Question about ASUS U36J SMB PC Notebook
Asus u36j fan cleaning - ASUS U36J SMB PC Notebook
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: Asus U36J
Try installing the latest wireless driver.
You can download the device drivers from ASUS WEB site.Select your model motherboard/computer/laptop, and make sure you select driversthat matches your Windows operating system. Please click on this link to theirWEB support site : -http://support.asus.com/download/download.aspx?SLanguage=en-us
Posted on Feb 24, 2012
Asus m32 rebooting randomly
Check to see if your PC is over heating which would normally cause the fan speed to increase. Overheating will cause it to shut down unexpectedly. Cleaning all the dust from the power supply and vents will prevent overheating. Make sure the fan IS running.
After you back up your data, run disk diagnostics on the hard drive to fix any bad sectors.
Nov 05, 2014 | ASUS M32BF-US005S Desktop
Clean asus all in one fan
Two possibilities: Either the fan is really dusty or the bearings are worn out. The easiest way to clean the fan is to get a can of compressed air and blow the dust off. If it doesn't help you might need to replace your fan...
Mar 28, 2014 | ASUS All-In-One Pc Et2700 Series, I7 27"...
Asus U36J
Feb 23, 2012 | ASUS U36J SMB PC Notebook
The cooling fan does not work anymore. It made a weird sound and since then has not worked. netbook gets very hot now. How can I fix it?
The fan hasn't been cleaned and oiled so it jammed. You will need to dismantle the netbook and clean the fan. For that watch this
http://www.youtube.com/watch?v=yehHh0GmnU0
Aug 07, 2011 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
My ASUS laptop F8OL always shutdown when temperature rises on top of my keyboard on the left handside but my ASUS NB Probe did not give a warning and itsays Normal, can you help me out
Your laptop shuts itself down to due to overheating. It does this to prevent damage to your components. This may have been caused by one of a combination of the following reasons:
1. Faulty fan.
2. Dust preventing the fan to supply enough air into the board.
Solution: Clean or replace the Fan.
Cleaning the fan isn't a job for the rookies so I suggest you take your laptop to the computer repair shops and have them service it. Unless you know what you're doing. This procedure can damage your laptop entirely.
Hope this helps.
May 06, 2011 | ASUS Computers & Internet
My ASUS P5GD2 doesn't passes the BIOS Logo. It's not possible even to press the delete button to enter the BIOS setup. What can I do?
remove the cpu fan and and clean the surface with soft cloth and spread a thin layer of heatsink solvent and place the cpu fan tigthtly and lock them then remove the memory card and wipe it clean with cloth and insert to the slot also dont forget to rest your bios
Oct 29, 2010 | ASUS P5GD2 Deluxe Motherboard
Asus f3t with vista will not start fan does not run only one flash of hdd led
hi dear, check thair is somthin inside fan like dust open
& clean it will work
Feb 02, 2010 | ASUS F3T-AP042C Notebook
While using my Media Center PC sometimes I get loud beeps from the MB. It seems to happen when a lot of memory is being accessed ( watching and recording a TV show at the same time ) or when the harddrive...
Your ASUS motherboard uses an Award Bios. Open the link provided;
http://www.bioscentral.com/beepcodes/awardbeep.htm
Check the beep codes listed.
Everything you mentioned can easily point to a possible overheating problem. Try cleaning your system fans. Everything electronic will attract dust and dirt which makes your parts run hotter.
If your PC is sitting on the floor the attraction is increased.
Use canned air if you do not have a air compressor. (Do not touch the fans blades while their turning during cleaning), they will break. Pull your system memory and than reseat it. If the loud beeps continue you might consider installing a bolder fan that pulls more cooler air into your case. If your CPU heatsink and fan assembly is clogged with dust you may consider replacing it. Your ASUS motherboard will shut its self down if your system gets too hot. Your ASUS MB also has a bios setting that allows you to check just what the tempture is. See page
4-36 section 4.5.4 in your manual. It wouldn't hurt to install, ASUS PC Probe II from your ASUS CD.
Happy holidays
Mike
Dec 11, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
ASUS M50SV fan cleaning
Usually if the fan and heatsink is not accessable from the bottom of the laptop behind a vent then the fan is accessed by removing the keyboard.
Aug 12, 2009 | ASUS NB | M50SV-A1 RTL PC Notebook
ASUS U36J SMB PC Notebook Logo
115 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
