Question about Masterbuilt 20070910 30 Inch Electric Smokehouse
Masterbuit smokehouse 20070910 wont stay at set temp.set for 190 and buids up to 275 heat light is off but still building heat
New unit after seasoning next day set temp to 190 to start smoking and temp went to 190 ok ,heat light went off and unit continue to build heat to 275,
How do I preheat this toaster oven
Set your temp. Turn oven on. Wait. That's how you pre-heat a toaster oven. There aren't any that I have seen with a specific "preheat" setting.
Dec 31, 2015 | Toaster Ovens
The oven does not heat up when I turn it on. what is wrong with it?
could be one of several things or several ,timer , switch ,element, fuse and on and on
Mar 17, 2015 | Toaster Ovens
Power light is out and the oven doesn't heat
He calls himself an electrician ?!? LOL!!!Not very good. He could have at least checked to make sure there was continuity in the unit or opened it up and made sure there were no loose connections. As for that sustaining ticking sound, it is because of a spring loaded mechanism.
Nov 08, 2013 | Hamilton Beach 31199xr Countertop...
Power light out and doesn't heat
Ticking sound when unplugged? It sounds like a mechanical timer. Check the timer / control setting is actually on a cooking cycle. The unit may be set on delayed start? If there is no power to the unit, there may be a fuse inside it. You may have to take the back / side off to see.
I have a new GE Covection Toaster Oven model 169127/169140. My question is should this oven's heating elements shut off periodically when the set temperature has been reached?
YES this is normal it is how it regulates temp by cycleing the elements ......................Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Mar 01, 2009 | GE 168947 Toaster Oven with Convection...
Broiler element
Its an on or off thing. No way to control the flow of electricity.
The elements are bigger than necessary to heat the unit quickly, the problem you have is a bad thing with food that burns easily but a good thing that makes these units come up to temp so quickly after turning on.
Unfortunately the only thing you can do is put more space between the element and your food or use aluminum foil (not suggested, its too close to the burners).
Eventually the contacks will fail (unless you are one of the lucky ones).
Good Luck
Feb 03, 2008 | Cuisinart TOB-30 Toaster Oven with...
KitchenAid toaster oven Mod# KC010058
The overload switch is located above the theromostat.To check it put a jumper across the switch and plug the unit in. If the switch is bad you will now see the red light on and the oven will work. Take the switch off and gently pry the 4 posts back. Remove the pin, gently put it in a vise and put a drop of solder on top of the metal cap. Put the switch back togther, install it and you should be back in operation.
Oct 21, 2007 | KitchenAid KCO1005OB 1400 Watts Toaster...
Not Heating
I just opened one with the same problem. The bi-metal switch / thermostat was completely burned out and melted into a small lump of metal. Unless you can get a replacement for that it might be the cheapest to go to a store and buy one new for under $80.
Aug 24, 2007 | Hamilton Beach 31197 120 Watts Toaster...
Masterbuilt 20070910 30 Inch Electric Smokehouse Logo
23 people viewed this question
Top Masterbuilt Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a Masterbuilt Toaster Oven Expert? Answer questions, earn points and help others
