Question about Fisher and Paykel Fisher & Paykel Washer
A F&P GW 612 that has the "lid lock" light on, even when the lid is unlocked. Turning the machine on - the display lights up nomally, but on pressing the start/pause button the "lid lock" light comes on, the machine refusing to start.
ngfam1
  • 639 Answers
SOURCE: gw11 fisher & Paykel
Peace
ngfam1 at you service,
It sounds like it may be a faulty lid or door sensor!
A&E Factory service is nation wide and only charges $75 service call in my area!. (NJ)
They are available 24/7 to set appointments!
Bless You,
Please give me a good rating befor e you sign off of fixya.com
Posted on Sep 02, 2008
greg_margo
  • 1959 Answers
SOURCE: Our washing machine was stopping at various stages
Although the machine itself is balanced, it sounds like the drum isn't. Since it's not held in place with belts, it has a tendency to float some and on occasion, it will become unbalanced. You will notice it more often on lighter loads than heavy because the extra weight of the clothes is enough to seat the drum well enough to run. It's the lighter loads when you will notice an issue. What I've done is to physically lift the drum slightly and shake it around in all directions. After letting it come to a rest in the center, it should balance and run correctly for all loads.
Posted on Oct 26, 2009
  • 343 Answers
SOURCE: MW511 top loader washing machine.
The third and fourth lights from the left indicate a failed motor controller (error code 48) If this is the correct fault code you will have to replace the motor controller. However before that is done all the electrical components which can effect the controller must be checked as well...Best to call a tech...Good luck Nomess
Posted on Jul 02, 2010
  • 713 Answers
SOURCE: MW512AU Fisher and Paykel top load smart touch
Hi Des, just read your posting.Now when you turn on the machine you say that some lights light up and it starts to beep.These lights will be in a row of 8 lights.Starting from left to right which lights are lit when the machine is beeping?Is it he 3rd and 5th or the 2nd and 7th ---etc---?Please reply with additional information on the question and I can help you rectify the fault.Looking forward to your reply.
Posted on Aug 18, 2010
  • 713 Answers
SOURCE: Hi I have a gw612
Hi just read your posting.Starting from the left to right if the lights that are on when the machine is beeping are the 3rd and 4th and 8th then the error code is called COLD VALVE FAULTY.This means either your cold water valve is faulty or you control module is faulty.Would you like me to guide you in the testing and isolating the fault and replacing the faulty component?Please reply for further help.Looking forward to your reply.
Posted on Oct 12, 2010
The lid of my toshiba aw-1190s top loading washing machine would not open what could be the problem
Sounds like it has been locked. Is the power on it on or off? It will lock the lid, as shown by a red light (normally). Switch the power off, and it should unlock. If not, unplug it and it should unlock itself. If it does not do that, it may be that the lock is engaged and the mechanism damaged. Let us know what you find out after turning the power off, or unplugging it.
Sep 10, 2017 | Washing Machines
I have a whirlpool cabrio and the lid will not lock the light keeps flashing and it keeps making the lock clicking sound
BEFORE ASSUMING THE LID SWITCH NEEDS REPLACEMENT TEST WITH A METER, BUT FIRST TRY TO RESET CONTROL BOARD EVEN RUNNING A DIAGNOSTIC TEST WILL REVEAL THE SOURCE OF THE ERROR.. 1. Be sure the washer is in standby mode (plugged in with all indicators off; or with only the Clothes Clean or Done indicator on). 2. Select any one button (except POWER, START, STOP, and PAUSE/CANCEL) and follow the steps below, using the same button: a. Press/hold 3 seconds. b. Release for 3 seconds. c. Press/hold 3 seconds. d. Release for 3 seconds. e. Press/hold 3 seconds. ? If this test mode has been entered successfully, all indicators on the console are illuminated for 5 seconds with 88 showing in the Estimated Time Remaining two-digit display. ? If indicators do not display as described above, the press/hold/release procedure above may not have been performed within the time frame necessary for successful entry. Repeat step 2 to ensure this was not the cause. If still unsuccessful, see Diagnostic: Unsuccessful Entry, at right. 3. The test sequence continues by checking for saved fault codes: ? If there are saved fault codes, see Diagnostic: Saved Fault Codes, page 2. ? If there are no saved fault codes, all indicators on the console will momentarily turn off, then turn back on with 88 displayed. After 5 seconds, the Automatic test, below, begins.
