Question about HP Presario Computers & Internet
My desk top computer has booting problem
My computer has XP professional operating system but recently it has booting problem. When switched on it directly switches on and asks for F1 or F2 to press to continue. How can I avoid this? I want it as it was when I have to press power button to switch on the computer which then went to normal process of booting up.
  • HP Master
  • 32,281 Answers
The F1 or F2 takes you into the BIOS setting.
The problem could be a flat BIOS battery and the Date & Time needs to be set to the current date & time.
Replacing the BIOS battery with a new one will fix this problem. When you insert the new battery go into the BIOS setting and set the Date & Time.
Posted on Dec 30, 2012
  • 243 Answers
SOURCE: Bootup
Have you tried changing the cmos battery on the motherboard?
Posted on Jan 07, 2008
SOURCE: Dell OptiPlex SX260 PC Desktop User Guide
Can you post the error please?
Posted on Jun 21, 2008
Cytherian
  • 124 Answers
SOURCE: Dell GX270 Maxtor 7Y250M0
If you are getting bad block reports on your hard drive, it means that your hard drive media has suffered some degradation. It could very well be that some system files are being affected by this, thus continually triggering the problem. You may not like the suggestion I have, but it looks to me like the most solid solution (saving you hours and hours of troubleshooting).
Backup all files from your hard drive, save all of your browser shortcuts to backup files, then perform another Windows XP installation with a low level format of the hard drive. I know a PC specialist with many years of experience that says hard drives develop faulty areas over time and that every 5 years or so, it's just best to back up data from the hard drive and perform a low level format. This resets the device completely. If there are any faulty areas on the disk, they are skipped over--to the operating system, the drive will be perfectly fine.
This is not a guaranteed solution, but it sounds to me like it will eliminate a lot of possible culprits for you. Good luck.
Posted on Dec 30, 2008
  • 15 Answers
SOURCE: Strike F1 key to continue, F2 to run the setup utility
Please let me know what is the make and the model of the pc that you are using.. Also, go to the bios, under boot menu, make sure that you have hard drive as the first boot option.. For further queries please get in touch..
Posted on May 28, 2009
  • 1043 Answers
SOURCE: OverClocking Problem when startup my system
Most motherboards have settings that allow the board to try and overclock itself upon bootup. Take a look in your manual and it should lead you to the correct setting in the bios that will allow you to have the computer boot up in normal mode. Failing that, you may have to force the motherboard back to the default setup. There is a jumper you would have to move, then you would remove the battery from the motherboard. Check your manual for how to clear the CMOS settings if you need to do that step.
Posted on Jul 10, 2009
Every time i boot my computer it freezes and below the screen there is this " verifying DMI pool data, Update success, Boot from CD" what should i do with this problem?
Hi. You need to reinstall again your operating system windows xp.
power on your PC then press F2 or DEL to see BIOS SETTING need your first boot is CD or DVD-ROM press F10 to save and exit. insert your windows xp installer CD.if you see "BOOT FROM CD" press enter. windows xp begin installation please read instruction carefully.very easy understand
to restore your recent desktop.press R.
Jun 04, 2011 | Microsoft Windows XP Professional
After installing windows xp professional there is no sound
You will need to locate the mother board drivers and install them you should have a motherboard CD if you purchased the computer from new.if not you will need to find the make and model of your laptop or desk top motherboard and then go to the manufactures web site and down load the relevant drivers
I hope this helps
Andrew A
Apr 03, 2011 | Microsoft Windows XP Professional for PC
Dual op systems
in bios setup usually under security you can remove user passwords.
you get into safemode for 2000 and in control panel and remove it form users administrator account
If your not interested in to os systems then you can format
Mar 06, 2009 | Compaq Armada 3500 Notebook
I have a dell 2350 desk top my window xp sound device just stop
go and reinstall ur audio driver to solve ur problem or get ur Xp reinstalled to solve the problem
or it is not a s/w problem its a hardware problem then show it to a professional
Feb 18, 2009 | Microsoft Windows XP Professional for PC
Hello, I have 2 Operating Systems in a computer namely Windows XP(SP3) in C:\ & Windows Server 2003 in D:\ . I've deleted the file BOOT.INI accidentaly form X:\ drive(X:\ means all drives like...
That's not a virus. Boot.ini is a default file needed for Windows OS to boot.
Fortunately, you can recreate the boot.ini files
This is a sample of the above Boot.ini file with a previous installation of Windows 2000 on a separate partition. [boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Windows XP Professional" /fastdetect
multi(0)disk(0)rdisk(0)partition(2)\WINNT="Windows 2000 Professional" /fastdetect
Simple way to add operating system on a separate partition:
At the command prompt, type: bootcfg /copy /d Operating System Description /ID# Where Operating System Description is a text description (e.g. Windows XP Home Edition), and where # specifies the boot entry ID in the operating systems section of the BOOT.INI file from which the copy has to be made.
Dec 28, 2008 | Microsoft Windows XP Professional
BOOT.INI deleted. How to re-create this file?
timeout=30
[operating systems]
Please rate this if you found this answer helpful. :)
Windows XP SP2 will not boot after installing new SATA hard drive
Your system thinks the "second" drive has precedence over the first ( your boot drive ) try switching the SATA cables between the two drives. There also might be a BIOS setting under Boot Order, sometimes you have to drill down to get to it for a particular drive.
Dec 25, 2008 | Microsoft Windows XP Professional for PC
Bios setting problem
This happens because Windows is corrupted.
You need to start the computer with a windows install disk, or a factory recovery disk inside to reinstall the system.
Get a windows install disk and reinstall the system.
Nov 17, 2008 | Computers & Internet
Realtek HD Driver Instllation failure
Please explain more the position:
1. Is the hard drive properly connected in the computer?
2. have you booted the computer to recognize HD in BIOS?
3. Have you inserted bootabe Windows CD to attempt loading the operating system?
4. Has the Operating system loaded and failed?
Note: hard Drives are made in Standard Industry specs. If its good and connected properly it should work. If it is a second or third hard drive you are connecting, it may be connected wrong in data cables.
Feb 17, 2008 | Computers & Internet
Computers & Internet Logo
204 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
