Question about LG Android 4.0 ice Cream Sandwich Mid 7" Touchscreen Wi-fi G-sensor Tablet 4gb Bu
How do I reset an android tablet or bypass the pattern lock w/out a gmail account
My child can't remember her pattern and was locked out of the talet. It asks for a gmail account which she can't remember either. The back-up email address is the same as the email she can't remember so it is useless. We are completely locked out from using this tablet. The users manual has no instructions on to reset the tablet to the manufacturer settings.
Tip
Android Tablet Hard Reset Method
If you had forgotten your Pattern lock of your Tablet, you can reset it of your own.
You can recover it through your Gmail account, enter the pattern for 15-20 times. After it you will be asked to enter your Gmail password.
But, if you do not remember Gmail password
then Hard reset will be the Final solution to your question.
Different Hard reset factory wipe methods for Android Tablet Different Hard reset factory wipe methods for Android Tablet
on Feb 24, 2015 | Samsung Tab Tablets & eReaders
Change pin number
hard reset by recovey options
Nov 14, 2014 | Tablets & eReaders
How can i unlock the screen on a mid-android 7" tablet that my daughter cannot remember the pattern she locked it with?
After a few attempts to guess pattern it should prompt for the gmail account assigned to the phone. Then allow a pattern reset and confirm.
Aug 08, 2014 | Coco Android 2.1 Tablet (837121001186)
AX109JC20130709
You do not say what type of password was set and if you have forgotten it or just want to reset from a known password..
If you just want to change your gmail login password
- Go to google.com/accounts on the tablet browser
- Sign in
- "Change Password"
- Go back to the Home Screen on the tablet
- Open the GMail app, clicked on Menu, then Refresh -- you will get a sync error
- Wait for a notification to re-enter your password (a triangle with an exclamation point in the tablet notificaiton bar and/or something in the gmail screen)
- Enter the new password
This simple solution sometimes works:
Turn it off.
Turn back on.
When you get the warning triangle in the notification bar, open the notification.
You will then get a login screen.
Input your new password.
Pattern Lock- Incorrectly enter pattern 5 times (4 or more points each time) . Pop up message will appear Click Next and you will be prompted for goole a/c details or security for pattern lock.
tap forgotten pattern and on next screen enter goole account details. Then next screen allows you to choose a new screen lock option.
Locked with PIN or password _Try Screenlock bypass pro from play store.
The only other solution is a hard reset which is only as a last resort. You need to access Androids Recovery mode. Check your manual. Most devices it is power off then power up holding volume + and power buttons.
Once in this mode use power down button to highlight "wipedata/factory reset option, then use power button to select it.
Vol - button to to scroll and select yes delete all user data option with power button. When device reset select option to reboot now and the device will turn on unlocked but you will have lost your personal data.
Face unlock - you were asked to provide a pattern or PIN backup when you set it. Just bypass and enter PIN or pattern.
Good Luck
Aug 06, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Forgot home screen password for Samsung 12.2 tablet. How do I unlock it?
If it's an android device...
1. Enter wrong pattern 5 times and wait for 30 seconds.
2. Select "Forgot pattern" and enter your email account username and password.
3. Make sure you use the same account that was used to activate the device and double check the password by logging in to that email account in a browser.
4. If you don't have access to the original email account, you will need to do a hard reset and loose your settings and apps on the devcice. The data on the memory card will not be wiped though.
Note: if you can't remember your email password, you will have to visit the email service support page to get it reset.
also, see here...
http://www.androidtablets.net/forum/android-tablet-usage-tips-tricks/6280-forgot-your-unlock-pattern.html
or here... http://mytabletguru.com/forgot-password-pattern-unlock-of-android-tablet/
Jul 15, 2014 | Tablets & eReaders
I have an android AK888-15B.my tablet has been locked due to multiple incorrect patterns however I need to unlock it by signing into my gmail account but how do I do that if I have no internet connection...
You can buy a google account bypass from Ebay or learn how to install the factory operating system from a usb flash drive or SD card if there is SD card slot.
Try turning off the device, then hold the power and the Vol Up button, or the power and vol down button or the Power and both vol up and vol down to factory reset the device.
If you are still locked out, its so much easier to buy the google bypass but you will need to plug it into the computer after you purchase the bypass and download tinyURL program, which will all be explained after purchase. Google Account Bypass is around $5.00
Nov 23, 2017 | Tablets & eReaders
Son forgot password
If you set a pass code (or pattern) that you cannot remember, please enter the wrong password (10-20 times) until you are prompted to sign in via your google account. Please note, this will only work if you have already setup your google account on the tablet. If you have not set up a Google (or Gmail) account on the tablet, you will have to perform a firmware install, which will revert the tablet back to factory settings. Support Troubleshooting Guide
Mar 23, 2014 | Kocaso M730W 1.2GHz 4GB 7 Capacitive...
How to factory restart a nextbook tablet without gmail?
You do not need gmail.com only tap on SETTINGS to factory-reset your tablet.
Jun 24, 2013 | Tablets & eReaders
I have locked my MID Android Tablet. I have forgotten the pattern, So is there any one who knows how to unlock the pattern?
pls try reset your mid tablet pc, if it can't, maybe you can contact your seller. if you can't contact your seller, you can ask another mid tablet pc seller online help sevier. as: http://www.mcwto.com, they are an mid tablet pc wholesaler.
Nov 01, 2011 | Coco Android 2.1 Tablet (837121001186)
LG Android 4.0 ice Cream Sandwich Mid 7" Touchscreen Wi-fi G-sensor Tablet 4gb Bu Logo
123 people viewed this question
Top LG Tablets & eReaders Experts
Jax Planet
Jax Planet
Andrew Taylor
Andrew Taylor
ka4iup
ka4iup
Are you a LG Tablet and eReader Expert? Answer questions, earn points and help others
