Question about Samsung Bd-E6100 3D Blu-Ray Player
Samsung Blu-ray E6100 looses WLAN connection & fails to re-connect
I have a Huawei Wireless Router and all other attached devices work fine. I have MAC filtering and secure access (WPA/WPA2) enabled and it has connected thru to Internet successfully. BUT it keeps loosing the connection and reverting to a 'default' IP address and unable to connect into the Wireless Network. Problem is not solved when entering all WLAN details (IP, DNS, Gateway etc) manually. Anyone any ideas?
SOURCE: Samsung ML 2010 under mac os X 10.5
I found a solution that worked for me by prowling around various Apple discussion forums. The two keys to the solution for me were numbers 3 and 5 below.
1. Opened print/fax preferences
2. Opened Add printer by clicking the +
3. For protocol, select HP jetdirect-socket (not IPP or LDP)
4. Determined the IP address for my Belkin wired print server and typed this into the Address line of printer setup
5. Manually selected the printer driver as ML-2010. It is in the list of drivers but is in the M's, not under the Samsung drivers.
6. This worked for me. I've seen reports from people who had to power cycle their print server and/or printer as well.
Posted on Oct 26, 2008
MNfisherman
  • 11896 Answers
SOURCE: Samsung NC10 will not connect to any network
If WLAN and Wireless cards are enabled, then you may have to unplug your router for 10 seconds to reset it. They tend to build up a static charge. Unplug wireless router for 10 seconds, plug back in and you should be fine in a minute or two with full connectivity
Posted on Aug 20, 2009
  • 630 Answers
SOURCE: samsung BD p3600, can not connect to the Wi Fi
Forgive me if you know this already IP address needs to be different to the Apple one. If the Apple one is 192.168.0.1 make the Samsung 192.168.0.2. subnet 255.255.255.0. Gateway should be the same as the apple number.. DNS can be left to automatic but if stuck use 4.2.2.3. Check the security settings on both the Apple and the Samsung are set to the same type
Posted on Oct 11, 2009
  • 5 Answers
SOURCE: blu ray want connect to the internet
You have to buy a Samsung wireless adapter in order to use a wireless conection..look up your player at www.avsforums.com for any and all questions and answers.
Posted on Nov 16, 2009
  • 6 Answers
SOURCE: I can't get our Samsung Blu-ray player(Model
I am not an expert a "tinkerer"at best but I do have the 3600 like you and I have no problems connecting. Make sure there aren't any spaces or special characters in you router name. Follow your instruction manual and get the 3600 connected first then try netflix: Menu, setup, network, set your settings and it will tell you available networks, choose yours, enter your security code then do a connection test. If its not connecting at what step are you having a problem?
Posted on Jan 10, 2010
Wont play 3d movies
Ensuring the Tv is a 3D tv, first .......wipe the disc and try again, usually the menu on the disk has the 3D selector if the blu ray is connected to a Tv that has 3D mode engaged it usually switches over to play in 3D automatically
Jan 02, 2014 | Samsung Bd-E6100 3D Blu-Ray Player
Error_model_bind samsung
Try different network cable and check. check if the Samsung HT-E5400 Blu Ray Home Theater [HT-E5400] has a reset option and reset it.
Try the following link for instruction:
http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?from_osc=&homeid=642763&idx=410781&modelcode=&modelname=HT-E5400&
Jan 27, 2018 | Samsung HT-E5400 Blu Ray Home Theater...
Can't connect my blu=ray dvd to my wireless internet
Please clarify your model number. If you have the DMP-BD60, it only has wired networking capabilities. A USB wi-fi dongle will not work (the USB port is only for storage devices). If you are connecting it to a wired port on a wireless bridge (switch) or directly to your wireless router and having trouble with the connection, check your cables and that your network is up. Next check that you have not restricted the number of devices allowed to connect to the router. There are ways to limit the number of IP addresses in the router setup. If you allowed 4 addresses and the blu-ray player will be number 5, you need to adjust the settings for your router.
Please add a comment with the model number if you are using a different blu-ray player. I hope this helps.
May 05, 2012 | Televison & Video
The signal from my router to my Samsung blu ray is not strong enough
There are several things you need to consider with wireless connection:
Distance - How far is the Netgear router from the Samsung Blu ray? Try changing the wireless channel on the Netgear router that can help boost the signal. Wireless Security- Have you enabled wireless security on the router? Is it WEP or WPA? Make sure that you input the wireless security key on the Blu Ray player and that you have setup wireless settings correctly.Number of wireless devices - Check the number of wireless devices(laptops, desktops, pda's, etc) connecting to the router as it also weakens the signal. And if wireless security is not enabled on your Netgear router, there's a chance that your neighbor might be connecting to your router via wireless.
You can also test how strong the signal is by placing a wireless laptop on the same location where the blu ray player is. If the laptop gets a weak signal as well, you can try placing the router closer to the blu ray player.
Oct 24, 2011 | NetGear WNR2000 Wireless Router
My toshiba BDX2700 has an integrated wifi connection. It connects to my home networrk. For 2 weeks it worked just fine and now it won't connect. Or, actually, it says it "connects" to the...
