Question about Home Security
I need to re-program a 4 channel Henderson door remote
Please can anyone help. I need to re-program a remote for an electric garage door. It is a Sommer 4020 remote transmitter for a Henderson duo garage door. Many thanks
Could anyone tell me. Why there are 4 buttons? And what are the 4 functions programmed in to the remote? I have two doors and two remotes and are unsure how to program?
regards
Posted on Nov 11, 2015
Remove the unit cover and hold the learn button for precisely 2.5 seconds. Holding the remote approximately 12 centimetres away from the unit press buttons 1, 2, 3 then 4 for a duration of 2 seconds each with an exact 1 second interval. Then hold the learn button down until it flashes and repeat the previous step. Your remote is now programmed. You are welcome. Henry James Winterbottom.
Posted on Aug 26, 2014
  • 3197 Answers
SOURCE: I have Craftsman TX2028 remotes (139.53753) with
Make sure the green light in the wall control is not blinking. If it is, press and hold the 3 seconds the lock button.
Posted on Nov 29, 2010
blanchettohd
  • 143 Answers
SOURCE: I have a Merlin Powerlift-Model 2500L Garage door ...
This is a foreign design but here is what the instructions say to do.
Remove the light cover then remove the colored plastic rectangle strip located underneath. This will reveal a red Learn/Delete? button. 1. Push Learn/Delete button for 2 seconds the lamp will blink continuously to alert you that it is in Learn Mode. 2. Push the big button on your remote for 2 seconds 3.Push the little button on your remote for 2 seconds Minimum of 1 second is required between each action Your remote will now operate with your motor b) Overhead Doors Remove the coloured plastic rectangular strip located next to the Merlin label on the front of the motor. This will reveal a red Learn/Delete button. 1. Push Learn/Delete button for 2 seconds the lamp will blink continuously to alert you that it is in Learn Mode 2. Push the big button on your remote for 2 seconds 3. Push the little button on your remote for 2 seconds *Minimum of 1 second is required between each action Your remote will now operate your unit. Thanks BB
Posted on Sep 03, 2010
  • 3197 Answers
SOURCE: lift master 1021499A do not have
You need to get the correct model number which you should be able to find on the end closest to the door. Any door opener service company will be able to help you.
Posted on Aug 17, 2010
glenmann62
  • 91 Answers
SOURCE: programing garage door opener remote
ok crystal,calm down this is an easy one! first locate the smart button on your openers , next you will press and hold down the smart button until you see an indicator light above it shut off, while your holding that button the light will be solid ,Now your ready to program your remotes ,first programm one side by taking each of your four remotes and pressing the smart button on machine then pressing the button on the remote you want to program,by doing that you will notice the lightbulbs on your machine shut off and go back on , This is an indicator that your machine has accepted the code , now do it with the other three remotes , after you,ve programmed all four ,go over to the other machine and repeat the process but this time you have to choose another button on your remotes since you,ve programmed all four remotes to the same button on each remote ,just choose the bottom button on your remotes this time to keep them seperated , hope this helps you and it is as easy as 1-2-3 your owners manual will describe exactly the same ,i know because i,ve installed over 27,000 machines working as an installer for sears, please leave a nice feedback rating if i was able to help you, good luck,Sincerely Glenn Mayer
Posted on Apr 01, 2009
SOURCE: Garage door opener transmitter/receiver compatibility
Press and hold the homelink button and wait till the red light flashes slowly,but don't release it. Now hold a working remote 3 inches away,press the remote button and hold it.When the red Homelink buttom fllashes quickly, release both buttons. Now go to the opener and push the learn button. Now go back to your car and press and hold the Homelink button. You will see the lights on your opener flash. Now your Homelink button should operate your garage door.
Posted on Feb 09, 2009
Factory garage door opener
If this is the 3 button HomeLink Transmitter usually centered overhead above the rear-view mirror, this should work:
While the engine is turned off follow these steps to program up to three channels:
1. Decide which one of the 3 channels (one of the 3 HomeLink buttons) you want to program.
2. Press & hold the desired button through step 3.
3. When the HomeLink indicator light begins to blink slowly(this may take up to 30 seconds), hold your hand-held garage door remote about 1 to 3 inches away from the buttons & then press and hold the button on your garage door remote. Continue to hold both buttons until the indicator light on the HomeLink begins to flash rapidly(this may take up to 90 seconds).
If it still doesn't work, make sure the batteries in your garage remote are not weak, and try again moving the remote back & forth and left & right or turning it upside down while programming.
Also note HomeLink will not work with older garage door openers, especially not with ones manufactured before April 1st 1982.
Feb 18, 2010 | 2005 Buick Rendezvous
Liftmaster garage door openers Model # 3245 (remote Issue)
it is possible that when you programmed the car remotes you erased the pairing between your hand held remotes and the unit. Follow the instructions to pair the remotes again and you should be good to go.
Sep 16, 2009 | liftmaster Chamberlain Garage Door Opener...
I have 2 liftmaster 3245. The hand held remotes were working fine then stopped. I replaced the batteries and turned of all electrical/RIF close by. Still not working. Both cars operate the doors with no...
You need to reprogram the remotes by briefly pushing the learn button on the garage door opener until it flashes once, then release the button on the garage door opener.
Now press the remote button once until you hear the garage door opener click, now press the remote button once again and the remote should be programmed to work for that garage door opener.
DO NOT press and hold the garage door opener learn button for more than 10 seconds or you'll erase all programs and have to relearn all the remotes, including your car ones.
Hope you found this very helpful and best regards.
Aug 06, 2009 | liftmaster Chamberlain Garage Door Opener...
Just moved, no garage remote, need to set the opener in my SUV.
The garage door opener is needed to use the HomeLink system that is in your vehicle. This design is so that no one can program theirs to gain access to your garage. You will have to obtain a working remote and it will have to be programmed at the garage door.
Jul 13, 2009 | 2004 Nissan Maxima
Programming the garage door opener
I know what the problem is but never tried to resolve it. I have a 1998 XJ8 and went through the same problem. After numerous attempts to program the 4 channel built in opener I researched the problem and learned that the system in the car actually changes the code after every use. It's a security feature built in to the system. I simply started keeping my remote in the car.
There must be a way to disable the automatic randomizer so it retains the code from your remote opener everytime. Check with the dealer to see if it can be disabled and you will be in business. Please post the info if you get it.
Good Luck!
Nov 24, 2008 | 1998 Jaguar XJ8L
I do not have the owners manual for the 2007 grand caravan
  1. clear channels by holding the 1 & 3 buttons down for 10 secs.
  2. to program hold remote no more than 3" from console,press and hold remote button and button you want to program the message center will say channel training then channel trained release w/you see channel trained
  3. you may have to push train button on garage door opener and repeat step 2
  4. use step 3 only after 1&2 fail.
Nov 16, 2008 | 2007 Dodge Caravan SXT Minivan New Cars
Help w/ programing keypaqd along w/remotes
I press the learn button on the door motor. I wait a few seconds and press a new 4 digit code into the keypad, hold down on the "enter" button for several seconds so it learns the code. Now the remote will not work. Press the learn button again, press the button on the car remote until the light on the motor blinks. Both should work after that.
I have Sears LiftMaster products. Hope that helps.
Jul 20, 2008 | Sears Craftsman LiftMaster Chamberlain...
Programing garage door opener remote
Mar 12, 2008 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
961 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
