Question about IBM ThinkPad X41 Notebook
How to enter boot menu on IBM thinkpad x41? I am trying to start with usb
I am almost sure I will need a new hard drive but I wanted to attempt this first........
    Habit-Forming:
    Scholar:
  • 69 Answers
Restart your computer with the USB drive connected, and press the blue "Access IBM" button on your keypad. Select "Startup Utility" and go to "Boot Order." Change "USB Device" to "Primary," save changes and exit. When your system reboots, it should boot from the USB drive.
Posted on Dec 30, 2012
dante777
  • 623 Answers
SOURCE: How can I boot from USB in a Thinkpad T22?
I assume with "boot menu" you mean the BIOS boot menu (the one you get to if you press F12 during start up, before the Windows screen appears.)
  1. Go to "Enter Setup"
  2. Go to "Config", click "Enter"
  3. Go down to "USB", click "Enter"
  4. Make sure that "USB Bios Support" is enabled.
  5. (Hit "Enter" again and choose between "enabled" and "disabled")
  6. Hit "Esc" twice to go back to the main page.
  7. Go down to "Startup", click "Enter"
  8. Choose "Boot"
  9. Check if "USB CD" is in the list of boot options or excluded form booting.
  10. Hit F10, confirm any changes you made (click "Enter" for 'yes') and reboot.
  11. Tap or hold down F12 again and you should see the boot option menu again.
Note: I am not 100% sure if you can boot from a DVD externally.
I booted from the internal DVD drive fine with a Linux LiveCD. It is possible that the T22 BIOS does not support external booting. Check you version - the latest release from IBM is version 16ET32WW (1.12), release date 06/03/2004. You find that info here.
I would really appreciate if you could come back here and leave a comment, so I (and maybe others?) can learn form this ;-)
Posted on Feb 13, 2009
myob247
  • 1342 Answers
SOURCE: IBM ThinkPad T20 - Won't boot windows
Click HERE for info on IBM passwords
Posted on May 24, 2008
  • 3 Answers
SOURCE: Any touch will freeze my laptop IBM Thinkpad T42
There is a common problem with this machine; the mother board flexes and the processor mount partly separates from the motherboad. You tube posts a couple of solutions but they involve taking the laptop apart and applying heat from a heat gun to resolder the mount; it is not a solution for the faint hearted. Thinkpad/Lenovo might consider reparing the unit as it is basically a desgn/production defect but don't hold your breath.
Posted on May 29, 2008
Pyrhyc
  • 2028 Answers
SOURCE: Stuck at IBM Thinkpad Splash Screen
Sound like a memory chip has failed. Try removing the memory, I believe these have on board, but not sure. If it doesn't have on board, you will need at least one chip in. If the problem is still there, try removing the CD drive, occasionally they can cause a no start. If it's not the memory or the CD drive, then try a bios flash. You will need to create a bootable disc from IBM's support site using a different machine (obviously).
If the bios flash doesn't fix it, them the problem will lie with the motherboard.
Posted on Jun 27, 2008
  • 45 Answers
SOURCE: IBM ThinkPad R40 Intel Centrino Upgrade to Intel Core 2 Duo?
No, your motherboard does not support the Core 2 Duo family.
Posted on Feb 03, 2009
How can i boot with system recovery disc when I dont have a cd slot on this IBM x41?
Try putting on a flash drive on another computer but just copy,do not activate or run, or borrow an external CD drive .
Dec 30, 2012 | IBM ThinkPad X41 Notebook
Are all hard drives the same in size? I mean can I take a hard drive 36 GB and put it in a IBM Lenovo ThinkPad X41?
Laptops hard drives have the same physical size but they maybe use IDE/PATA or SATA data connections.
This WEB site has the specs of this model Thinkpad.
www.notebookreview.com/default.asp?newsID=2362
Dec 29, 2012 | IBM Lenovo ThinkPad X41 Motherboard...
Ibm x41 will not boot says boot overload
Have you tried booting in Safe Mode?
Turn off the computer, then hit the power button to turn itback on and immediately start hitting the F8 key repeatedly until you see SAFEMODE. Take the Safe Mode option and let it boot up. Safe Mode will lookdifferent to you, the screen will be darker and the icons bigger, this isnormal.
