 10, 2009
SOURCE: I'm a plumber and was looking at a friend's
Many boilers seem to use a more or less common type of thermister although actual fixings vary. My experience of one of these from another brand of boiler was 670 ohms at 10 deg C and 10 -11 k ohms at 20 deg C
Posted on Jan 13, 2010
I am wanting to wire a Baxi 105E boiler to a Danfoss 102 mechanical timer. The boiler has 5 wires = red, blue, earth, black and yellow. The Timer has six terminals = 1 DHW, 2 HTG, 3 COM, I (earth), 5...
1) Contact baxi:
http://www.baxi.co.uk/contact.htm
2) Which boiler wires? I don't know. Page 24 manual.
Manual says to disconnect link between terminals 1 and 2, and instert timer in-line.
http://www.acwilgar.co.uk/Boiler-Manual-PDF/Baxi/Combi%20instant%2080E%20&%20105E.pdf
2) I can tell you about the timer wiring.
Timer is 230Volts
Not sure if you have British Hot-Neutral 230Volt, or Hot-Hot 230Volt.
Wiring is same 2 wires, but words to describe are different.
Let's say you have Hot-Neutral 230V
Connect Hot to L6
Connect Neutral to N5
This will power the timer so it runs and keeps time.
You can get Hot-Neutral wires from Hot-Neutral that arrive to power the boiler.
Now the timer terminals are separate.
E terminal is Earth or ground.
The Common is Hot wire.
The timer then turns on-off and switches back and forth between DHW and HTG.
HTG is heating
DHW is defrost.
Timer has 2 sets contacts.
When timer activates first set of contacts, then DHW defrost terminal receives power from Hot wire on Com terminal. At this time, all power is cut to HTG heating terminal.
When the defrost cycle ends, then the heating circuit receives power, and then the timer has programming that opens and closes a second set of contacts going to HTG heating terminal.
Which wires from boiler connect to each terminal, I am not sure.
Feb 03, 2013 | Hardware & Accessories
I want to use my baxi bermuda gas fire just as a fire as having a combi boiler installed is it possible
yes a combi boiler has to be piped so they would cut off the pipes to your baxi and you can ues it as a gas fire only
Nov 06, 2012 | Heating & Cooling
Boiler not working
I would call the person or company who installed it. May be a simple fix you do not know about. You may have to wait till they open.
Sep 28, 2017 | Heating & Cooling
We have just moved into an old house with a Baxi open fire and have no idea how to use it. Do all Baxis have boilers? How do we find the model name/number? Is there any risk in using it if the backplate is...
baxi do boilers they are on the baxi potterton wed site, but they are gas would not use with the back platecracked this old fire place you may have trouble finding parts if any , try someone one that deals with woodburners of fire places , they could well be you bestline to go down or a chimney sweep
Oct 15, 2010 | Heating & Cooling
Got a baxi bermuda 552, back boiler not working
Hi clean pilot light and change the thermocouple , you will have to remove the gasfire to get to the boiler if unsure best get a gas fitter to do this as this is not easy to explaine , simple job but you have to know what you are doing , it might be you need a service on the bbu and the gasfire then the thermocouple could be done at this time.
Feb 20, 2010 | Heating & Cooling
I'm a plumber and was looking at a friend's Ariston Microgenus 28 kW combi boiler today. The problem is the DHW comes out tepid, then within a few seconds of the burner igniting, the temp indicator lights...
Dec 10, 2009 | Combi Centre DX - Mango
How to light pilot light on back boiler?
Hi. we have a baxi bermuda. I know that you need to hold in the silver button on the left while repeatedly pressing red/ignighter button until pilot is lit. Hold in the silver button for at least another 30 seconds.
Good luck, ours wont light anymore so was on here looking for advice.
Cheryl
May 07, 2009 | Kitchen Ranges
Baxi 80 e some rads hot others cold
is the pump running or is there an air lock near to the boiler check water tank in loft the smaller one to make sure you have water in the system
Apr 24, 2009 | Combi Centre DX - Mango
Boiler overheating
the problem there a relay stuck or thermostat bring on the pump & you can lower your high limit aquastat!! also the flow valves can bypass hot hot water risers time to put in a seperate water heater domestic coil are not energy efficient !!!! aquastat high limit set @ 180f deg low limit set @ 140f deg!!!
good luck!!! tim
Oct 08, 2008 | Water Heaters
Baxi Combi 80e
i need to know boiler specifics- make and model but sounds like either the air pressure switch seized or the main printed circuit board, if the boiler has an overheat thermostat please ensure that the little red button hasnt popped out because this will prvent the boiler firing up- refer to the manufacturers instructions for location of the o/heat stat
May 05, 2008 | Combi Centre DX - Mango
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
