Question about Hydrofarm Flc0125d Fluorescent Grow Light System
Light wont start up
Will come on(not all the way) will shut off, after3-5 minutes it will try to come on again, after 1-2 minutes will shut off again. Left plugged in for about 1 hour never powered up to stay on it is 2003 model 175 watt
    President:
  • 1,990 Answers
You will have to Replace the Balast.
Posted on Jan 18, 2009
Security alarm wont shut off
Make sure all doors are closed, Key out for 3 minutes.
If that doesn't fix it, Try a battery disconnect for 3 minutes.
let me know what happens.
Mar 15, 2014 | 2000 GMC Jimmy
2002 vue v6...starts and runs well however when I stop , shut off the engine, then try to start after half hour , it wont start
Lookfor a light on the dash that says SECURITY or ANTITHEFT. If you see this light, that is a sign of a failed or failing antitheft system, which will disable your vehicle. This link explains
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Nov 06, 2011 | 2002 Saturn VUE
Works good for 2 minutes, Then shuts down & light goes red. Remote wont restart , so turn power off then on, Works again for 1 minute then shuts down. Panasonic PT-AE900U... projector
change the Bulb if that does not work it could be a power supply or power supply regulator this should be done by a professional except the Bulb
how many hours of operation does the unit have ??
Sep 21, 2009 | Office Equipment & Supplies
My car wont start
sounds like security shut down which will start run for second then shut down after several time the security will shut down completely.......you can try what is called the relearn proceedure..this is what you dealer will do...might have to put battery charger on car first... then put key in ignition and turn to the run position do not crank leave it in the on position for ten minutes...... then turn key to the off position then back to the run position again for another ten minutes.....for the last time turn key off then back to run for the last ten minute cycle.... after the final ten minutes is up turn key to off position then attempt to start... let me know
Aug 31, 2009 | 1997 Chevrolet Cavalier
1500 ram 2003 wont start red dot
REMOVE IOD (IGNTIION OFF DRAW)FUSE FROM FUSE BLOCK FOR 1-2 MINUTES,THEN REINSTALL..THIS DOT IS IMMOBILIZER SYSTEM..THIS SHOULD RESET SYSTEM..TRY STARTING VEHICLE..IF NOT,TRY ANOTHER IGNITION KEY AFTER RESETTING AGAIN..I HOPE THIS HELPS
Jul 29, 2009 | 2003 Dodge Ram Maxi
Chevy cavalier z24 theft system light on
This is a easy fix. Lucky just follow the procedure and your car will start. This is a theft system shut down.
The procedure is. Disconnect battery for a minimum of 30 seconds. ( one post is OK. )
Reconnect battery and get in the car and start as usual 1 time only. When it starts and stops letthe key just return to run position as if it was running. Do not shut it off and if you do you must stert the procedure all over again. i usually put on the emergency brake before i start and that shuts of the driving lights etc.
Just leave the key in on running position and go have a coffee. it takes 15 to 20 minutes for the car to recycle the system. When you come back to the car the flashing theft light will either be off or solid.
Try to start again. If it doesn't go shut it off and turn back on and start as usual. It will start and run and stay running.
The reason you have this problem is something electronic was disconnected whe the battery was hooked up. always disconnect the battery before you touch anything electronic and you will not have this problem.
Apr 03, 2009 | 1999 Chevrolet Cavalier
Hydrofarm Flc0125d Fluorescent Grow Light System Logo
172 people viewed this question
Top Hydrofarm Garden Experts
Colin Stickland
Colin Stickland
Ed Hauk
Ed Hauk
Level 1 Expert
Angelo Monroe
Angelo Monroe
Level 1 Expert
Are you a Hydrofarm Garden Expert? Answer questions, earn points and help others
