Question about Acu-Rite Measuring Tools & Sensors
My acurite 590A1-RX is flashing low CW what does that mean? It looses the outside temp alot
Also says it is on channel one
2 Suggested Answers
SOURCE: acurite 1097-rx will not display outside temp or
I had same problem. Take all batteries out of both units. Put the batteries in the remote sensor FIRST. Then put batteries in the main unit. Within five minutes, they will link up. Problem solved!
Posted on May 11, 2010
Flashing emblem by outside temp on acurite
The symbol probably is indicating that the outside transmitter is sending temperature data.
May 22, 2017 | Measuring Tools & Sensors
Why can't I receive input from the outside sending unit?
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
Jan 07, 2016 | Measuring Tools & Sensors
I have an Acurite 822-RX thermometer that shows HH as the outdoor temp, even after replacing the batteries in both the base and remote units. How can it be fixed or reset?
Usually those symbols mean your out of range of the instruments range . Do you have the sensor in direct sun light ? There may also be a defect I would try to contact them
Mar 10, 2015 | Measuring Tools & Sensors
My acurite model75321a1 does not tell out side temperature
I checked my Acurite instruction file and found it rather vague about this issue but based on my experience with a similar system I found that battery changes have to be made at the transmitter first, allowing time for the transmitter to begin sending temperature data. Also, the Acurite instructions suggest use of lithium batteries in the transmitter where extreme low temperatures are encountered. My experience has been that the transmitter stops working at low temperatures so the reading comes and goes depending upon the weather. Currently it is 20 degrees F outside headed for 5.
Feb 01, 2015 | Measuring Tools & Sensors
Model 00754W4 does not sense outside temperature..new batteries have been placed correctly in both inside and outside units..noW what do I do?
We would recommend a reset of your unit. Please verify that you are using good-quality, standard alkaline batteries such as Energizer or Rayovac, then follow the steps below.
1. Bring both the sensor and display unit indoors and remove at least one battery from each.
2. Make sure the A-B-C switch on both units match. Sometimes changing to a different channel can help.
3. Reinstall the battery in the outdoor sensor.
4. Reinstall the battery in the display unit.
5. Let the units sit within a couple feet of each other for about 20 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or info@chaney-inst.com.
Dec 03, 2014 | Acu-Rite Acurite Wireless Indooroutdoor...
HH means it is showing the high temperature you (most likely accidentally) set with the MAX MIN / + button, which is easy to do when setting the clock. Just press that button again until the reading appears.
Jan 15, 2011 | Acu-Rite Acurite Wireless Weather...
I put new batteries into both units, the indoor unit and outdoor unit, now it is not able to read the outdoor temperature. What needs to be done?
I'm having the same problem and can't find an answer. Seems this also happened with another model we had - planned obsolescence? It was working fine, flashing due to low battery. Now, nothing from outside. Annoying.
Oct 16, 2010 | Acu-Rite AcuRite IndoorOutdoor Wireless...
Acurite 1097-rx will not display outside temp or humidity. new batteries. Inside functions normal.
Feb 23, 2010 | Acu-Rite Audio Players & Recorders
Measuring Tools & Sensors Logo
Top Acu-Rite Measuring Tools & Sensors Experts
windryder
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you an Acu-Rite Measuring Tool and Sensor Expert? Answer questions, earn points and help others