http://www.applianceaid.com/pdf/Whirlpool-Cabrio-Waher-WTW6600SB3-Tech-Sheet-W10026634.pdf
TEST #8 Lid Lock Perform the following checks if washer fails to lock (or unlock). 1. Perform Manual: Lid Switch and Manual: Lid Lock tests on page 2. 2. Remove the console to access the machine/motor control assembly. See Accessing & Removing the Electronic Assemblies, at right. 3. Visually check that the P12 connector is inserted all the way into the machine/motor control. ? If visual check passes, go to step 4. ? If visual check fails, reconnect P4 and repeat step 1. 4. Check the lid lock motor winding and switches by removing P12 from the machine/motor control and checking the resistance values shown in the following Lid Lock Resistance table:
TO RESET TURN KNOB 1 FULL TURN COUNTERCLOCKWISE, THEN 3 TURNS OR CLICKS CLOCKWISE, 1 TURN COUNTER CLOCKWISE, 1 MORE TURN CLOCKWISE, THEN HIT START , ALL THE INDICATOR LIGHTS SHOULD THEN LIGHT UP, THEN UNPLUG FROM THE WALL FOR 5 MINUTES THEN PLUG BACK IN , IT SHOULD BE RESET AFTER PLUGGING BACK IN
Feb 11, 2017 | Whirlpool Washing Machines
Just replaced bearings and seal in GW 612 fisher and paykel washing machine and now wont spin and lid doesnt lock
if the bowl is stilf to turn when stator cover is off by hand, remove agitator give the end of the shaft a hit with a hammer and punch and the same thing at the other end of the shaft to free it once stator cover is removed assemble and try again
Jun 03, 2015 | Fisher and Paykel Washing Machines
GW 612 Fiaher Paykel wont complete drain or spin cycle
Do you get any errors on the display lights?
Dec 03, 2012 | Washing Machines
OP display light comes on when hitting start. Then hit off & in a minute it comes on?
Most times this issue is caused by loss of signaling thru the Left Hand Lid Lock.
1st check for a Lid Magnet out of position. This is an easy check if you have a couple key holder magnets or a similar magnet that you can place over the Left side grey lid bumper. Let's see if you can close the Magnetic Reed Relay switch with an external magnet and send +12VDC up to the Control Board and clear the "OP" error code.
If that doesn't clear the "OP" error code we will need to remove the Left Hand Lid Lock and check to see if corrosion is part of the issue. Because of its proximity to that nasty bleach dispenser it will cause issues. Here is the lid lock to order.
Here is a picture of a bad lid lock.
Nov 22, 2012 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore Elite Oasis HE Washer #27087. Doing a load of wash & wash & lock lid were flashing. Could not unlock lid & panel kept flashing. Unplugged cord for 30 minutes. When I plugged back in...
I would think the lid would unlock once you unplugged the machine. Check your owner's manual for any kind of "emergency reset" procedure. Perhaps the lock mechanism is jammed. Have you tried pressing on the lid or tapping it to see if that frees the lock?
Nov 18, 2017 | Kenmore Elite Oasis 27052 Top Load Washer
How do i manually release the rear door on a ssab 9-3 2003 as the door module has failed
Trunk Lock After Closing
Desc.: What happens to the trunk lock when closing it.
Settings:
Yes: Automatically lock Boot on closing
No: Boot can be reopened using micro switch button located on the trunk/boot
* Trunk Lock After Drive Off
Desc.: Should the trunk be locked at drive off or after 30 sec.?
Settings:
Yes: Trunk/Boot will automatically lock when vehicle increases speed
No: Trunk/Boot will remain closed, however will be in the unlocked
condition if No was selected in the previous option.
* Door & Trunk Unlock at Key Out
Desc.: When the is removed from the center console should door/trunk
be unlocked?
Settings:
Yes: All Doors & Trunk/Boot will Unlock when the Key is removed from
the Ignition Switch If Driver frequently locked all Doors when
driving
this feature would be beneficial.
No: Doors and Boot will remain in the same condition as they were
prior
to Key removal
* TSL Locking Logic (Theft Security Locking/Deadlock)
Settings:
TSL at first Press: Default Setting. All Doors will lock in Deadlock
Mode
TSL at Second Press: All Doors will lock in Deadlock mode at the second
press of the Remote.
* Lock /Unlock Acknowledge
Settings:
None : No acknowledge will be visible
Indicators: Indicators will blink as acknowledge
* Follow Me Home Function
Settings:
Tail Light: When selected Tail Lights will be illuminated
Back Up Light: When Selected Reverse Light will be activated
Tech 2 Body Exterior Lighting & Horn
* High Beam Follow me home Active Time
Desc.: Follow Me Home Active Time can be adjusted between 0- 10 minutes
Settings:
This Feature can be turned on or Off .Yes / No can be selected.