Seems like the DNS on your router has failed to provide address info for your BR player. I would first try this:
  1. Unplug the Blu-Ray player
  2. Unplug your router for 20 seconds
  3. Plug your router back in and wait for the Wifi symbol or WLAN light to turn on
  4. Plug in and turn on the Blu-Ray player
If that fails, I would double check the WiFi settings on the Blu-Ray player, make sure that you have the SSID and passkey correct.
If that still fails, I suspect that your router's DHCP table has a problem with it. You may need to consult your router's manual for instructions on how to clear the DHCP table. The easiest way to do this is to perform a factory reset on the router. You will have to redo any configurations you may have applied to the router such as WiFi name (SSID) and pasword.
Mar 13, 2011 | Toshiba BDX2700 Blu-Ray Player
I am trying to connect a wireless ready Samsung blueray player to my Motorola Surfboad and it says to press the wps button on the surfboad, where is it?
NOTE: [] & "button(s)" represent features on the remote controller. {} & "key(s)" represent features in on-screen menus.
ROUTER INFO: WPS is on the SBG901.
BLU-RAY DISK PLAYER: You did not mention the model # of the Samsung Blu-ray disc player, so this information is somewhat generalized.
PREREQUISITE: Once you have attached Samsung's proprietary wireless adapter to that Blu-ray player, have connected that Blu-ray player to your TV, & have powered on that router & Blu-ray player & TV, access that Blu-ray player's initial settings menu.
STEP ONE: From the Home menu, press ?? buttons to select "Settings." Press [ENTER].
STEP TWO: Press ?? buttons to select "Network." Press [ENTER].
STEP THREE: Press ?? buttons to select "Network Settings." Press [ENTER].
STEP FOUR: Press ?? buttons to select "Network Type." Press [ENTER].
STEP FIVE: Instead of using the the "PBC (WPS)" selection, press ?? buttons to choose the "Wireless" selection & press [ENTER].
STEP SIX: Press ?? buttons to select "Internet Protocol Setup." Press [ENTER].
STEP SEVEN: Press ?? buttons to select "Auto" or "Manual." Press [ENTER].
IF SETTING UP WIRELESS CONNECTIVITY VIA AUTO NETWORK SEARCH: If you selected "Auto," press the ? button to go to "Access Point Selection." Press [ENTER]. Upon searching for available wireless networks, it will display those choices in a list.
A.) In the list of networks, press ?? buttons to select your network. Press [ENTER].
B.) IF "PIN/Security" DOES NOT POP UP, THEN SKIP THIS STEP; otherwise, press ?? buttons to select PIN or Security (Security Key--the usual option), & enter your network's Pass Phrase on the Security screen. (This Pass Phrase would be what you would use to access the network. IT SHOULD NOT THE PASSWORD WITH WHICH YOU SET UP YOUR ROUTER!)
Press number buttons on the remote to enter Pass Phrase numbers OR use arrow buttons on the remote to move from key to key in the Security Key screen. Change the type of on-screen accessible characters by moving to the on-screen {a/A/1/?} key & pressing [ENTER] on the remote. (The character set changes with each press of [ENTER]. Once displayed on the screen, you can enter a letter by pressing the number button on the remote which corresponds to that letter key. Pressing that button repeatedly changes the letter. You can move to {Delete} & press [ENTER] in order to remove the last character entered. You can move to {Clear} & press [ENTER] to clear all entered characters (or just press the red [(A)] button. When done, press the yellow [(C)} button (or the {Done} key followed by [ENTER]).
C.) WAIT UNTIL THE CONNECTION CONFIRMATION MESSAGE DISPLAYS & THEN PRESS [ENTER]. You're back at the Network Selection menu.
D.) To test the connection, press ? to select "Network Test." Press [ENTER].
IF YOU REQUIRE ASSISTANCE WITH SETTING UP THE WIRELESS NETWORK CONNECTION MANUALLY, I SUGGEST THAT YOU READ THE MANUAL (http://www.samsung.com/us/support/).
Jan 08, 2011 | Arris SURFboard SBG900 Wireless Router...
I have Samsung blu ray and bought the adaptor for it to stream netflix through my wireless network. The two see each other, but when I enter the Wep Key or password, it doesn't connect. Any thoughts?
Try setting the allowable connection number in your router to at least 5. If you set a limit on your router for say 3 simultaneous connections the 4th device attempt to login will fail or just not recognize the router.
Nov 26, 2010 | Samsung WIS09ABGN (8808993304486)...
Samsung bd-p1600 wireless connection to 2wire 1800HG router
Check CNET Samsung forum. There are several posts with the same problem. A couple solutions and basic confirmation that Samsungs newest fireware is bad. I wish their support helpdesk would realize that instead of telling me to contact my router support.
Apr 24, 2009 | 2wire 1800HG Router (RG1800HG00)
Samsung Bd-E6100 3D Blu-Ray Player Logo
103 people viewed this question
Jerry Greenberg
Jerry Greenberg
