Question about HP Computers & Internet
My Hp Pavilion dv9000 laptop will not boot.
Led lights come on, can hear fan briefly,screen remains black. I was finally able to get into BIOS setup utility, tried to run self test (result: test status - No IDE Device) I tried changing boot order to hard drive in 1st position. Eventually got it to boot up,ran any and all Hp and Microsoft updates. Could not find a functioning restore point. I believe boot up issue started after trying to download converters so MS word could read a newer version of MS Word doc. Just changed boot order to CD and did start up with Recovery Disk in CD slot. Forced it to boot up, what can I do to resolve boot up issue at this point now that I'm back in?
    Sergeant:
    Habit-Forming:
  • 149 Answers
You have more patience than I do. I'd load Linux on a flash drive (Mint or Ubuntu MATE are my current favorites) and see how well it ran on those, then install. HPs usually run Linux perfectly. You're not still running Vista, are you?
Most Linuxes come with LibreOffice so you can read and write all Microsoft proprietary formats; you can set it to save in .docx by default.
Posted on Apr 06, 2017
5 Suggested Answers
Teh_shivers
  • 104 Answers
SOURCE: broken power button on HP pavilion desktop
ok check this out, follow the two wires that come off the power switch to the motherboard, just take a flat head screwdriver and touch those two pins together and your pc will boot up. and to fix this all you have to do is go to your local pc shop (not some place like bestbuy) and ask them for an atx power switch, its an easy fix, if it doesnt fit exactly there is always hot glue.
Posted on Dec 14, 2008
SOURCE: no monitor display
this site
http://www.ultimatebootcd.com/download.html
is a link to Ultimate Boot Cd
this is a bin file to be burned as boot Cd
it contains a various tools including hardware check (google it!)
hope it helps
feed back
Posted on Apr 06, 2009
  • 4 Answers
SOURCE: HP PAVILION DV9000 COMPUTER STARTS BOOTING UP AND THEN STOPS.
here is the only solution available on net:
give it a try:
http://amritbera.blogspot.com/2009/09/solved-hp-infinite-restarts.html
enjoy..
Posted on Sep 10, 2009
LaptopExpert
  • 458 Answers
SOURCE: upon boot up, screen remains black,disk power up briefly
HOW TO FIX YOUR DV6000/DV9000/DV2000/tx1000/tx2000
All the Problems described are Graphics Related..
Faulty Nvidia Chip..Both Intel And AMD Based Motherboards..Though More Common on the AMD..
The symptoms of the Laptop Powering on and Shutting Off Repeatedly..Or.. Powering On and Having No Video...Or... Power Strip Lights Up, Beeps,Shuts Down...Or..No Power At All...Or.. Intermittant Loss Of Wireless/Video Goes In And Out/Touchpad Slows and Freezes..
To Fix this issue, You will need to Reflow The Graphics Chip.
I will Explain In Full Detail As To The Correct Method Below....
HP DV6000/DV2000/DV9000 Compaq v2000 Video Chip Reflow Instructions
First Step Is Complete Disassembly Of All Parts And Components..
Remove RAM, Remove CPU, Of Course Remove Heatsink and Fan assembly.
Next Step is Insulating the Motherboard... You need to Protect The CPU area, The RAM area, Cover any plastic Plug ports.
Try to leave 1/4 inch area around the edge of the chip free of insulation.
To Insulate the Board.. I use thick pieces of Tin/Aluminum, you can fold up some aluminum foil (tin foil) About 4 folds thickness....
Now that you have your Motherboard Insulated... Make Sure There's Nothing Flamable Or Burnable Below the Motherboard... it will get quite hot underneath.
You will need a Heat Gun.. You can get one of these at your Local Home Improvement Store, they cost about $15 - $30.. You Will Use ONLY the LOW Heat Setting... I REPEAT..... USE ONLY THE LOW HEAT SETTING ....
Next You Will Need Some Coins.. Yes Coins..
8 Quarters and 2 Nickels... Put the 2 Nickels On the Bottom and Stack Quarters On Top...
Place The Stack Of 2 Nickels And 8 Quarters On Top Of The Graphics Chip...
The Reason for using the Coins: Using the coins serves a few purposes...
1) It Helps Transfers the heat Into The Chip More Evenly/Slowly
2) It Helps Hold The Heat Longer/Then Helps To Cool Slower
3) It Gives The Correct Amount Of Weight That Is Needed To Press The Chip
A Thing To Look Out For...
Hewlett Packard is nutorious for using the RED epoxy around the edge of the Graphics chip.. this epoxy is used to help secure the chip to the motherboard...
This is a process that is Hand Done at the Factory.. And Some Boards Will Have Only A Little Amount of this, Some Will Have Alot of it...And Some are Only Done On The Corner Edges....
If There Is Alot of This On Your Chip, You Might End Up Needing To Carefully (REAL CAREFULLY) Remove as much of this epoxy as able to....You can use a Razor Blade To Lightly Scrape This Off... DO NOT MISS AND SCRATCH THE MOTHERBOARD!!! Go SLOW...
Now Comes The Heating Of The Chip...
