Question about Honeywell HZ2110 Utility Heater
Honeywell hz-2110 heaters. it works for about 3 min then the fan shuts off but the lights are all on. i have two of these and they both do the same thing. i paid 50 for each of them. what is the probl
They both work for a couple of minutes and then the fan shuts off
  • paydelady
    paydelady Jan 14, 2013
    took it apart and vacumned it out and it works fine now. went around the whole house and did that to everyone (i had two more that did this also) and they all work. thanks to all, don't know what this single lady would do without ya'll much love and Happy New Years!!
  • 4 Answers
SOURCE: Honeywell Compact Quick Heat Ceramic heater with tilt feature - HZ 325
Your prob is their is a thermostatic solinode that is trigger the unit to go off--because it thinks itself as too hot and unsafe to be on--this trigger was defective or damaged by disuse and/or fatigue------give it a shake-- better yet, when cool and unplugged-vacuum or blow out with compressed air-with out disturbing integrity of workmanship on device--if that no worky--time for new one---thermostatic element is dirty, device being of differing Mghz than outlet, if fairly new device--amperage of outlet is too small for device to work properly. If it is a 240 volt or a 120 volt device and your attempiting to use the wrong voltage outlet--STOP USING THE DEVICE
Posted on Jan 21, 2008
SOURCE: Honeywell HZ-709 Oil Filled Radiator
Problem: firs let's identify the problem, there is a sensor on the inside panel, made originally for safety if you tipped the heater off, it kill the power causing it to turn off...after a year of so that sensor get a little rusty/dirty causing it not to work correctly...
let's find out how to fix that annoying turn off..
tool needed, a phillip screw driver.. electrical tape or soldering unit..
fixing it: take out the top and bottom screws, to open the panel. after you open the panel you'll see a metal bar screwed to the front controller...take all 6 screws out...the front panel comes off....then there is about 4 screws holding an inner box, open that up..
inside there, you;ll see lots of wires...look for 2 small blue wire running together to a black sensor that make noise everytime you move it....
disabling the sensor
2 ways you can do this..
-you can cut the wire off using a scissor, and connect the blue wires together, use the tape to tape them.
or
- you can solder them together on the back of sensor panel...
there you go problem solved...
Posted on Mar 25, 2008
Roger NB Jr
SOURCE: Instruction Manual for HZ-705
HZ 709 This model# is the closet we'll are gonna get unless I can find my manual and get it scanned. Scroll down to page 4.These instructions will give you a basic idea how this heater works. Good Luck :-) http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/oil-filled-heaters.pdf
Posted on Nov 22, 2008
  • 36 Answers
SOURCE: Hi, Honeywell (HZ-341BL) Ceramic Heater stopped
when most ceramic room heaters stop working, the blower is clogged with lint and dust from floor use . get an air compressor, or a can of air. take unit outside using a small head philips driver remove screws while laying on an old sheet .disassemble cover carefully and blow dust away from you and clean blade without bending with a toothbrush in vinegar water not gettting any liquid on the electrical parts. reassemble. thanks karl
Posted on Dec 14, 2009
  • 408 Answers
SOURCE: how do you set heater to work?
That is the manual you need. Hope it helps. If you need anything else, let me know.
Posted on Feb 20, 2010
Model hz709 manual
Was there any physical damage to the heater when it fell over?
The HZ-709 has safety features that might prevent its subsequent operation.
1 - It has a tip over switch but the heater should operate normally when it's upright again.
2 - A thermal cut-off fuse will permanently shut down the heater should it operate at a higher than normal temperature. Was it operating when it fell over, or could it have overheated?
If it's none of those, try contacting the manufacturer Kaz directly by email, Facebook, Twitter, etc. as the HZ-709 has a 3-year warranty.
Digital Electric Radiator HZ 709
Jan 31, 2014 | Honeywell HZ-709 Oil Filled Radiator...
My Honeywell HZ 709 WMT stopped working. I've had it for about a year now and has been great up to this point. Any ideas?
I am having the same problem. I am not sure the cause but I was reading that some manufacturers will put automatic shut off switches in the electronics. I read that it was mainly printers and faxes but I wonder if that could hold true here as well?
Oct 10, 2012 | Honeywell HZ-709 Oil Filled Radiator...
Fan heater works for awhile then shuts down seems like the stat
bypass the thermostat by wiring past it if unit stays on that is the problem.
Oct 22, 2010 | Honeywell Pro HZ-2120 Heater
How do you set heater to work? I have no manual for this heater it is Honeywell HZ-709 Oil Filled Radiator Heater After I turn it on How do I turn it on and set it to work?
Dec 29, 2009 | Honeywell HZ-709 Oil Filled Radiator...
Honeywell HZ-709 oil filled radiator heater-all controlls work but no heat produced. Possible reason?? Thanks
There is a bottom element and a top element so the elements could be dead.
More likey, there could be no power coming from the wall - there are switches on the front that need to light up or the thermostat could be set to off.
Dec 07, 2009 | Honeywell HZ-709 Oil Filled Radiator...
How do I program my Honeywell HZ-709 radiator heater
Is there a seperate control for the timer and temp? If so, turn the temp off first and then the timer.I think they need each other for safety.
Oct 30, 2009 | Honeywell HZ-709 Oil Filled Radiator...
Honeywell heater turns off after 3 min. Never comes back on
It sounds like the temperature sensor has either failed or come loose and is sitting too close to the heating coil. Alternatively, the level-sensor, which shuts off the heater when it is tilted, may be malfunctioning.
If the heater is not sitting level, it will also shut itself off.
In any case, if it is under warranty, return to the manufacturer. If it isn't, a local appliance repair shop should be able to isolate the problem.
Oct 06, 2009 | Honeywell Surround HZ2200 / HZ2204 /...
Diagnosing a short cycling honeywell HZ-510 heater
Here is a link to manual and trouble shooting guide. Also service numbers and e-mail contacts. Hope this helps, Thanks and let me know,
Sea Breeze
http://homeappliance.manualsonline.com/manuals/mfg/honeywell/hz510.html
Feb 01, 2009 | Honeywell HZ-510MP Ceramic Heater
Jan 02, 2008 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Honeywell HZ2110 Utility Heater Logo
87 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
