Question about Health & Beauty
STRIDER MN4 MOBILITY SCOOTER KEEPS STOPPING
MY MOBILITY SCOOTER HAS BEEN WORKING FINE UNTIL THE LAST COUPLE OF WEEKS. WHEN IT HAS DECIDED TO STOP FOR NO APPARANT REASON AND ALSO FEELS SLUGISH WHEN ON THE MOVE. BUT WHEN I SWITCH I T OF THEN ON AGAIN IT WILL GO THE BATTRIES ARE 3 YR OLD AND USED EVERYDAY AND CHARGED EVERYDAY COULD IT BE THIS, AND IS IT A GOOD IDEA TO CHANGE THE FUSES JUST AS A PRECAUTION the warning light on the dash on the scooter are flashing continuous when i go up a hill or on the grass...
    Scholar:
  • 61 Answers
Hi. From your description of problems, it sound very likely that your batteries are at fault. There could be other problems causing the above symptoms, but I would definately start by getting the batteries checked at a shop with a PC based battery testing facility. If the batteries pass this test, I would be looking at Brake, Motor or Transaxle problems, as these will all draw from your batteries if not opperating correctly. I would not change any fuses, as these will be fine unless blown. Hope this helps.
Posted on Jan 07, 2013
4 Suggested Answers
gewiz
  • 1263 Answers
SOURCE: no drive,flashing green light
Are you sure the FREELEVER is in the right position ? , to test try to push the scooter ?
Battery Low ?
Posted on Jun 13, 2009
  • 6 Answers
SOURCE: Old BEC Stirling 4. just stopped!
There will definitely be a fuse or thermal cut-out (or two) for the batteries, but those must be OK. Double check wiring to the motor? Was motor or controller very hot?
Posted on Sep 09, 2009
  • 61 Answers
SOURCE: I have a ctm scooter the battries are charged
I would say the throttle pot is slightly out of neutral allowing the scooter to travel slightly when turned on. Try moving the throttle lever slightly in the opposite direction to which the scooter is travelling (i.e. if the scooter moves forward when turned on, press the lever to go backwards, but only a small amount). If the scooter stops and you hear a clicking noise from the back of the scooter (this would be the brake clicking on) then that would be your problem. Would just need a small adjustment but best left to a dealer as it has to be sopt on! Sometimes scooters will not work if the throttle is slightly out but if its only a very small amount out of neutral, it might sometimes work in the manner you have suggested. We have come accross this fault on a few occasions. Hope this helps...
Posted on Mar 19, 2010
What batteries should I have in my dam strider mn4
same kind as are in it already usually .open the battery cover and look
Jul 27, 2015 | Health & Beauty
Problem with days strider mn4 mobility scooter
hi, you mention everything but the charger , please bear in mind a poor charger will result in poor batteries thus the problems you describe.
The brake in question could also pose a problem , firstly if possible get the rear wheels off the ground , now apply a slight forward movement on the throttle lever until you hear the click , okay that the brake releasing now try to move the wheels around , do they move freely yes then the brake releasing okay, you will some help to do this .
Regards
Jan 13, 2013 | Health & Beauty
Days Strider Midi 4 Plus faults
HOW DO GET THE REAR WHEEL OFF MY SCOOTER NUT VERY TIGHT
Jul 10, 2012 | Electric Mobility Mobility Electric Power...
Hi my days strider midi4 keeps going in reverse for about 4 seconds after you take the throttle off
spares sounds like the throttle pot is not being centered upon release making the scooter move in reverse or forward depending on which way it is off center. try pushing on the thottle lever slowly forward when you stop to see if that stops the creeping. Then you can try to adjust the pot by loosening the lever and retightening it in the forward direction that stops the creeping. You might have to order a new throttle pot assembly to get this working right. Hope this helps
Nov 18, 2010 | Electric Strider Midi 4 Wheel Mobility...
When I stop the scooter after travelling a short
Hi. Yes, most, but not all machines have a "sleep" mode. More for safety than any other reason. Neil .
Oct 31, 2009 | Electric Strider Maxi 4 Wheel Mobility...
Maxi strider scooter
Hi
Are you sure it 's the cable ? and not the wig wam or throttle speed pot that you operate with your thrumbs.
Regards
GeWiz.
May 03, 2009 | Electric Strider Maxi 4 Wheel Mobility...
Strider chair starts and stops
Troubleshooting for this model is now available at
http://www.striderscooterservice.com/blink-codes.html
Dec 15, 2008 | Electric Strider Midi 4 Wheel Mobility...
My wifes strider chair runs a bit the stops. Then she turns off the key, turns it back on and it runs a little bit a stops. The green light stays steady until it stops then blinks..any help?
Ztarg is the Medline Industries approved service and parts distributor for the Strider and Gemini Scooters.
Their contact information can be found on their website www.striderscooterservice.com
Health & Beauty Logo
171 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
