Question about Cobra 148 GTL 120-Channels Base CB Radio
I have 148F AND IT HAS 5 PLUG ON THE MIC INSTEAD OF 4 PIN
I have a 148f and i cant find a manual(user) for it, also it has a counter. the mic has 5 pin insteads of 4 pin like the 148 gtl any info would help
  • 1 more comment
  • jc_61990 Sep 02, 2008
    i have a cobra mike and dont know how to wire it to my cobra 29
  • Anonymous Nov 27, 2008
    i have 148gtl and the only place ive found one is iowa 80 truckstop in walcot ia and need new one now and am looking for one now
  • Anonymous Dec 08, 2008
    wire 4 pin cobra power mic to a 5 pin cobra gtl
Or try this it's the wireing for the 148GTL which should be the same. Pin-1 White, Pin-2Shield, Pin-3 Blue, Pin-4 Red, Pin-5 Blk
Posted on Jul 07, 2007
  • 398 Answers
1 - shield, 2 - audio, 3 - rx, 4 - common, 5 - tx
Posted on Jun 26, 2007
CB Uniden 4-wire mic to a Uniden 510 radio how to wire color codes please
look up microphone wiring diagram for your cb and mic. more than one way to wire, depending on mic and cb having 4 or 5 on plug end. write down mic numbers and cb plug numbers. if audio on mic is 3 and cb is 4 put 3 on 4 pin check each wire. using power mic make sure red and black wire are on the right pin, can damage radio or mic or both.
Feb 11, 2018 | Uniden Radio Communications
Wire 4 pin Turner Plus 3 Power Mic for cb radio to 5 pin President Washington SSB AM Radio
the best i can find is this
red pin 5 ptt
black pin 4 ptt ground
white pin 1 mic
shield pin 2 mic ground
no connection pic 3
Jan 19, 2015 | Radio Communications
How to wire a mic
This might help as I don't have a color code for the mic. Radio pin code; 1 - Audio -2 - Shield - 3 - Receive - 4 - Sw. Wire -
5 - Transmit
MIKE WIRING GUIDE
Found this by Google searching;
5 Pin Mic Plug Model
Pin #1 Audio Output / White
Pin #2 Shield
Pin #3 Receive / Black
Pin #4 Common / Yellow
Pin #5 Transmit / Red
Feb 01, 2014 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Moc plug 4 pin to a 5 pin
it's not possible to wire 4 wire mics to the uniden 5 wire radios without modifying the mic and replacing the mic cord
Jan 06, 2014 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Microphone wiring diagram
need a wiring for a aries echo mic to a cobra 148f gtl
Jan 01, 2014 | Audio Players & Recorders
I need to wire a silver salute mic to a cobra 142 gtl 5 pin what color wire goes towhat mic pin
dont go by colors.. go by what wires are on the switch and mic element.. mics can be rewired and no one told you the colors could have changed FYI..
Pin #1 ~ Audio
Pin #2 ~ Shield
Pin #3 ~ Receive
Pin #4 ~ Switch Wire
Pin #5 ~ Transmit
always go by connections not color of the wire. that way you learn and you can do any mic. to any radio.
Nov 30, 2013 | Radio Communications
I have a radio shack trr470 and I bought a cobra CA-76 power mic with a 5 pin conector instead of a 6 pin conecter by mistake .can I use this mic on this radoo .do you know what cooe wires form tje mic go...
according to the schematic I just looked at the mic for this radio is a 5 pin. As long as it is a plug in and not a din you should have no problem connecting it.All you have to do is re-wire it and be on your way.
Jan 18, 2013 | Radio Communications
When i plug in a mic, it wont work. under
You need to do the following
1. Open Sound & autido devices from controlpanel
2. Click Advanced button in Volume tab
3. Select properties from Options menu
4. Select Recording & press ok
5. Select External MIC instead of others
Aug 02, 2009 | Intel Celeron D 2.8GHz 478-pin 533MHz CPU...
Cb mic wiring
I have a browning golden eagle mark II. It has a two pin mic plug. I would like to hook up a astatic power mic to it. Anyone have an answer?
Oct 07, 2008 | Magnum DeltaForce CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
397 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
