Question about Zanussi Washing Machines
Zanussi zwx 1605 w beeps 5 times and will noit work? any answers?
Having relocated the machine it now only beeps 5 times and will not work. The machine has been resting on its side over night.
SOURCE: Zanussi FX1465W aquacycle, beeps 5 times and end light flashes
I have the same trouble with my washing machine did you find a solution i have been told the PCB or motor drive system
Posted on Jun 16, 2007
SOURCE: zanussi zwx 1505w drum not
the drum kep on jamming.
i tuck the drun a part and found a sockjamed be tween wall drum
that solved the promen
Posted on Apr 30, 2008
  • 1462 Answers
SOURCE: Zanussi Front-Load Washer ZWX 1606
the soap box has holes in the tyop thro which the water comes. those over the rinse compartment may be blocked. clear with a paperclip
Posted on Aug 21, 2008
  • 274 Answers
SOURCE: i am needing to know
contact a place that sales washers and dryer they may be able to cross referance and get you a manual.
Posted on Aug 29, 2010
  • 6277 Answers
SOURCE: Essential 1600 washing machine -
(try this!)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 25, 2011
I am needing to know where i can get an english manual for a top loader zanussi zwx 5100 top loader washing machine
Aug 29, 2010 | Washing Machines
Zanussi washing machine is making five beeps and not workign - what does this mean? It is not in the manual
My Zanussi Fs1555w is not finishing it's cycle and beeping 7 times. If I put on spin the cycle lasts less than a minute before the end button beeps, then it will beep repetitively 7 times until turned off. Please help
Feb 05, 2010 | Zanussi FS1455W Front Load Washer
Our washing machine (Zanussi ZWF 1632 W) flashes 5 times
This is a motor problem the end light flashing 5 times indicates error E50. The motor has either got wet or has just failed i would suggest trying to dry it 1st but i would suspect the motor has gone down to earth usually having to replace it. The part no. DST1246179079 Motor aprox £195 but shop around you may find it cheeper.
Dec 11, 2008 | Zanussi ZWF1430W Front Load Washer
Fault on Zanussi FS1455W
why should i tell you how i solved the problem????? you want money off of me to tell me how to solver it, so shove off
Aug 28, 2008 | Zanussi FS1455W Front Load Washer
Zanussi zwx 1505w drum not spining
Apr 28, 2008 | Zanussi Washing Machines
May 19, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
71 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
