Question about Garden
Put new coil need how to set the coil
Need seting for coil
  • 2,239 Answers
For an external coil, the air gap should be 0.3mm,slacken the fixing screws, place a suitable feeler gauge between the coil laminates and the flywheel, turn the flywheel so as the feeler gauge is sandwiched between the coil laminates and the flywheel manets, now tighten the fixing screws.
Posted on Dec 30, 2012
Lawn mower turns but no spark on murray 12.5 ride on
If you put a new plug in it then sounds like your coil went out,or if it has set for a very long time the coil will lose ground and wont fire,but if just happened recently then most likely your coil has went out and need to pull top off the engine then loosen bolt that holds flywheel on and with any luck it will come off with no troubles and the coil will have a wire plugged into it that is your stop wire for your ignition then there is 2 bolts that hold coil on I think they are 1/4 in loosen them take off coil and when you put new coil on you will have to set the gap,on single cylinders I set the gap at 10 thousand and I do it with 2 gauges so they are both perfectly set from the fly wheel plug your black wire back on and put back together as you took it apart good luck!
Sep 28, 2014 | Briggs & Stratton Garden
When i give the passport given by d_link .my network does not accept that.i have just instalted a wierless rotate d_link dir 615.but anytime i enter the code it doesnot accept it.thankyou
if is a WPS setting for wireless, is beter to connect whit the small patch cord to the router and desactivate the WPS setings and go to wireless seting/security and put wpa/psk2 shared key, is more simply and easy to remember.
best regards
Sep 22, 2011 | D-Link Computers & Internet
I pulled distributer, installed new now it runs but falls on its face n backfires when i need the power i have a 97 chevy with the 350 vortec
Check your firing order,check primary wiring,check your coil,and set the timing,make sure you unplug single wire lockated behind relay cover on firewall when seting the timing.
Mar 22, 2011 | Chevrolet C1500 Cars & Trucks
New coil being fitted on husqvarna 136 forgot gap seting
The air gap should be set at 0.3mm.
Regards.
Mar 10, 2011 | Husqvarna Garden
How do you adjust focus on proscan tv
[1] change CRT base socket with New.
[2] set Focus preeset to seting focus adjest but she is Dengerus becous inside tv very high voltage in on coundition so Seting with nr. thech.
[3] your tv set is sum 5 to 10 year old if posibul your tv tube is week.but "don' t vary" "recharge tube cathod " and posibbal tube is ok .
if not
then
Replace tube with New.
" do not repar or replace spare in tv it your self .
Oct 31, 2009 | Proscan PS35130 TV
My Motherboard running but no beep no display of bios how can I solve the problem
refix your ram after clean it.also reset your bios setings .put your cmos cell for 15 minutes away from other bord.
also u can reset your bios setings with jumper setings.it is nearly cmos cell or corner of the motherbord put in 1-2 position then power up the cpu then refix again to its original position.
Dec 29, 2008 | Intel D946GZIS Motherboard
I reset the factory setting on my sony ericsson k850i. and now when i want to connect to the internet it says "connection failure"
you need to send new internet settings to your phone. reseting your phone removed the original setings. if it doesnt work, master reset your phone (deep reset) then send new setings to your phone again
Jun 12, 2008 | Cell Phones
Configuration setting does not save
make the changes on the printer,
save the changes (press twice on setup button).
chek if the driver have "use driver setings"
if you want to use the setings from the printer, you need to change the "use drivers setings" to "use printer setings ( this is to change on the driver)
Apr 10, 2008 | Zebra Z4M Printer
Garden Logo
90 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
