Question about Dodge 2009 Journey SXT
How to replace front lower ball joints 2009 Dodge Journey SXT
  • 333 Answers
SOURCE: upper and lower ball joints
Your better off have it done bt a tech because you need a press to press them out and in. Also you will have a warranty witk the work. You want to be safe messing with your steering and suspension. I hope this helps.
Posted on Dec 05, 2008
  • 160 Answers
SOURCE: 1997 DODGE RAM 1500
 just tare the axels down and pull the brake callipers and brake disks, to get to the ball joints. un bolt the nuts and take the peice holding the ball joints in and  then press out . But you need a ball joint press if you wanna do it on your own
Posted on Jan 06, 2009
alicantecoli
  • 22095 Answers
SOURCE: Changing front ball joints on Dodge 2500 2005
can it not be done without removing the hub ?? dont think you can get hub off without removing the track control ball joint?do you have the right tools??
Posted on May 30, 2009
  • 72 Answers
SOURCE: Upper and lower ball joint replacement
to remove the axles, remove brake caliper and disc, remove hub assembly, the center hub/axle nut and...(there are i think 3-4 bolts on the back side of the spindle to remove the hub), you may have to force the hub off the spindle with a hammer or air hammer... once the hub is out the axle should slide out of the front differential allowing access to the ball joint nuts for removal...
Posted on Jun 12, 2009
jlisagearhea
  • 412 Answers
SOURCE: how do i replace the upper and lower ball joints
Dear Balljoint Replacer.....
This is a very labor intensive repair.The specialty tools that you need will be an air (or electric) die grinder, and an air hammer.If you already have these then GREAT!!! If not then be prepared to invest in a good $500 purchase for these tools.Once you get the vehicle up in the air and the wheels off then place jackstands underneath the frame and the lower control arms on both sides.Keep in mind to keep the jack stands underneath the lower control arms at all times because your suspension will be under load.Remove the brake calipers from both sides and swing them around and out of the way.....no need to break open the brake system....just swing the caliper and whole hose assy out of the way. Once tis is done its time to loosen and remove both upper and lower balljoint nuts...after that is performed then it's time to shock the spindle with a hammer to release the balljoints from the spindle.Your balljoints will then be ready to be removed.Now you have to take your grinder and score your rivets that hold your balljoints in on both the upper and lower so the top of the rivets are ground down to the control arm.Next take a punch and hammer the rivets in a downward movement to release the rivets and you can remove each balljoint like that.
The new balljoints install with nuts and bolts.Install is reverse of disassembly If you have any questions get back to me...HOPE I COULD HELP!!
Posted on Nov 17, 2009
Where is water pump located?
Follow the lower radiator hose to the water pump on the front of the engine.
It has a pulley on it that your fan belt go'es on and turns the pump.
It should also have a 1" heater hose that goes to it.
Hope this helps Mike
Jan 28, 2016 | 2009 Dodge Journey SXT
2010 dodge journey blows cold air on passenger side
Help with heating issues, blend actuator - Interior - Dodge ...
www.dodgejourneyforum.com/.../5304-help-with-heating-issues-blend-a...
Jan 13, 2014 - My 2009 Journey R/T is only blowing hot air out the driver side vents, while the other vents (passenger and rear) are blowing cold air ... Thanks Frogbox....keep in mind that the info is for the 2009 model and I guess it also applies to2010's. 2009 journy sxt heat/cool issue
Oct 16, 2014
Air Conditioning?
Dec 22, 2012
Rear heater A/C
Dec 22, 2012
More results from www.dodgejourneyforum.com
In a 2010 dodge journey why heat comes out just one side
Jan 10, 2016 | 2010 Dodge Journey SXT
Whats the part number for a front passenger side lower ball joint on a 96 dodge stratus?
SponsoredShop for Whats the part number fo... on Google
Moog K500007 Lower Ball Joi...
$33.26
Jet.com Moog K6117T Ball Joint
$27.79
Walmart Parts Master K9385 Lower...
$10.97
Jet.com Control Arm W/ball Joint Fr...
$59.70
eBay Ball Joint ? Lower/Upper...
$22.95
EPI Performa... Search Results
    Ball Joint - Lower at AutoZone.com - Best Ball Joint - Lower ...
    www.autozone.com/suspension-steering-tire.../ball-joint-lower
    AutoZoneShop for Ball Joint - Lower products with confidence at AutoZone.com. Parts are justpart of what we do. ... Duralast/Ball Joint - Lower, Part Number: FA1490 ...
    Dodge Stratus Ball Joints ' eBay
Dec 06, 2015 | Dodge Cars & Trucks
Why did the compass quit showing on the EVIC on my '09 Dodge Journey SXT?
Go to the dealer- The compass module is already installed in the car, however, the Infotainment system wasn't configured to acknowledge/control it. Have the technician flash an updated version of the software.
May 02, 2015 | 2009 Dodge Journey SXT
How do i replace a heater hose onn a 2009 dodge journey sxt
Go U-Tube type in 2009 dodge and there should be a video on how to solve your problem
Sep 26, 2013 | 2009 Dodge Journey
Clunking felt in steering column when driving 2009 dodge journey
you jack the car up and remove one of the front tires and check your tire rods and and ball joints for play, if so replace yourself or have serviced., if no, there may be a problem in the rack-a- pinion.
Sep 08, 2013 | Cars & Trucks
2009 dodge ram with squeak in front end
check your ball joints and sway bar links
Jun 10, 2012 | 2009 Dodge Ram 1500
2009 dodge journey
Dodge Journey owners please go to http://www.change.org/petitions/dodge-journey-s-defects sign and pass along please. Dodge had built and sold this car with defects that they refuse to fix, this is not the kind of quality we should expect.
May 21, 2012 | 2009 Dodge Journey SXT
Dodge 2009 Journey SXT Logo
669 people viewed this question
Top Dodge Computers & Internet Experts
Gene
D. E. Hev
Are you a Dodge Computer and Internet Expert? Answer questions, earn points and help others