Start With The Heat Gun About 6 Inches Away From The Top Of The Quarter Stack..You want to be holding the gun at a 45% angle.. Aim the heat at the Edge of the chip, You Will Start Rotating Around the Chip- around the outer edge of the chip...then use tighter circles concentrating on the quarter stack, then after about 30-40 seconds, slowly move closer to the chip...
Never Move the Heat Gun Closer than the Top Of Your Coin Stack...Then Pull It Back And Slowly Repeat.. The Chip Needs To Get Hot Enough To Re-Melt The Solder Balls On The Underside Of The Graphics Chip Back Down To The Contact Pads On the Motherboard.. and this takes Quite Alot of heating to Do.... You Must Not OVERHEAT the CHip... It Is Best To Underheat it and have to Redo.. than to overheat.. It will cause the solder to break down and even crack/split.. causing failure forever...
This process will take about 3 minutes total.. Once you shut off the Heat Gun.. Leave The Stack of Coins On The Chip And Let Sit For Another 5 minutes..
Now Remove The Coins(carefull they might still be hot)
Remove All Insulation.. Reinstall RAM, CPU, Heatsink and FAN Assembly (and Of Course Thermal Pads or Paste.. Note:. If Paste Is Used.. It Must Be Silver Paste...
Now You Can Connect The Power Button Strip/ Video Cable And The DC Jack Cable.... And Plug In AC adapter .. You're Now Ready To Test For Solid Power and Video....
Upon Sucessful Chip Reflow/Rebake.... You Need To Go To The HP Website..( www.hp.com )..Click on SUPPORT AND DRIVERS, then select...DOWNLOAD DRIVERS AND SOFTWARE....Then either click the box to Auto-Detect System, Or Enter Your Make/Model Info, Once At The Page With All Of Your Drivers.... Choose The BIOS UPDATE Driver..
Choose The Newest Driver And Download/Install It... It Will Reboot The Laptop And Upon Rebooting, Your Fan Will Spin Faster And More Often Due To A Thermal Controller Update In The BIOS Update...
Posted on Dec 04, 2009
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
Hello i have an hp Pavilion dv9000 laptop. I use
yes, i would definately try removing the memory modules and blow some forced air into the connectors as well as using alcohol on a q-tip to clean the module contacts before inserting them back into the board. If it still does not properly boot, try removing one module making sure the remaining module is seated into the #1 slot, and reboot. If it does not boot, remove and replace with the other one, leaving that one out, reboot. If, at that time, it boots, you now know which module, if any, are bad.
Jul 08, 2010 | HP Pavilion dv9000z Notebook
Have you tried removing the memory 1 stick at a time?
Jul 06, 2010 | HP Pavilion dv9000z Notebook
Laptop is having trouble booting up.
HP Limited Warranty Service Enhancement - HP Customer Care (United ... If you own an HP Pavilion dv2000, HP Pavilion dv6000, HP Pavilion dv9000 or Compaq .... Willthere be a future BIOS release that does not make my notebook fan remain ... Black Screen Error Messages that may Occur During Startup or Boot ...
h10025.www1.hp.com/ewfrf/wc/document?docname...lc=en...
Apr 05, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
My laptop screen is black. All light across the
Do you see the BIOS boot up phase, which is the bit in the beginning of booting the computer where you see DOS like white text on a black background?
If you do, there is a good chance that your problem is as simple as a Windows configuration issue. If not, you may have a short in the wires that connect the screen to the motherboard.
The first thing to try is to connect the computer to an external monitor and see if it will display.
Next, try booting in safe mode.
Then try booting from a CD.
It is possible to replace laptop screens, but it is usually not worth it.
Dec 02, 2009 | HP Computers & Internet
My hp dv9000 will not boot. when power is turned on all leds light up screen stays black. hard drive and fan can not be heard. restarts after 10 seconds with no error message or flashing lights.
Remove the hdd cover from the bottom and make sure it is completely seated and connected. If the hdd is properly installed and it still will not boot, try entering the CMOS Setup. If you can enter setup you most likely have a bad hdd. If you can't you need to take or send the pc to a repair shop.
Oct 06, 2009 | HP Pavilion dv9000z Notebook
My hp pavilion tx1000series won't boot even at bios
EXTREMELY common failure in the TX1000 line. Problem is the mainboard, part# 441097-001. From HP it should only be about $200 on exchange. DO NOT get this part anywhere else, as the OTHER common failure for this model is the wifi goes out.
I do about 10 of these TX's per day, no im not kidding, and i promise you HP has the most stable parts source around for this.
-Sy
Jan 18, 2009 | Eizo I-Station Networking Hub
DV9205eu display problem
HP has identified a hardware issue with certain HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario V3000/V6000 series notebook PCs, and has also released a new BIOS for these notebook PCs, version F.39 for dv2000/V3000, and version F.3D for dv6000/dv9000/V6000.
Click HERE to update your BIOS
May 03, 2008 | HP Pavilion dv9000z Notebook
DV9000 issues
hey, so ir dv9000 doesnt boot to hp logo screen & restart itself,first replace the cmos battery if thisdoesnt solves ur problem, the next time u boot check whether the rj45 & the dial up port give a led flash on start or not ,if not then u may have hape board ,cpu or power problem ....which can be fixed by repair only.
Nov 30, 2007 | HP Pavilion dv9013cl Notebook
Computers & Internet Logo
71 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
