Question about Mitsubishi WD-65737 Home Theater
Mitsubishi Model 65737 changed lamp, ballast and all fans are running. TV still won't start up. Code 37
Slinteriors
  • 8617 Answers
SOURCE: red lamp light with newbulb, won't come on error code 34
There are two 1000uf 16V capacitors on the PWB that cause that problem code 34 lamp abnormality. If you need more info let me know.
Posted on May 04, 2008
  • 98 Answers
SOURCE: Mitsubishi WD-52525 Lamp ballast
Contact Mitsubishi Parts themselves, 18005537278. They are very friendly.
Posted on May 15, 2008
  • 52 Answers
SOURCE: Mitubishi WD 62725 - Ballast Problem??
Could be the FMT pcb or the Dm pcb board you should check the caps on them and replace any faulty ones.
Posted on Nov 14, 2009
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi 52525 TV Red Lamp LED
340v should be on power pwb plug PL on the 1 and
5 (GND) pins for the ballast. and the ballast plug CN should also have the 340V with pin 1 of that plug being GND nd pin 3 should have the 340V If the PL plug on the power board is low the power pwb has a problem most likely the doubler circuit. If CN plug voltage is high say 360V the ballast is suspect.
Posted on Jan 10, 2010
SOURCE: problems with mitsubishi WD 65737
problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture then the tv turns off the light on the front is now steady red. resetting the sytem worked yesterday but not today.
Posted on Oct 03, 2010
We have a Mitsubishi TV model# WD-60735.. we have changed the lamp because it was flashing red but now its flashing yellow and the tv will not turn on..
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Nov 18, 2015 | Mitsubishi Televison & Video
I bought a lamp for my Misubishi 1080p and its not coming on flashing yellow
If not same issue as before lamp replaced double check that it is in correctly and door is closed--this set should also have a self check:
This is for another model so codes may be different but see what code you get.
Nov 08, 2012 | Mitsubishi WD-Y657 65" HDTV
Wd-60737 mitsubishi blinking yellow status light ?
Oct 25, 2012 | Mitsubishi WD-60737 TV
Mitsubishi dlp tv model wd-62627 wont power on when i plug tv in green light flas then will stop then i try to power on tv after after green light stops flashiing after oabout 30 sec red lamp light co
Inspect the lamp first to see if shattered--set has a self check feature also:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
33 = Air filtercover is open.
44 = DVI cablebetween FMT and Engine disconnected
May 30, 2012 | Mitsubishi WD Televison & Video
Tv doesnt show anything
Got (if model listed is correct) any blinking lights?
Set has a self check:
Here's something that might also be useful. After you turnon the set, and get the regular red blinky lights, hold down the Device andMenu buttons together for about 5 seconds.
May 29, 2012 | Mitsubishi WD65737 65" DLP TV
Shuts Off with a blinking red light
Lamp used is first suspect in model indicated here WD-65737.
If cover is removed first (rear) look to see if a lot of dust and or dirt on fans (3) or at rear of set. Set intakes air from front of set and exits it from rear--a lot of these when in our shop first get a air clean outside with a compressor to clear all dust out.
If not the lamp or dirt suspect number two is the ballast that powers the lamp---set even if it does not power up should have a self check--press and hold menu and input (device) at same time for at least 5 seconds and release both--
44 = DVI cablebetween FMT and Engine disconnectedLet me know what you find.
Apr 23, 2012 | Mitsubishi WD65737 65" DLP TV
I have a error code 33, what error code is 33
Hi, These are some codes to your DLP HDTV.
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disc
Jul 20, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi tv error code 21
The service manual does not list an error code for "21".
Here are the error codes:
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Sep 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD62526 - Error/repair code
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
remove the back and lamp (make sure the lamp door is on) turn the tv on and look to see if the fan is running (keep you hand out of the tv when doing this - as the lamp connectors are empty) if the fan does not start - replace lamp - the connector is located under lamp housing connector JA - measure the red wire and ground (any metal part) for 12v at turn on - if 12v replace fan - if no 12v check the power pcb
Oct 09, 2008 | Mitsubishi WD-62525 62" Rear Projection...
72'' mitsubishi model#73732
Feb 11, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-65737 Home Theater Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
