Question about Canon PIXMA MP495 InkJet Printer
Canon mp495 printer problems
Ink cartridge replacemnet not recognised by printer
SOURCE: canon mp600 printer
MP600 Easy fix for unrecognized ink cartridge
Posted on Jul 18, 2008
SOURCE: Canon MP520 cartridge swap and ink refill
Canon MP520 multifunctional device - deactivation of the ink level counter
1. You can do it only when the printer counter releases the warning message - "the ink cartridge is nearly empty" = yellow warning mark
2. You have to do this procedure four times - for every cartridge one times
3. At the screen you will see three warning messages
- for the first one press "OK"
- for the second and third one press "Yes"
4. The fourth message tells you that you can do the ink level counter deactivation by pressing the "Stop/Reset" button (7) for more than 5 seconds. Do it.
Later you can see another type of warning message at the screen:
In this case you can not follow the previous procedure - there will not be any other warning messages.
Just follow the message on the screen and press the "OK" button (5) and you can print.
Unfortunately - I do not know for how long time it works.
You have to manualy check the ink level and refill (change) the cartridge before it is completely empty! You might brake your warranty!
When you insert the new original ink cartridge, the counter will work properly again.
Posted on Sep 14, 2008
SOURCE: will not print - ink cartridges not recognised, not installed properly etc
On my Cannon Pixma, I pressed the stop/reset for 5 seconds to ignore the warning. Then,
I was able to make a copy. However, better solutions to this scenario are welcome.
Cheers - Peter
phjohan@hotmail.com
Posted on Sep 16, 2008
Grubhead
  • 5056 Answers
SOURCE: Canon MP460 ink cartridge not recognised
Perhaps the chips in the cartridges have failed? In which case you may need to replace them with brand new cartridges. If that doesn't work you might need to send it for repair as the cartridges might have damaged your machine.
Posted on Apr 12, 2009
SOURCE: RECOGNITION OF GENUINE CANON INK CARTRIDGE
most probably has been damaged.
ink cartrigde is damaged due to followin causes--
1. over heating  of head due to bulk printing
2. mishandling the cartridge.
3. repeated refillings
try this if you want to use this cartrigde again, it may work
1.  clean the golden contact points with isopropyl alcohol of cartrigde as well as the cartridge holder
2. remove cartrigde and install again after some days
possibility of fault in printer is minimal,
Posted on Jul 02, 2009
My black ink button on my pixma mp495 printer is blinking. Why?
A B LED light denotes that the black ink cartridge is running low.
A C LED light denotes that the colour ink cartridge is running low.
If the alarm light is on (lightning bolt in a triangle) it should be accompanied by an error code.
Canon MP495 - Error Codes If the printer displays an error message, the following information should help to diagnose the problem.
The led screen on the printer will flash a letter E and will then be followed by two numbers:
Error Description More Info Error E02 The machine is out of paper or will not feed. Error E03 Paper jam or output tray is closed. More Info Error E04 The Cartridge cannot be recognised. More Info Error E05 The Cartridge cannot be recognised. More Info Error E07 Cartridge is not installed in the correct position. More Info Error E08 Ink absorber is almost full. More Info Error E13 The remaining ink level cannot be detected. More Info Error E14 The Cartridge cannot be recognised. More Info Error E15 The Cartridge cannot be recognised. More Info Error E16 The ink has run out. More Info Error P02 Carriage encoder error. More Info Error P03 Line feed error. More Info Error P07 The waste ink absorber is full. More Info Error P08 Print head fault. More Info Error P10 Print head fault. More Info Error 5100 Carriage Encoder error. More Info Error 5200 Print head fault. More Info Error 6000 Line feed error. More Info Error B200 Print head fault. More Info Error 5B00 The waste ink absorber is full.
Feb 24, 2015 | Canon PIXMA MP495 InkJet Printer
PROBLEM WITH CANON MP495 I CHANGED MY INK CARTRIDGES AND CANNOT GET THE INK LEVEL INDICATORS ON SCREEN TO RECOGNIZE THE NEW CARTRIDGE. IT STILL REGISTERS AS EMPTY.
the main problem is with the catridge, if you have check it with other printer and the catridge is working then you have to service your printer , you can try by clean the catrridge carrage with soft cotton . most of the time it work , if not then you have to replace it
Jun 07, 2013 | Canon PIXMA MP495 InkJet Printer
How do I change the ink cartridge in my canon mp495 printer
Make sure that the printer is plugged in and turned on. Close the document cover (if it is open). Lift the scanner unit and hold it open with the support on the right. Wait until the ink cartridge carrier moves to the ink replacement area. Pinch the tabs on one of the ink cartridge covers (front and back) and lift the cover up. Then pull the cartridge up at an angle towards you. Put the new cartridge in at the same angle. Then close the cartidge cover (it should click). Repeat this for the other cartridge, if needed. Lift up the scanner unit and then lower it down to close the printer.
Wait for the printer to do the print head cleaning before sending more jobs to the printer. (It will resume jobs in progress automatically.)
If it takes more than 10 minutes to replace the cartridges, the cartridge carrier will return to the home position. Close the scanner unit and then lift it back up.
I hope this helps.
Mar 21, 2013 | Canon PIXMA MP495 InkJet Printer
Canon mp495 e05
The E05 error indicates that the Fine ink cartridges are either not correctly installed or isn't recognized by the printer. Make sure that the correct CL-211 and PG-210 cartridges are installed. (Refilled or re-manufactured cartridges may not be correctly recognized.)
Check if the cartridges are in the correct slots and that the locking cover is fully seated. (Lift up the scanner unit, lock the support and wait for the carrier to stop moving before checking the cartridges.)
Replace the cartridges with new ones. If that doesn't solve the problem, the printer needs service. If it is under warranty, contact Canon. Otherwise, decide if the service is worthwhile. (There can be a couple of parts that could be at fault; however on this model they are not user serviceable parts.)
I hope this helps.
Jan 25, 2013 | Canon PIXMA MP495 InkJet Printer
Cannon mp495
The printer will detect if there is any cartridges that has run out of ink and will not print until the empty ink cartridges have been replaced.
Jun 27, 2012 | Canon PIXMA MP495 InkJet Printer
Error E05 on mp495
On or the ink cartridges has been detected as out of ink. You will get this error if you use manufactured cartridges
May 24, 2012 | Canon PIXMA MP495 InkJet Printer
What ink will my canon mp495 take?
Quikshiptoner is a good site for ink and toner that I generally use. It has black and color ink for the MP495. I'd just go there and search for the printer you need and it should come up with the correct ink / toner that you need.
May 11, 2012 | Canon PIXMA MP495 InkJet Printer
Canon PIXMA MP495 InkJet Printererror code 5200 problems
Here what I found for you. If it fixes your issue, don't forget to give me a good rate. Thanks
Print head temperature rise error or Error Code 5200
Condition: The print head temperature exceeded the specified value.
Problems and Solutions:
  • Turn off the printer and then turn on if error still persist replace Ink cartridge or print head thankyou for using
Aug 30, 2011 | Canon PIXMA MP495 InkJet Printer
Canon PIXMA MP495 InkJet Printer Logo
66 people viewed this question
old marine
old marine
