Question about Maytag MVWX600XW - Bravos XTM HE Top Load Washer
Mvwx600xw lid locks doesnt run - Maytag MVWX600XW - Bravos XTM HE Top Load Washer
I have a Amana top loader washer how do bypass the lid lock so it can wash?..It fill with water then the lid light just blinks because it doesnt lock.
Locate the switch by the lid and simply connect a wire between the two wires going to it to affect a bypass.
Nov 01, 2015 | Amana Washing Machines
Bravos X. Where is motor drive?
Manuals and Literature - Maytag
https://www.maytag.com/manuals/
MaytagSearch Manuals & Use and Care Guides. Enter your appliance model number to access your Use and Care Guide and any related appliance literature. Use the ...
Bravos X™ Top Load Washer with PowerWash ... - Maytag
www.maytag.com/-[MVWX600XW]-1101158/MVWX600XW/
MaytagBravos X™ Top Load Washer with PowerWash® Cycle. Ratings ... Instructions for unpacking and installing your appliance, including electrical requirements and .
Oct 08, 2015 | Maytag Washing Machines
WILL NOT AGITATE
Does the lid lock and fill with water?
Oct 28, 2012 | Maytag MVWX600XW - Bravos XTM HE Top Load...
I have a maytag Bravos MVWX600XW. I am having problems with the lid lock.
LID LOCK LIGHT STAYS ON NO START:
Usually either the lid lock mechanism, the lid lock actuator or the board is the culprit even a disconnected capacitor.
MACHINES SAIDS SENSING
When the START button is pressed, the washer will first perform a self-test on the lid lock mechanism. You will hear a click, the basket will make a slight turn, and the lid will unlock briefly before locking again. Once the lid has locked the second time, the washer
will slowly spin the dry load to estimate the load size, and begin adding water. The washer will then move the load briefly, pause to allow water to soak in to the load, and resume adding water. This process may repeat until the correct amount of water has been
added for the load. You may also hear water flowing through the dispenser, adding detergent to the load.
NOTE: The sensing light may also come on during the Soak and Wash portions of the cycle. This is normal.
Try unplugging the cord a couple of times. See what happens then try going into diagnostic error codes, see what codes are shown. To pin point where the problem is. if you have no display to read the fault codes. Your main control board may be the issue.
Next, while in Manual diagnostics, try to get the unit to spin; if the motor hums for a split second and then shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors.
This is proof that the shifter/sensor actuator assembly is the issue because the optical sensor is not reading the motor speed.
I suggest unplug the washer and check the wire connections on the switch. If a meter is available then you can check the resistance (ohms) of the lock motor.
Note: After performing the manual test and the lid lock works perfectly, or at least as it is supposed to. You can eliminate that as the problem.If the lock worked in the manual test but doesn't in an actual cycle then I suspect the control board is at fault.
A safety feature found on front load washing machine is the door switch and the door lock and strike. On most models, the door switch must be closed and the door lock must be activated before the washer will start. The switch is normally located in the door frame of the washing machine, but may also be part of the door lock assembly. Inspect the strike to make sure that it engages the door lock assembly and that the door remains closed. To check the door switch for continuity with a multi-meter, you will need to disconnect the power and remove the front panel.
The lid switch on a top load washing machine is a safety device designed to prevent the motor circuit from operating when the lOn some models, the water inlet valve circuit is controlled as well. If the lid switch fails, the washer may not start. The lid switch is normally located beneath the main top with a projection on the lid or a pin attached to the lid that will actuate the switch when the lid is closed. Verify that the switch is being activated mechanically and that any levers or actuators are not damaged or sticking. If the switch is being activated but there is no power being supplied to the motor or water valve circuits, then the switch may be defective
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
God is good and that's why I give free advice.
Sep 29, 2012 | Maytag MVWX600XW - Bravos XTM HE Top Load...
Maytag Bravos MVWX600XW won't latch or start cycle just blinks & then turns off
Your door lock assembly has gone bad. You'll need to get your model # and go to either www.apdepot.com or www.repairclinic.com or your local parts supply to pick up. To start the repair you'll need to lift the top up by taking the two metal clips, one on each side, and then pulling the top forward. Once that is done lift top and you'll be able to locate the lock located in the front. Once you find the lock follow the wires back and you'll see that they go back and then upwards. Set the top back down and then remove the back of the control panel, which are 1/4 screws I believe. Located the wires from the lid lock switch and see where they connect on the control board , from behind, it shoould be on your left side close to you. Disconnect the wires and now you can remove the lock safely. Install new lock and put the machine back together;
Jun 18, 2012 | Maytag MVWX600XW - Bravos XTM HE Top Load...
Wont wash, door lock light coming on
This could be caused by a bad lid lock, or something that controls the lid lock like the RPM sensor that is located in the shifter in some models. If the motor control doesnt know that the drum has stopped you could get an error like this
Oct 25, 2011 | Washing Machines
Washer will not start. Start button flashes but lid is not locked
If the lid lock light is flashing, that is an error. If the lid doesnt lock it won't do anything. There is a diagnostic test that you could do to prove it if you are good with electronics and ohm meters. Most tecks would probably tell you to replace the lid lock assembly. That is probably the cheapest part. The only problem is that without the diagnostis test it could be somthing else. But first check to see that the wire that comes from the lock is securely plugged into the control board.
Oct 21, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
2000 Lexus ES300 trunk lid does not fit right on 2001 Lexus ES300
Hi, try loosening the catch on the trunk lid but do not remove it and the lock mechanism, close the trunk lid but not fully, then pull the backseats down and climb into the trunk. Adjust the lock and latch until they meet up and lock together ( This will take some time and patience is essential). Fasten the Catch and Lock back up. Then retry opening and closing, if it still doesnt fit just do the same again, just needs a bit of adjustment.
hope this helps. jonno
Apr 21, 2009 | 2001 Lexus ES 300
Problems with "easy-lock" lid
i noticed that the lid doesnt neccessarily "lock" into place, rather sits in there, next to those tear drop looking things.
Dec 06, 2007 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Maytag MVWX600XW - Bravos XTM HE Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
