Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Red and blue faded
Where to buy crt fluids and how hard is it to change
  • BigPossum Jan 31, 2009
    I was just given a 55" magnavox projection tv. The picture is great, but it seems to have a band of soft green and reddish orange areas through the center from top to bottom. The discolored areas are about 5 to 6 inches wide. During dark images they are hardly noticable but they really show when the screen is bright or light colored. It may be important to note that we transported this tv on a flatbed trailer over a very rough road. The tv was transported up right, but I'm wondering if we may have jostled something loose inside our is this another issue. Any advice would be greatly appreciated.
  • Philips Master
  • 3,459 Answers
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Jan 26, 2009
My mitsubishi vs 6047 has been in unheated storage for about 4 years. now picture is very blury. when words are on screen large letters are legible with small white horizontal lines dancing side to side....
Does the picture look like this?
If so I believe your CRT liquid coolant has gone bad and needs replaced.
How to diagnose bad CRT Coolant:
Note: This problem will only affect the GREEN and BLUE picture tubes. The RED CRT is never affected, because the wavelength of the red light does not promote this algae growth
General Symptoms: Washed out, blurry picture, red portions mostly OK, GREEN images have halos, BLUE portions of images may have halos or be missing entirely.Turn the color level control all of the way down and remove the screen and/or the cabinet that contains the mirror. (different for different models) Do not turn the set off or the color level control will reset to preset levels. Look directly into the picture tube lens while the set is on. First look at the RED CRT. Observe the scan lines in the picture. These same lines should also be present in the green and blue picture tubes.
After looking at the RED CRT for comparison, look into the GREEN or BLUE CRTs. If it is contaminated, it will look like there is a layer of film that you have to look thru to see the picture. There may also be swirls and other various contaminates forming. If it is not as clear and sharp as the RED CRT, it is contaminated, and you should change the coolant fluid. IF you wish to tackle this I will supply more information and instructions. This task is medium to hard for non trained people.
Let me know if you wish to get the instructions on changing the fluid.
Jun 09, 2011 | Mitsubishi VS-6047 60" Rear Projection...
Hitachi ultravision 50ux26b. Two problems. 1. In the top left corner it looks like a dogear with the picture behind it faded and the edges looking blue.This started shortly after a couple of moves...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Apr 21, 2011 | Hitachi 50UX26B/27K 50" Rear Projection...
AFTER CLEANING BOTH THE MIRROR AND THE THREE LIGHTS MY PICTURE IS MUCH BETTER. HOWEVER STILL NOT AS CLEAR AS WHEN NEW. WHILE I HAVE THE BACK COVER OFF & THE TV ON , THE BLUE AND RED LIGHTS ARE CLEAR...
Picture are blurry and have a hollow effect?But Convergence pictures R,G,B colors lines are all alignments up?Need CRT coolant replacement for the green CRT TUBE gun.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a CRT coolant kit for the replacement.
Dec 08, 2010 | Hitachi 53FDX20B 53" Rear Projection...
CRT problem
you need to adjust the red screen control of the crt under the speaker grill turn it down with the tv running.
Mar 02, 2009 | Sony KP-51HW40 51" Rear Projection...
Color fade on phillips 9p6034
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
Feb 12, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philips 55P8341 red pic
yes change the coolant, if that doesnt correct the problem you will need a blue CRT
Jun 04, 2008 | Philips 55P8341 55" Rear Projection...
No Blue ink and fading red
same thing happen to mine. we tried every possible solution and nothing worked, you will have to buy a new printer atleast thats what we did to save yourself the stress and headache
May 24, 2008 | Lexmark X1150 All-In-One InkJet Printer
Faded and out of focus picture
Your TV has a burnt CRT base socket. Replace that, it is not a tough job, but make sure that you get the exact same type of base socket.
Jan 14, 2008 | Panasonic CT-34WX15 34" TV
Poor color
You may need fluid change. CRT gets dirty fluid, must be changed after long time of use.
Nov 26, 2007 | Philips 55P8341 55" Rear Projection...
My tv seems to have more red and blue colors in it
It sounds as if one of the picture elements (there are probably 3 for R-red G-green B-blue) has gone bad and it is most likely the green one. Sad to say it will probably cost you more to have it fixed than it would to buy a new TV. Most places will not even look at a TV for less than $85 or so, then they will add parts and labor... if they can even find parts.
Jun 18, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
114 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
