Question about Activision Skylander Giants Starter Pack Wii Game Activision
Wii skylander giants disc says unreadable
Says unable to read disc right out of the box for skylander giants wii
Why my wii skylanders giants won't read cd
This will depend on a few things.
1. If sky landers is the only game that will not work then it is likely that it is scratched or damaged in a way that makes it difficult to read. You can buy special cleaner for your cd to help with this if the damage is moderate to minimal. Or use a home remedy like tubing a banana on the side to be read and wiping it all off with a microfiber cloth and giving it a quick rinse (never submerge) and drying. The banana fills in some of the scratches.
2. If you wii has a hard time reading any disc then you should buy a cleaning disc meant to go inside the wii and clean the reader. One designed for computers and CD players should work just fine.
May 13, 2014 | Activision Skylanders GIANTS Starter Kit...
Will not read disc
The disc is probably scratched, if it is I would recommend buying the game again. If not then see if any oher discs are not working if others are messing up as well then it may be an issue with the wii.
Apr 19, 2014 | Activision Skylanders GIANTS Starter Kit...
I have just brought the skylanders giants wii starter pack,when I start the game and it asks for me to put a figure on the portal nothing happens
Are batteries in the portal, is it synced with the console. To sync remove battery cover and SD card cover on the Wii press the two red buttons at the same time they are now wirelessly connected.
Aug 11, 2013 | Skylanders Wii Gaints Starter pack
Trying to get started with the skylander giants game on wii, console will not read disc, any other game works fine, not sure what to do now
Check that it is the correct region format Eg: PAL or NTSC depending on country, If after you have checked this and it is correct then it could be a simple case of faulty media. To check if it is faulty media check the disk in anotherr Wii console if possible. If all else fails contact the store at which you bought it or the software company that has distributed or made the game. I hope this helps.
Jan 12, 2013 | Video Game Consoles & Games
We can't get to the next level of Skylanders giants.
What do you mean by "no longer being read" ?
If it that error "Disc is unreadable" that is the problem, you have to check your disc, because it might have scratches, dust or some gore that shouldn't be there.
If that is the problem, you should remove whatever is on the backside with warm water and gently rubbing it of with your fingers (not nails!). If you have scratches, and nothing else, then you must either get a new copy of the game or you can try something that might sound very weird, but CAN work.
- Remember that if you try to fix the game by yourself, it's at your own risk! -
If you want to try fixing those scratches you must get some toothpaste, yes toothpaste.
Then you take some of the tootpaste on your finger (remember to not hit the disc with your nails!) and gently rub it over the disc, apply more toothpaste if you can't get it over the whole disc.
When you have done that, you'll get all the toothpaste of the disc, using nothing but warm water.
When that is done, you'll just let it dry, place it on a towel or something like that (with the BACK side up).
And when it is dry, you just put it in your xbox and play the game! It usually work, I've done it with 3-4 games, and all of them worked atleast for 2-3 more weeks. :)
Jan 07, 2013 | Activision Xbox 360 Skylanders Giants...
My wii console can't read my wii U skylander giants disc
I can only pray this is a joke question. Wii ISN'T wii U. That's whyit wont work. It's like putting a wii disc into a ps3.
Dec 01, 2012 | Activision Skylanders Giants Starter Pack...
Wii "unable to read disc"
If Wii gives Unreadable disc, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 04, 2008 | Nintendo Wii Console
Unable to read disc message
Could be a damaged disk (check closely), a bad disk (did it work before) or your lens could be going out (which makes it unable to read the disk). Have you tried putting another disk in to see if you get the same problem?
Jul 19, 2008 | Nintendo Wii Console
Activision Skylander Giants Starter Pack Wii Game Activision Logo
133 people viewed this question
Top Activision Video Game Consoles & Games Experts
Zhenya Ogorodnikov
James Wishart
ray gallant
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