Low Beam Automatic / Low Beam also in Position 0 (light switch)
Yes / No
- Daytime Driving Lights can be activated
* Parking Lights
Settings:
Act as Lead Me To the Car Light.
* Park Light On Reminder
Settings:
On / Off
If Ignition is turned Off and the parking lights are active, Driver will
be warned if set to on.
* Show Trailer Light Outage
Desc.: REC will detect blown trailer light and display on SID
Settings:
Yes or No
* Trailer Light / Fog Light off
Settings:
Yes: Fog Light Rear will be disabled When Trailer is connected Yes
No
* Horn Lock Unlock Acknowledge
Settings:
On: Horn will honk when car is locked
Off: Horn will not honk if car is locked
Tech 2 Body Locking
* Panic Alarm Activation (Vehicles fitted with /Alarm only)
- Panic Button / Locking Switch
Central Locking Switch Driver /Passenger
Settings:
- Panic Button on Remote and locking switch inside vehicle will
activate alarm
- Panic Button will activate Alarm only
- Locking Switch inside vehicle (driver /passenger will activate
alarm only
- No Panic Alarm function required.
* Unlock Logic
Settings:
All at first press : All Doors will open & Fuel Lid will unlock if the
Driver or Passenger Door Switch is activated
Driver Door & Fuel Lid at first press : Only the drivers Door will unlock
& Fuel Lid will unlock when door
switch is activated
* Remote unlocking One Press
Settings:
All at first press: All Doors will open & Fuel Lid will unlock if the
Remote is pressed
Driver door & Fuel Lid at first press: Only the drivers Door will unlock &
Fuel Lid will unlock when the Remote
is pressed
Dec 17, 2010 | 2003 Saab 9-3
Washer displaying du code with 3 quick beeps
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
Door Unlock Error
A Door Unlock Error occurs if the door cannot be unlocked.
It will try to unlock the door 6 times before displaying the error.
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
If it is a cabrio:
dU flashes if the following conditions occur:
Excessive force on door lid is preventing lock bolt from retracting.
Wash media buildup is preventing lock bolt from retracting.
Machine/motor control cannot determine if door lid is in an unlocked state.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
TEST #8 Door Lid Lock
1. Perform Manual: Door Switch and Manual: Door Lid Lock tests.
2. Remove the console to access the machine/ motor control assembly. See Accessing & Removing the Electronic Assemblies.
3. Visually check that the P12 connector is inserted all the way into the machine/motor control. If visual check passes, go to step 4. If visual check fails, reconnect P4 and repeat step 1.
4. Check the lid lock motor winding and switches by removing P12 from the machine/ motor control and checking the
resistance values....
Component/Resistance Unlocked/Resistance Locked/Contacts Measured/Contacts Measured:
Motor Winding/35 ±5 O/35 ±5 O/P12-2/P12-3/
Lock Switch - Home/0 O/Open Circuit/P12-1/P12-4
Lock Switch - Lock/Open Circuit/0 O/P12-1/P12-7
Lock Switch - Lid/Lid Closed = 0 OLid Open = Open Circuit/Lid Closed = 0 O Lid Open = Open Circuit/P12-1/P12-5
If resistance values are good, go to step 5. If switch measurements do not match the values shown in the table for unlocked (or locked) conditions, a problem
exists in the door lid lock. Replace the door lid lock.
5. If the Manual: Door Switch or Manual: Door Lid Lock in step 1 failed, then the machine/motor control has failed: Unplug washer or disconnect power.
Replace machine/motor control assembly. Perform the Manual: Door Switch and Manual: Door Lid Lock in step 1 to verify repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Aug 04, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Gw 612 washes ,drains wont spin fault comes up as on off off off on
Hi just read your posting.Now the problem you might have, and I have had before, is the motor is not turning the bowl far enough when it is starting to spin and therefore the machine thinks the bowl is not turning.To get your machine spinning 1st undo the 2 screws under the lid so you can lift the hob up to see the bowl.Select a spin cycle and hit start while you are holding the hob up enough to see the bowl.The reason for lifting the hob instead of the lid to see the bowl is if you lifted the lid the machine would not work because of the lid switch.Now when you are holding the hob up to see the bowl make sure the lid is closed so the machine will work.Now once you have started the spin cycle you will see the bowl turning one way then reverse and turn the other way.While you are holding the hob up when the bowl turns in 1 direction help turn the bowl in that same direction with your hand.Once the bowl reverses help turning it in that direction also.This will make the machine register that the bowl is loose enough and will kick to spin.Once it is spinning let it spin for the cycle and you should be fine.Please reply for further help if needed,Good luck
Jun 16, 2010 | Washing Machines
Washing Machines Logo
29 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
