Question about Mitsubishi WD-73737 73 in. HD-Ready TV
Mitsubishi TV model 65737 code 37, all fan running, Tv stop and red light blinking
  • 179 Answers
SOURCE: Mitsubishi wd52525 shows error code 37
error code 37 is either the dmd fan or the lamp fan. you can see the dmd fan with the cover off. you cannot set the lamp fan as it is under the light engine. I guess the easiest thing to do is get a lamp fan 299P282010 and a dmd fan 299P283010 and change them both.
Posted on Nov 17, 2008
taran_2005
  • 10515 Answers
SOURCE: I have a WD 65737
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems, to activate this turn the unit on let it shutdown then press the input/or device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times.
Let me know,so that we could Proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 11, 2010
  • 62 Answers
SOURCE: MY mitsubishi model LT52246 went blank on me and
means the 12 volt line has a short some place. Look towards the inverters first.
Posted on Nov 04, 2010
Testimonial: "thank youso much on what board are the inverters located I have the manuel for this tv?"
SOURCE: mitsubishi WD-65737 DLP TV. TV powers on, green
I had exactly the same thing happen..I contacted Mitsubishi and they said the software needs to be updated..they are going to send me the link to download the software.
Posted on Dec 29, 2010
ladywinn
  • 5138 Answers
SOURCE: my 60" dlp mitsubishi tv
Sound /No picture- Have you replaced the Lamp?
If Not, First make sure fans are running when Tv is Turned on .Then if fans are OK ,Most common reason is the Lamp.
What is the Model # that is printed on back of TV?
Posted on Feb 20, 2011
Wd-60737 mitsubishi blinking yellow status light ?
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Oct 25, 2012 | Mitsubishi WD-60737 TV
Mitsubishi dlp tv model wd-62627 wont power on when i plug tv in green light flas then will stop then i try to power on tv after after green light stops flashiing after oabout 30 sec red lamp light co
Inspect the lamp first to see if shattered--set has a self check feature also:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
33 = Air filtercover is open.
44 = DVI cablebetween FMT and Engine disconnected
May 30, 2012 | Mitsubishi WD Televison & Video
Tv doesnt show anything
Got (if model listed is correct) any blinking lights?
Set has a self check:
Here's something that might also be useful. After you turnon the set, and get the regular red blinky lights, hold down the Device andMenu buttons together for about 5 seconds.
May 29, 2012 | Mitsubishi WD65737 65" DLP TV
Shuts Off with a blinking red light
Lamp used is first suspect in model indicated here WD-65737.
If cover is removed first (rear) look to see if a lot of dust and or dirt on fans (3) or at rear of set. Set intakes air from front of set and exits it from rear--a lot of these when in our shop first get a air clean outside with a compressor to clear all dust out.
If not the lamp or dirt suspect number two is the ballast that powers the lamp---set even if it does not power up should have a self check--press and hold menu and input (device) at same time for at least 5 seconds and release both--
44 = DVI cablebetween FMT and Engine disconnectedLet me know what you find.
Apr 23, 2012 | Mitsubishi WD65737 65" DLP TV
When i press power button green light comes on and then red light blinks 2 but the tv does not turn on
Question title shows it is Mitsubishi WD-65737 tv.
When did you replaced lamp in tv?
If lamp has not been replaced in last 2-3 years, please check lamp as it seems dead, that is why tv does not turn On.
Aug 26, 2010 | Mitsubishi WD65737 65" DLP TV
Nov 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
I have a Mitsubishi WD-62525. This morning my TV would not turn on so I pressed the rest button. After the Timer light stopped blinking I pressed power. I could hear the fans start than a somewhat loud...
the status light blinking red means a fan (the unit hs 4 of them) has failed. you need to determine which one. use the self diagnostic function:
Error Code Operational Check
Note:
The TV must be in “Shut Down” and not manually switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Press the front panel “DEVICE” and “MENU” buttons at the same time, and hold for 5 seconds to
activate the Error Code Operational Check. The LED will then flash denoting a two digit Code.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
Example: If the Error Code is “32”, the LED will flash three times, pause, and then flash two times.
• The Error Code is repeated a total of 5 times.
and read the code.
35= Chassis Fan failure
36 =Exhaust (Back Cover) or Lamp Ballast Fan failure
37= Engine (DMD or Lamp) Fan failure
Nov 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD52525 DLP Projection TV
Jan 29, 2008 | Mitsubishi WD62628 62" Projection HDTV
Mitsubishi WD-73737 73 in. HD-Ready TV Logo
54 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
