Which lopt can i use to replace BSC25-N0819
I CANT FIND THE LOPT
  • 556 Answers
SOURCE: jvc tv
check for fly back transformer
but remember that before you replace any thing in eht section check for power supply output to be ok.
also check for diodes,capacitor connected to flyback transfomer.
also check for mica sheet is not cracked or h/output is not touching to chassis.
good luck
Posted on Nov 02, 2007
crazy larry
  • 6 Answers
SOURCE: Bush TV Dead MODEL: 5693D
switch mode power supply? it has a in or primary side and out the secondary side of a switch mode transformer.
check the driver IC that runs Q102 it makes a oscillation that Q102 amplifies. now the secondary if has a short will blow the Q102 look for shorted rectifiers in the secondary and fuse resistors that are open, even go far downstream and check the HOT for short.
Posted on Feb 23, 2008
  • 556 Answers
SOURCE: tv dead
please check flyback transformer for short
good luck
SOURCE: error code thompson 32ws23u icc17 chassis
the unit is being over powered, by a faild component on the power board, i would suggest getting a new TV as replacong the LOPT does add up
Posted on Oct 20, 2008
gopakumarg43
  • 74136 Answers
SOURCE: I want a LOPT (Line
Hello
The service person who told you so is correct. EF series LOTs are of old National Kit, and is not available now. If you have a chance to get it from somewhere, it will cost more that RS 800/= ie about $18, and with that money you can purchase a new kit for your TV, provided your TVs picture tube is good. Just do as you like in this case. Todays TV kits are assemled and aligned, comes with more than 250 channels and includes all accecories, like remote handet, fitting material and so on. OK.
Posted on Dec 10, 2010
The TV doesnt start and there is a constant noise of 'click'..'click'...'click'... going when ever we start the plug and switch of the TV.. i guess this could be due to moisture in...
This is the HT leak from the LOPT . You can remove the back panel after switch off and on switch on - in a dark condittion- will be able to see the sparks shorting. If so switch off and let the HT drain off. There will be high voltage on the CRT and so care must be taken not to touch the anode as HT might flow. Use a dry cloth to clean ,use petrol to clean all dirt and static dust, clean the LOPT.
clean the HT leads. Use some insulation if the leak is more specially from the transformer. If the clicks are still heard without switch on then it is internal leak within the LOPT and it must be replaced,
Jul 14, 2011 | Televison & Video
Picture on screen has gone to only 1/4 of screen with strong line through picture.
This sounds like the OPT or LOPT has blown or weak ( OPT = Line output transistor. LOPT = Line output transformer.)
This job should only be carried out by a professional engineer. I would take it to your local TV repair person. Hope this helps.
Apr 13, 2011 | Sansui Televison & Video
Sony kd-34xbr2. Started having problems turning it on. Found manual. Found that when I hit power button, I can hear the components clicking, but i noticed there is no static on the display of crt, and...
CAPACITORS Argh. the worst component in anything...LOL.. Right u sound like you know what u are doing.
I would suggest you change your LOPT, or even the lopt. LOPT = Line transformer . lopt = line transistor. usually a au808 If you do not understand this, u should not be in the back of this tv.
Apr 12, 2011 | Televison & Video
I want a LOPT (Line output transformer) EF58149 for my 21 ?Onida color TV model number-8751, which was purchased in 1989. As per the Onida authorized service person, this modle LOPT is not available in...
Hello
Dec 10, 2010 | Televison & Video
Technics turntable has a lopt of static. no
run or rap a cable around both the phones ie red & white then run it to the GND. on the mixer or amp witch ever.failing that put a new ground wire in the turntable.when you take it apart you'll see the old one just crimp a new wire on to the old one,bob's you're uncle
Jul 30, 2010 | Technics SL-BD22 Turntable
Picture is dark
the problem is that the lopt is loosing power this can be due to a leak. in it there fore you will hear a hissing sound or the lopt is simply past its time. and will need to be replaced ( the lopt is a unit that sends power to the screen or in this case the globes the less the power the duller the picture)
good luck hope this helps
Jul 12, 2010 | Mitsubishi WD-62531 Projection Television
Logic colour TV stuck in standby mode.
hi! try floating the b+ pin of the lopt and check if you have a normal b+ if it has. the lopt is the culprit.
Aug 11, 2009 | Televison & Video
Tv goes to standby
Yes require sodering iron lopt is the Line output transformer large cylindrical plastic item on circuit board that has a thick wire that connects to the CRT (tube) with cap on the end. Do Not Touch as 24
Oct 07, 2008 | Televison & Video
Replacement of LOPT on an LG TV
You will have to cut solder /splice the 3 wires Be sure to dress the splices after soldering with electrical tape. That's the only way if the CRT socket is sealed. Just don't mix up your wires, They should be color coded. Let me know if you need any additional help.
Jan 31, 2008 | Televison & Video
Error code thompson 32ws23u icc17 chassis
Dec 09, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