Apr 09, 2012 | IBM ThinkPad X41 Notebook
Forgot username and password for IBM thinkpad x41
Back up your most important data to an external storage device in case anything goes wrong while changing the BIOS settings. Remove any disc that is currently inserted in the IBM Thinkpad X41's disc drive.
2-Shut off the Thinkpad X41 laptop. Turn the laptop back on and wait for the "To interrupt normal startup, press the blue Access IBM button" message to appear on the screen.
3-Tap the blue Access IBM button at the top of the keyboard. Click the "Access BIOS" button when the "Rescue and Recovery" menu appears.
4-Click "Yes" and wait for the BIOS to load. Type in the current BIOS password for the IBM X41 and press Enter.5-Navigate over to the IBM's "Security" heading by tapping the right arrow key twice. Scroll down to the "Supervisor Password" listing and press "F5."6-Type the IBM's current BIOS password and hit Enter. Leave the next field blank if you want to completely remove the BIOS password, or instead type in a new password to replace the old one. Press Enter.7-Press "Escape" and then highlight "Restart" and press F5. Navigate to "Save changes and Restart" and press Enter.
  • Nov 05, 2011 | IBM ThinkPad X41 Tablet PC
    IBM Thinkpad x41 tablet does not go past the ibm boot logo at startup. BIOS does not open or any of the other options at startup. What should i do ?
    If you have the machine on a dock of any sort, remove it from the dock.
    If that doesn't help, try taking out the hard drive. See:
    http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-54584
    for instructions.
    If you get past that screen, put the hard drive back in. If you're stuck in the same place, you may have a bad drive. If it boots. . .great!
    Feb 21, 2011 | IBM Lenovo ThinkPad X41 Motherboard...
    Access IBM no working, the computer freeze
    During the boot process you will see on the screen to press a certain key to enter setup
    Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
    once you have your computer running
    try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f this should schedule to happen on reboot which will scan for and attempt to recover bad sectors and automatically fix any corrupt files on your hard drive or
    click startcontrol panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
    do not do anything while the chkdsk utility is in progress any input will damage your computer
    then you should test or replace all leads make sure they are securely seated and are not bad/faulty that are attached to your (((motherboard to your hard drive))
    defragment your hard drive will speed up your computer
    scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have virus slowing your computer also select users you will see who is using your computer
    don
    Feb 02, 2011 | IBM Lenovo ThinkPad X41 Motherboard...
    IBM Thinkpad X41 wont turn on.
    change your RAM slot,or run it on single RAM.
    Nov 06, 2009 | IBM ThinkPad X41 Tablet PC
    XP Drivers for IBM ThinkPad x41
    FOR WINDOW DRIVER: WWW.WINDRIVERS.COM
    WWW.MRDRIVERS.COM
    WWW.MOTHERBOARDS.ORG/DRIVERS
    WWW.IBM.COM/THINKPADX41
    WWW.MICROSOFT.COM/DRIVERS IBM THINKPAD X41
    ENTER
    TYPE IN THE ADDRESS BAR:
    WINDOWS XP DRIVERS FOR IBM THINKPAD X41
    ENTER KEY
    CNANDYMANGANDY
    Feb 13, 2009 | IBM ThinkPad X41 Tablet PC
    8. Choose "Boot"
    Jan 30, 2009 | IBM ThinkPad T22 2647 Notebook
    Start up problem
    This generally indicates a hard drive failure. You can try to do an operating system repair with the recovery or operating system disc, but most likely you will need to replace the hard drive.
    When you see the IBM screen you need to enter the boot menu. On this screen it tells you what to press to get to the boot menu. Place the recovery or operating system disc in the drive, and select the CD drive from the boot menu, then follow the directions. If the repair doesn't work, then reformat the hard drive and install a new operating system. If you have any issues during or after the format or install, then the hard drive has failed and will need replaced. You want to do a full NTFS format, not the quick format, if the hard drive is bad, it won't format.
    Aug 08, 2008 | IBM ThinkPad T30 2366 Notebook
    IBM ThinkPad X41 Notebook Logo
    488 people viewed this question
    Top IBM Computers & Internet Experts
    Computer Links
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
