Question about Panasonic PT-52LCX65 44" HDTV
How to reset lamp on Panasonic 1080 i without my remote
I know how to reset it with the remote but I have lost it so I can't push the PIP button while pushing the volume on the tv.
    Sergeant:
  • 204 Answers
Look for a replacement on partstore.com or ebay.
Posted on Dec 30, 2012
  • 3 Answers
SOURCE: Panasonic LCD PT 50LC13. Nothing happens when I push PIP/SPLIT
Make sure you put the lamp DOOR back IN PLACE before turning your TV back on. Then it should all be just ducky.
Posted on Mar 25, 2009
  • 10 Answers
SOURCE: i dont have a pip button on my remote to reset my
if you do not have the (PIP) button on your remote look for for the (split) button and try the volume down and (PIP/split) trick again. it worked for me!! good luck..
Posted on Oct 08, 2009
ladywinn
  • 5138 Answers
SOURCE: I have a Panasonic PT-50LC13
Replace your Ballast Board it is what turns on Lamp call Encompass Parts 1-800-638-3328
Posted on Dec 20, 2009
  • 927 Answers
SOURCE: i have a Panasonic pt-52lcx65-k. I thought the
Howdy,
Doble check your Lamp Installation, making sure that the Lamp Cover is properly secured. Reset TV by unplugging TV from the wall for 3-4 minutes then plug back in, then turn TV on.
To reset your Panasonic Lamp Time:
ø Press and hold these buttons for (at least) 5 seconds:
ø Volume Down button (on TV Panel).
ø AND ACTION Button (on remote).
As the remote gets older the ACTION button may not respond unless you press the button dead center and not at an angle.
Thanks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
SOURCE: how do you reset the timer on the lamp without a
press trhe voulume minus buttin the the unit while pressing the PIP or swap button on remote
Posted on Jan 08, 2010
I have a universal remote for my Panasonic PT-50LC13 and I need to reset the lamp hours. Can anyone help?
I too had a problem resetting my lamp time of my PT-50Lc13. My remote that came with the set lacked a PIP and SPLIT keys, BUT....my charter remote (that was obviously configured for my set via codes) has a PIP ability that we discovered some time ago. Instead of using the STANDARD remote, you can use a UNIVERSAL that has a PIP capability....has to be set up to work with your set first....you can hold down the VOL - key and the UNIVERSAL remotes PIP key for about 5 seconds and then you will receive a message stating that the lamp time was reset to 0.
I know this helps someone out there, and your welcome!
Oct 24, 2010 | Panasonic PT-50LC13 50" Rear Projection...
How do i reset the new lamp hours after installed the new one?
The reset instructions often are in the box with the replacement lamp; use those directions if you have them.
Try holding the Volume Down button on the TV while pushing the Play PIP button on the remote for about 5 seconds. If that doesn't work, try the Split button instead of the Play PIP button on the remote. You should see a message that the Lamp hours have been reset before you release the two keys.
I hope this helps.
(make sure the cover is properly attached before trying the reset.)
Sep 15, 2010 | Panasonic PT-56DLX25 56" HDTV
Resetting lamp hour meter on panasonic tv
press volume down on tv and pip or split on remote
Nov 19, 2009 | Panasonic PT-56DLX25 56" HDTV
MY PANASONIC PT-52LCX35 REMOTE DOES NOT HAVE A SPLIT OR PIP BUTTON. MY BOTTOM BUTTONS ARE TV/VCR, VCR/DBS CH UP,DOWN. HOW DO I RESET THE LAMP TIMER. THIS IS THE REMOTE THAT CAME WITH THE TV.
I can help you reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV. The buttons used are the TV's volume down and the remote's number 0, not the 'split' or pip for your model.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Oct 10, 2009 | Panasonic PT-52LCX66 Projection Television
How do you reset the timer on the lamp without a PIP button on the remote
Howdy,
Oct 08, 2009 | Panasonic PT-52LCX65 44" HDTV
I dont have a pip button on my remote to reset my
Oct 06, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Unable to reset Lamp Hour Meter on Panasonic PT-50LC14
Try this, using the Panasonic remote, wait until the notice about your lamp goes AWAY (it wont work with the message still up).
Hold the volume down on your tv while holding the split/play button on the remote.
You will get a notice about 4-5 seconds later that it was reset.
May 29, 2009 | Panasonic PT-50LC14 Television
Reset hour meter for replaced lamp
push and hold the PIP (same as play) button in the remote control
push and hold the menu button on the front panel of the tv.
Do both actions simultaneously. Of course you have to be close to the tv to do this: pointing with the remote at the sensor AND holding the menu button of the tv panel.
Do this for some seconds and the screen is going to tell you the timer was reset sucesfull and ask you to push exit in the remote control to finish
Apr 08, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Lamp meter on Panasonic PT-40LC12 ?
I just had my picture go out two weeks ago. I took it to a local tv repair shop. They replaced the thermal fuse. I also had a spare lamp so they also replaced that. I'm not sure if they reset the lamp meter but this is what I found surfing around...try at your own risk. I'm going to try this when I go home tonight.
Good Luck...
Press the power button to turn the unit on.
While pressing the Vol-(volume down) button on the projection display,
hold down the PIP button on the remote control at the same time for more
than 5 seconds. When the reset procedure is complete the following message
will appear on the screen. "Lamp time was reset to 0".
Mar 16, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Turning off PIP without remote
To turn off the "stuck" pip on a Panasonic tv without a remote:
1) Turn off the tv.
2) Then hold down the "Action" button on the front of the tv and press the power button.
2-b) Continue to hold down the Action until the tv powers all the way up, and the reset menu comes up - be patient.
Expected Reslut: Self check menu should appear.
Expected Reslut: The pesky pip screen will be gone!
If the self check menu does not appear, you did not hold the Action button long enough.
Simply begin from step one.
Thanks to Imhiro
Sep 28, 2007 | Panasonic CT-36D32 36" TV
Panasonic PT-52LCX65 44" HDTV Logo
43 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
