Question about Hitachi DZ-MV730A DVD Camcorder
Do I HAVE to use Maxell dvd-r
I am wondering if I can use different (less expensive) types of mini dvds with this? Can anyone suggest a good DVD-RW, or dvd-r?
I use Panasonic DVD RAM, since my DVD RW drive supports it.
Posted on Oct 21, 2012
  • 247 Answers
Provided you check that what you are buying is DVD-R or DVD-RW (as opposed to +R or +RW), it should work. Best thing is probably to buy one or two and see how you get on. There's not many places make DVDs - and an awful lot of badge engineering goes on. You could download a useful bit of freeware from http://dvd.identifier.cdfreaks.com/ to help you find out which factory your Maxell discs have come from - and which of your cheap alternatives actually hail from the same stable. A.
Posted on Jun 23, 2007
SOURCE:
When trying to record a home video VHS to DVD this is what I get. E-4 54040990 Cannot record on this disc. The disc is brand new.
Have you've tried cleaning the laser with a cleaning disc?
Failing this it may be worth removing the cover and cleaning the lens directly with a QTip and some lens cleaning fluid. Only use a drop and then wipe off with a clean dry QTip.
The other option is that you are using an incompatible format of blank DVDs. I've heard of people having problems using DVD-R & DVD-RW and although it is lised as being suitable for all types of recordable DVDs I belive you're best using DVD+R & DVD+RW.
The Manual states
Recordable disc
• We strongly recommend for good recording quality:
SONY DVD+RW 4x, MAXELL DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, TDK DVD+R 4x/8x/16x,
MAXELL DVD-RW 4x, MAXELL DVD-R 8x/16x
• Discs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+RW 4x VERBATIM DVD+R 8x
VERBATIM DVD-RW x VERBATIM DVD-R 8x JVC DVD-RW 4x MAXELL DVD-R 16x
May 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Brought 5 maxell 1.2x rewritable 4.7 gb data dvd-rw tried to record a film keeps saying no disk what am i doing wrong? kind regards ken moore
if the other 4 dvds are still wrapped take it back (in exchange for 4x 4.7gb dvd-rw)...you picked up 1.2x your player maybe looking for higher speed..these recorders are very sensitive for the type of dvds it use..(i can only use maxell /panasonic + dynex (online))..cant use some of those on sale ones.....my recorder wont just eject it it rejects,,,,
hope this is your case, feel free to rate the help
Jun 16, 2010 | Maxell MAX635114 Rewritable Single-Sided...
I can't get the DVD out of the player
Need a firmware upgrade. Emerson will charge you for it. Otherwise you need to find Dvds it will accept. Hard to do with all of the newer dvds. -RW only 1Xor 2X. -R 1X-2X. Memorex would not work for me. Multi- speed dvds over listed speeds will not work. Maxell -R 1X-4X worked for me. Good luck finding any.
Jan 16, 2010 | Emerson EWR20V4 DVD Recorder/VCR
Certain DVD disc can able to openSONY DVD RW DRU-810A, But I am unable to open with SONY DVD RW DW G521A. Kindly advise me to further course of action.
yes, most of the dvd recorders are like that. you must read the user guide to find the correct dvd brand to use. i have a toshiba (i can only use maxell, (best) tdk ,dynex (good) and memorex (Ok)) fuji sony pansonic will not record nor play.
http://www.supermediastore.com/dvdmedia.html blank dvds for sale
May 06, 2009 | Televison & Video
Hitachi dvd player not reading all dvds
Hello, I'm here try and help your problem, first older DVD players only read certain disc formats, If you have your owners manuel to your DVD player it will tell you what types of discs the DVD player will play. There are seneral types of burnable disc's DVD -, DVD +, DVD-R, DVD+R, DVD-RW, DVD+RW, please looking in the owners manual for the types of discs that the player will read, also in the same secton it will tell the types of formats that it will read DVD Video, DVD ROM, and there is a few others, Next is when you burn DVD's the type of burner you have makes a difference. You will need to find out what format your DVD burn, burns to disc, some of the newer DVD players
read alot of the formats. I would start by finding out what your DVD burns first, then I would suggest buying a DVD player that will read that format. If you have anyother questions please feel free to post them, Thank You and have a great day.
Jan 14, 2009 | Televison & Video
DVD Recorder will not format blank DVDs
I kept formatting DVD's until I got the unit to work. Mainly, it was some DVD's I had earlier problems formatting. I tried two new DVD's (Maxell DVD-RW) and they worked thus far. I truly think the unit needs to be taken to authorized service center for evaluation or minor maintenance. My suggestion is to verify the DVD's will work with unit. Try to use better quality ones like TDK or Maxell. Thanks for responding to my problem. If I have others, I will contact you.
Feb 09, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Can't view a DVD Recorded on RCA DRC8335
whats the format of the dvd writer you used,? cus sometimes the computer cant really read a unknown format of dics. try to use a nero or divx to read it.
Jan 25, 2008 | RCA DRC8335
Dvd/vcr recorder/magnavox
my solution may be to never buy this companies products again as I have been having the same issue and since the machine is not been used much and since the disks worked before it really ticks me off. The suggestion noted to my issue recently really didn't seem to be valid due my above statted time period of no problems then sudden isses tends to show me poor quality of equipment by manufaturer.
Dec 06, 2007 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Can't record DVDs
OK. Finally "solved" this problem. You must use the brand name "Maxell" DVD disks, 2x or 4x (maybe 8x). Do not use variable speed disks (e.g. 1x--4x) or 16x. Walmart carries these!
The DVR -RW 2x finally got mine to record. I didn't think this would work, but it did. I am still experimenting with it. Had to download (free) VLC player to get it to play on my computer. Works fine in other DVD players.
Credits to the Sears' repairman, the guy at F., and my patience!
Oct 24, 2006 | Sylvania SREC427 27 in. TV/VCR/DVD Combo
Hitachi DZ-MV730A DVD Camcorder Logo
79 people viewed this question
Top Hitachi Video Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Jerry Greenberg
Jerry Greenberg
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
