Question about Video Cameras
Will software for windows 7 work on windows 8
    New Friend:
  • 3 Answers
Yes most software and hardware that worked with Windows 7 will work with Windows 8, I would just install it and see if it works.
Posted on Jan 31, 2013
Can I use alohabob to go from Windowsxp to Windows 10
You might be able to move specific applications or software from a Windows XP computer to a Windows 10 computer, using that software. But you cannot go from Windows XP to 10 on the same computer. The hardware of the Windows XP machine, unless you downgraded the OS from Windows 7 or 8 to XP, was NOT designed to work with a operating system higher than XP. You can only upgraded a Windows 7 or 8 computer to Windows 10 (not that you would want to as the Windows 10 system is useless junk).
One of the reason that Microsoft offered the Windows 10 free was that people using 7 would not ditch their old computers to buy a new one fitted with windows 10. However to get around the problem of not having new hardware. They had to fudge and bodge the Windows 10 software to make it work on hardware designed for Windows 7.
So basically it's rubbish because corners were cut.
May 15, 2016 | Computers & Internet
Drivers do not work for win 8
From windows 7 up no older drivers will work.
Mar 16, 2017 | Computers & Internet
Camasia 8 Recorder won't work on Windows 7
Delete 7 and 8 but then only reinstall 8 and see if that works because they might be screwing with each other.
Mar 18, 2014 | TechSmith Camtasia Studio for PC
I can't get mynew computer to accept windows xp
Ok so im a little confused.. You have windows 8, windows 7 and xp on your computer??
Did you install the xp os correctly?
Nov 30, 2013 | Belkin Components Belkin Easy Transfer...
Voyetra midi orchestrator
The only Voyetra Midi Orchestra Plus software I can know was written for Windows 3.1 and Windows 95. Thus there are several reasons for it to be incompatible with Windows 8. First, it was a 16-bit software; the most common Windows 8 installs use a 64-bit OS. This means that the OS has undergone a number of major changes. The installers are completely different (format/way of talking to the OS). The DLLs that communicate between the software and the OS have also changed. The drivers for MIDI devices will be totally different in the modern OS.
The documentation for Voyetra Midi Orchestra is available here: . It is a discontinued product and no one at the company that owns it will be writing a new version of the code for Windows 8. I'm not sure this software will work in Windows 7 32-bit. You might be able to use the software in a compatibility mode from a virtual version of XP. For Windows 7 Pro, Virtual PC and the XP mode package are available as free downloads and can be used if your hardware allows. Windows 8 Pro has Hyper-V but requires a licensed version of any Windows OS that you want to use. For non-pro versions of Windows software, you would need to buy a Pro upgrade. The alternative is to obtain another Virtual machine software (VMWare, for example) and a licensed copy of XP or an older version of Windows. (OEM Windows 7 Pro licenses are still available from many computer hardware vendors.)
I hope this helps.
(Many 32-bit device drivers don't work under Windows 8; older software that didn't run under Windows 7 have similar problems.)
Nov 29, 2013 | Yamaha Music
The CD -rom not compatible with windows 8. it works on windows 95
Between Win95 and Windows 8 there are several other versions Win 98, Win 2000, Win XP, Vista, and Windows 7. Try to run the CD in compatibility mode. If it does not work you will have to forgo the use of that software or run it on an old machine, or upgrade to a version compatible with Windows 8 if one such upgrade exists.
Aug 31, 2013 | Expert Software Computers & Internet
Could this printerwork with window 7?
Lexmark P3150 works fine with windows 7 and even with windows 8. I verified that by visiting Lexmark's support center. You can also check that by visiting LEXMARK ..
By the way, if you want to optimize the performance of your computer then I suggest that you install a technician software called RadarSync. It is a good maintenance software for computers running in Windows 7 and even with Windows 8. What it does is it maintains and updates basic drivers inside your computer. You don't need to do anything at all. The software will do them for you - maintain and update.
I hope this helps.
Thank you.
Nov 22, 2012 | Lexmark P3150 All-In-One InkJet Printer
Give me key for windows 7 ultimate
you might be given it if you ask nicely
Jan 30, 2011 | Microsoft Windows 7 Ultimate for PC
Can you put American greeting 8 on to windows 7 ?
The website / Microsoft site does not have any information if this software will work with Windows 7 / Vista, hence it would be a better idea to try installing it and see it it works. If it does not work with windows 7, windows 7 has a very good feature called XP mode to use old software and hardware which are compatible with XP but not with windows 7.
Please check the link below for details of what is XP mode in Windows 7
Please check the link below for details of how to use XP mode in Windows 7
Dec 30, 2010 | Broderbund American Greetings Creatacard...
I use MGI photosuite and love it. I just bought a
Windows 7 and 8 much the same (32 and 64 bit) you may missing files for Internet Explorer.
Just today I was able to get PhotoSuite 4 to work in Windows 8. PhotoSuite 4 (P.S. 4) is dependent upon Internet Explorer 5 (I.E. 5) browser for its content/software to work. The original P.S. 4 CD has
I.E. 5 installer, I tried to install and the install quit with a check box to force install of all components. Internet Explorer 10 for Windows 8 was not affected in any way, that's how I got back here anyway.
I have read ton's of suggestions and one mentioned I.E. Browser dependency and walla it was the answer that took me ten minutes to get it up and running.
Jun 25, 2010 | MGI Software PhotoSuite SE V4.0
Video Cameras Logo
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
