Question about Lands Phones
Can't clear voicemail from landline
How do i change the voicemail on my landline and how do i retrieve messages on telkom landline.
Hello, Janine -
The voice mail and message service for your landline phone is provided by your landline service provider. If you did not receive a printed booklet directions for your landline phone service, I suggest you call your landline telephone service provider Customer Service number (Telkom) and ask for one.
From the Telkom web site, this looks like the number to call:
10210
Best wishes
Jan 03, 2018 | Lands Phones
I have a tracphone. How do I clear my voicemail box? No messages can be left on my voicemail. Thank you.
Delete voice mail by going through the keypad on your cell phone. The actual procedure depends on the kind of cell phone that you own. For example, on the Nokia 1100, hold down the "1" key while you are on standby. Tracfone connects you to your voicemail, where you can follow spoken menu instructions to listen to your voicemail. After you hear the voice message, you're asked if you want to delete your recordings.
This is not recommended, because connecting in this way uses up your minutes even if you just want to listen to them.
Use your landline phone to delete messages if you want to avoid using your Tracfone minutes. Turn off your cell phone so it doesn't ring and then call your cell phone number from a landline.
Press the "*" (star) key as soon as you hear your voice mail greeting. Then enter your password number and press the "#" (pound) key.
Listen to the instructions for accessing your voice mail, which can vary slightly depending on the phone you have. You are told the number of new and old messages you have, how to listen to them and how to store or delete them. Press the number for listening to the message to hear it, and then the number for deleting.
Sep 08, 2017 | Lands Phones
How to set up voicemail
  1. To access your voicemail, hold down the 1 button.
  2. When prompted, enter the temporary password (the last four digits of your wireless phone number).
  3. Follow the instructions to set up a new password and record your name and a personal greeting (or use the default message).
  4. You can check your voicemail from a landline.
How do I set up Voicemail on my Phone & Quick Messaging Phone ...
www.rogers.com/web/support/wireless/voicemail/903?setLanguage=en.
not sure if this helps you out,if not go to google and put info in there.
Nov 17, 2016 | Cell Phones
How do I retrieve voicemails? I have not set up voicemail yet.
If you haven't set up your voicemail yet, then there s no voicemail to retrieve. The mailbox will not accept calls until you set the mailbox up.
Dec 18, 2015 | Lands Phones
How do I access my voicemail from another phone?
To call your Voice Mail from a landline phone:
1. Call your TracFone from a landline phone.
2. When your voicemail begins, press the star key on your landline phone immediately.
3. Enter the PIN you use to check your Voice Mail from your TracFone. When you have finished entering your PIN, press the pound key.
4. Listen to the instructions. They will tell you how many voicemail messages you have and give you options for checking them, deleting them, saving them or storing them as new messages. Phones may vary, so listen carefully to the options.
if you havent created a pass code try 9999, if that doesnt work give tracfone a call.
1-800-867-7183
Sep 19, 2012 | tracfone.com
Voice mail blinks & won't clear
There are messages on the voicemail system provided by your telephone company. This records messages when people call while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jun 01, 2012 | AT&T DECT 6.0 Cordless Phone System with...
I can't pick up voicemail
Apparently you're subscribed to a voicemail system offered by your landline telephone company. Please contact them for instructions on acessing their voicemail system.
Mar 30, 2012 | Siemens Lands Phones
How do I retrieve my voicemail from a land line
Access your voicemail from your mobile cell phone and record a personalised voicemail greeting.
Now call your number from a landline, and when you hear your voicemail greeting prompt you to leave a message, press the required key sequence to access your voicemail from the landline.
The required sequence is dependent on which network/service provider you are using.
If you let me know which network, i can give you more detailed information.
Jan 06, 2010 | Motorola Cell Phones
How to set up voicemail on i phone
<<This is straight from TracFone support for setting up voicemail on the Motorola C139....enjoy>>
Thank you for your interest in TracFone Wireless. We are responding to
your recent inquiry.
TracFone Wireless would like to take this opportunity to apologize for
any inconvenience this issue may have caused you.
Your voicemail box has been reset. To set up and retrieve voicemail from
your TracFone:
Press the MENU key,
Scroll to MESSAGE and press SELECT,
Then scroll to VOICEMAIL and press the MENU key,
Next scroll to VOICEMAIL SETUP and press SELECT,
The VOICEMAIL Access Number should be: +17044089979 and press the OK
key (if there is no + sign, please press and hold the 0 key until it
comes up).
If the numbers there are different, press and hold the key below the
word CLEAR or DELETE until all the numbers disappear from the screen.
Then enter the number 17044089979 and press OK.
After programming the Voicemail Access Number on handset, please turn
the phone off and back on.
Then, press and hold the 1 key to auto-dial the VOICEMAIL box to record
greeting and complete setup.
Your temporary password can be 0000, 1111, 9999, the last 4 digits of
your wireless number, or another 4-digit number easy to remember.
All calls made to your voicemail from your TracFone will deduct airtime
units. To avoid being deducted airtime, it is recommended that you
contact your voicemail from a land line phone, by dialing your ten-digit
mobile number. To retrieve voicemail messages from a landline phone,
please follow the instructions below:
1. From your landline phone, dial your TracFone Number.
2. When you hear the greeting, press the star (*) key. If the star key
does not interrupt the greeting, press the (#) key.
3. Enter your password and follow the retrieval instructions.
Please note, if this procedure does not resolve this issue, we would
need to talk with you directly for further assistance.
Should you have any further questions or concerns, please contact one of
our customer care representatives at 1-800-867-7183. For your
convenience, our representatives are available Monday-Saturday from 8:00
AM to 9:45 PM EST, and on Sunday from 8:00 AM to 6:45 PM EST.
Thank you for being a TracFone Wireless customer. We appreciate your
business.
Sincerely,
TracFone Wireless
Sep 16, 2008 | Cell Phones
Lands Phones Logo
Top Lands Phones Experts
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
