My certified data laptop quit all of a sudden and turning it off and on or even removing the battery does not help it just goes to safe mode or open windows normal and the screen stays blank
    Habit-Forming:
    Scholar:
  • 69 Answers
Symptoms seem to indicate either corrupted or missing driver files (probably other corrupted files on hard drive as well).
You can boot into Safe Mode, then run Command Prompt, and type the following to try to correct corruption on the hard drive:
chkdsk c: /r
You will get a message telling you the drive is in use, and would you like to run on next restart. Type "Y" and hit enter, then restart the computer. Depending on the size of your hard drive, this could take hours to run, but be patient.
If this does not resolve your problem, the next thing to try is (in Command Prompt again) "sfc /scannow". You will need your installation disks as this program does a full System File Check and will ask for your installer CD/DVD to replace any missing or corrupt System files it finds.
I hope this helps...
Posted on Dec 30, 2012
pankaj_dic
  • 1250 Answers
SOURCE: My Hp Pavilion dv4000 screen stays blank
have you got a bootable cd or recovery cd , boot from it and do a fresh installation, i think your windows has got corrupt
Posted on Nov 06, 2008
  • 3 Answers
SOURCE: freezing in 'safe mode'
Have you tried accessing the bios to set boot order? It may be trying to load from the hdd before the optical/usb drive.
During the flash screen, press F2 (though it can vary by maker) and change your boot order to load the USB drive first.
Hope this helps!
Posted on Apr 29, 2009
masteria
  • 355 Answers
SOURCE: Windows Error Recovery...can't start up!
hello friends...
It seems that your window is corrupted ..may be some system file is missing in your computer...the best way to insert Windows CD and try to repair your window..
Thnaks
Posted on May 09, 2009
haayz
  • 197 Answers
SOURCE: Will Not Boot/Keeps Rebooting
suspected hard disk faulty or OS corrupted.
to check, take out your hard disk and put it in other laptop. if the problem persist your OS is corrupted. In that case, you need to reformat your OS in a defaulty factory settings.
Posted on May 28, 2009
  • 3940 Answers
SOURCE: Hello! I've got a LG LW40 Express Laptop. Whenever
First, if you can run hard disk drive diagnostics, because many times a windows failure is based on the Hard Drive failing. If the Hard drive checks out, since you cannot access the Windows enviroment, you'll likely be re-installing Windows and loading drivers again. I hope your data is already backed up, otherwise it may be gone
Posted on Sep 05, 2009
Hp g8ooo turn on for two seconds then goes of
Check charger power supply, are you getting voltage? Otherwise, I'd try to boot into "safe" mode probably f8. Try a Disk check. If problem continues, even in the safe mode I'd go to install disk and try a repair (without loss of data) option. Hopefully you have backed up just in case. If you have backed up and still have problems you may want to do a "fresh" install, but that entails reinstallation of all software. Not fun. Good luck. I find tomshardware.com quite helpful.
May 07, 2015 | HP Computers & Internet
We found an inconsistency in your data and are fixing it. Please wait while we restart your computer
To enter safe mode, At boot start tapping F-8. Or, Unplug, while running, remove battery, plug in, reboot, a list should come up select safe mode with networking. OR, while running open MSCONFIG, by opening RUN and typing MSCONFIG and OK, select Boot Tab, Safe boot, restart. Try Running Command Prompt, as Administrator, type sfc /scannow.
Feb 02, 2013 | HP Mini 1000 Netbook
I can not boot up my acer 5735 even in safe mode
Sometimes if you insert a flash drive or your repair disc that you made when you got the computer helps.
Dec 10, 2012 | Acer Aspire 5735 Notebook
My pc won't start not even in safe mode
you might as well turn off your laptop and remove the batteries and cable into it. And then, press and hold the power button for 8 secs. This will reset your power and operating system settings on your laptop. Then , reinsert the cables and battery into it. Turn on the laptop, and if you still cannot start even in safe mode, consult your PC provider so that they will help you back up the files and repair your laptop....
Mar 06, 2011 | Computers & Internet
My Dell Inspiron 6000 (which I think I bought in
Have you tried this:
1. After removing the battery
2. Press and hold the power button for at least 10 sec.
3. Put back the battery
4. Turn it on
if this doesnt work, there could be a problem with your operating system. Try accessing safe mode if you can login .TAP F8 continously on the dell logo screen, and it will open advance boot options. (Just select safe mode) If safe mode boots properly try running system restore to restore it back to the previous date where your computer is still booting to windows. Hope this helps
Dec 08, 2009 | Dell Inspiron 6000 Notebook
Doesnt turn on, when it does it turns right off after just a few minutes
Remove the battery and try turning it on with jut the power adapter connected. Could be the adapter is bad and not charging the battery.
Aug 07, 2009 | HP Compaq Presario 700Z Notebook
How to remove BIOS memory cache
Since it is a Toshiba Tecra if you are not worried about losing data on the laptop you can try turning on the laptop and start pressing the zero key. It should give you the option to restore your laptop if you haven't deleted the restore partition on the laptop.
Mar 20, 2009 | Toshiba TECRA A6-EZ6312 (PTA60U05T00F) PC...
My laptop has a blue then black screen after start-up
Press F8 when you laptop starts. Go to safe mode. Scan and remove virus in safemode. Try and restart your laptop when completed.
Jan 09, 2009 | HP Pavilion dv9000z Notebook
Start up problem
try to disable start up items that are not required...for that u have to boot in safe mode and type msconfig in Run
Dec 10, 2008 | Compaq Presario Notebook
I have IBM LAPTOP thinkpad T43 SERIES. it was working tiil yesteraday. Suddenly it turns switch off. I thought its the problem with AC adapter. I bought a new one. It shows it turn it on but its switch...
It's not necessarily hardware related, can you boot into Bios? If you can try to boot info safe mode, that's F8 for most PCs. I would suspect something with your motherboard drivers, then again it could just be your battery. Not all laptops will operate with the battery out, there is some kind of failsafe to prevent overheating in some, because without a battery the power supply can be fried sometimes.
Hope this helps
Dec 04, 2008 | IBM ThinkPad T40 2373 Notebook
Computers & Internet Logo
David Payne
David Payne
