Question about GE 18023 Dimmer Rocker OnOff with Slide White
I want to install the 18023 ge dimmer in the middle of a 4-way switch
Already have a dimmer by the door but don't need it. I can't get the lights to all work unless the switch by the door is in one position. up.
  • 843 Answers
Bob, Not quite enough info to be sure how you have this wired, but here's a shot. 3 or 4 way dimming switches are designed to work with other 3 or 4 way on-off switches, not with another dimmer. I never tried this but it is no surprise that it might work only if you keep the dimming function of switch C in the full-bright position, because you are using two dimmers wired in series. For best operation, you should replace C with a regular 3 or 4 way switch.
Posted on Dec 31, 2012
2 Suggested Answers
TerryTown
  • 292 Answers
SOURCE: Can I replace a leviton dimmer light switch that
Thank you for contacting FixYa with your electrical inquiry.
Yes! Both units are interchangeable.
The green wire is a ground and the box under the cover plate has a ground screw or provision for attaching the green ground wire. The two black will go to the existing leads. Usually screw on wire nuts are included in the new GE Dimmer Switch to make installation simple.
For safety be sure to trip the circuit breaker effecting that light circuit. It's usually located in the load center in the garage and should be well labeled by code requirements.
Hope this helps. Please keep us updated and remember to rate this answer.
TF
Posted on Jun 15, 2011
Testimonial: "Haven't tried to do it yet, but you advise was very helpful. Thanks,"
I have a dimmer switch with 2 red wires 1 black wire and 1 green wire
that is a 3 way switch. In order for that to work it has to be installed to a light with more than one switch. For example in a hall way and there is a switch at both ends of the hall then both switches need to be 3 way switches
Sep 11, 2014 | GE 18023 Dimmer Rocker OnOff with Slide...
Need help 2001 chev cavalier running lights work but low &high bean lts don't
Someone will need to check for voltage at the dimmer switch and then trace back to the fuse box as needed.
Dec 12, 2012 | 2001 Chevrolet Cavalier
Door won't lock for self cleaning although closed
Hi, Look to see if the safety switches in the slots in the door is bent Kind of hard to figure out if you don't know how they are supposed to look like but guess remember it's not working either, also could be a bad switch itself.
Nov 22, 2011 | GE Profile JTP56 Electric Double Oven
I forgot to open the dishwasher hole when installing. I don;t have the instructions and I can't figure out what I am supposed to do. It seems solid and I don;t see anything removable
If you disconnect the dishwasher hose from the disposal and peek inside the disposal where the hose was, you'll see that it's blocked by a piece of plastic. It's premolded into the inner chamber but that portion is breakable. Stick a screwdriver or something into the hole and give it a whack. If that piece end up inside the disposal's main compartment, you'll need to get it out. You could turn the disposal upside down if you haven't already installed it, but you did.
Aug 18, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Interior lights stay on and car chimes when car is off ford windstar 1997
On certain model the dimmer is also control the inside light.
MOVE the dash dimmer control dial from the extreme right to the middle position. (counter clockwise)
Clean the metal contacts on the side sliding door.
You may find white lithium grease on the surface.......do you best to wipe these contact clean.
Do the same on the rear hatch contacts.
Both front doors has plastic pin switches.
Check one door at a time to make sure the plastic pin switch is good condition.
Press the switch in and see does it operate smoothly.
Aug 10, 2011 | 1996 Ford Windstar
I installed a GE dimmer similar to this model (bought it from COSTCO), after about 10 minutes the metal plate on the dimmer start to heat up. It is normal? Is it faulty? Can it start a fire?
It is normal for dimmers to get warm. Dimmers have, roughly, an inefficiency of about 1% that turns into heat. Metal plates, especially the metal screws, are going to conduct that heat to the front pretty effecitvely. The lower you dim the lights, the cooler it will get. Also, the less load you have on it, the cooler it will get. A plastic plate will contain the heat more effecitvely - or better yet a screwless faceplate will completely encapsulate it.
Aug 02, 2011 | GE 18023 Dimmer Rocker OnOff with Slide...
I need to replace the door switch on my GE Profile Gas Dryer DPSB620GC4ww and don't know how to get behind the panel on the front of the dryer. Can you give me detailed instructions on how to do this?
unplug it,open the door and look up,you'll see two phillips screws,take them out and remove the top panel,if you want to remove the front panel just remove the two phillips screws one on each side of the panel around 4 inches down from the top.
May 20, 2011 | GE Profile DPSB620GCWW Gas Dryer
3 way dimmer in a single switch ap
Sometimes it can sometimes it can't. They make dimmers designed for both. If it is not designed for both it can only be used in a 3 way application.
May 01, 2010 | GE 18023 Dimmer Rocker OnOff with Slide...
GE 18023 Dimmer Rocker OnOff with Slide White Logo
151 people viewed this question
Top GE Electrical Supplies Experts
steve morris
steve morris
ray gallant
rdjagger
Are you a GE Electrical Supply Expert? Answer questions, earn points and help others
