Question about Bush Televison & Video
Factory reset Bush s642f
Hi, I have a Bush s642f tv. I have installed a module, i searched the digital channels, and all the existing ones were removed. Now when I search again for these channels I don't find any ( module removed). How can I do the factory reset/ initial installation? I have searched the users manual but no procedure found. Thanks, Ibra
    Top Expert:
  • Bush Master
  • 74,383 Answers
You have to enter its service mode option to do this. It is a skilled work. Just check this, and see whether you can do this or not.
Posted on Dec 30, 2012
  • 135 Answers
SOURCE: RCA TV model 32V420T - Auto channel seek
Hi there!
Check that the remote buttons or the buttons on the Tv has not become sticky or soiled on the inside. Good Luck, JUS004
Posted on Mar 16, 2008
yambo
  • 230 Answers
SOURCE: channel issue
Do you have a lot loose connection inside tunner. Need be re solder. Do this and TV will be ready!!.
Posted on Aug 19, 2008
SOURCE: user manual for bush tv
http://forum.eserviceinfo.com/archives/99999975.html
This Site Should Help You Mate
Posted on Aug 23, 2008
  • 4234 Answers
SOURCE: I can't scan for digital channels
This is a standard NTSC set that can only receive cable channels up to 113. Since you don't specify what digital channels you are trying to receive, I'm not sure I have completely answered your question. If not, please provide more info about what channels you are trying to get and I'll try to respond.
Thanks,
Dan
Posted on Feb 21, 2009
vortash
  • 431 Answers
SOURCE: Cannot tune analog channels on Bush 32'' LCD TV
Hi I am Vortash not a set I have worked on but suggest that the solution will be in the user manual , if you have no user manual try this site http://www.safemanuals.com some of the downloads by adobe pdf file are free others reasonably priced I hope this is of help Regards Vortash
Posted on May 15, 2009
Volume up and channel up buttons do not work for 19 Bush tv/DVD combo. How do I reset the remote control
Hi, If you have a computer. look up (google search) Bush tv/dvd combo. There maybe some things you can do yourself. The # 1 thing you can check is the batteries. replace with new and make sure they are in correctly. + to + - to - Do not mix batteries (new with old). Good luck.
Jun 01, 2015 | Televison & Video
Hi I am having problem with my tv bush model s642f while I am switching the tv on the red light keep flashing an it won't come on please help me thanks
It's possible it may be an error code. Depending on the number of blinks it will tell you what to look for when diagnosing the TV.
Feb 13, 2015 | Bush 42" LCD TV 1920x1080, 50 Hz, Freeview...
Want help in resetting or rebooting a BUSH IDPVR 802 freeview digital box with or without using remote please note not a tv but digital box
There are two types of reset digital electronic devices. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Nov 03, 2014 | Televison & Video
Toshiba 32BL505B- 32 inch TV - Lack of settings - No Installation, or TV Settings.. Please Help
1. Press the menu button on the remote
2. Once the menu comes up press the numbers 7935 in succesion
3. This should bring up the hotel menu, turn off the hotel mode at the top of this screen
4. Then press the menu button to exit out of the menu and next time you press the menu button there should 6 icons available
Jan 10, 2013 | Televison & Video
I need a sky remote code for a bush s642f
Hello
Sky remote codes for Bush TV are:
246 263 377 037 064 065 310 300 383 399 391 402 547 292 239 312 609 322 339 515 236 389 035 191 232 245 288 714
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button
OK
Jun 28, 2011 | Televison & Video
How do I retune DMTech TV Freeview with DVD video please?
Please fallow bellows instruction to retune your TV.
Could you please follow that EEPROM RESET INSTRUCTION OR FIRST TME INSTALLATION.
Also please don’t forget that MENU BUTTON from your remote, it’s not the one in the middle of remote.
There are the other MENU BUTTON in left down bottom side.
Cannot access Digital TV and am asked for a Lock code Key?
If you cannot access the Digital TV option then conduct an EEPROM RESET as mentioned above. If you are prompted to enter a lock code key enter three / four zeros.
Alternatively when prompted to enter the lock code key conduct a FIRST TIME INSTALLATION also mentioned above.
There are two options available. The first option is to conduct a general reset that will reset all user preferences. The second option would be to conduct an EEPROM RESET. An EEPROM RESET would reset all the internal hardware.
Instructions - Please refer to your DMTECH remote control and user manual provided
1. Turn the Television ON ? Button on front of Television / Power button on remote control.
2. Make sure that you are on Analogue television by pressing the TV/DVB-T button until you see PR and the channel number selected in the top right corner of the screen, e.g. PR 1.
3. You must then Press the button labelled Display until a window titled INFORMATION is displayed on the screen.
4. Only when the window titled Information is present can you continue by pressing the digit (1) twice and then pressing the button titled LINE. If you make a mistake then press Display again to remove the window titled INFORMATION and repeat the process. (Display - 1 1 - Line)
5. Once you have successfully completed step four you will notice that a menu appears on the left of the screen. You can then select which option you want, either RESET or an EEPROM RESET using the arrow keys. To execute an instruction please use the RIGHT ARROW KEY and not the ENTER button.
Make sure you have properly conducted a FIRST TIME INSTALLATION and an AUTOMATIC SEARCH. If having done this you can try conducting a manual search in an attempt to force / lock the channel.
This will erase the DVBT tuner memory and reset the interface card. This may resolve poor channel reception, the inability to store channels or even receive certain channels.
1. Turn the Television ON and select digital television by pressing the button labelled TV / DVB-T located under the power button on the remote control.
2. On the remote control locate and press the button labelled Menu, found at the extreme bottom left of the remote control.
3. A Menu should now appear displaying options. Scroll down and select the option labelled SETTINGS using the ARROW KEYS and the enter key located in the middle of the remote control. On the next menu you must select INSTALLATION to move on to the next menu.
4. On this last menu scroll down to the last option labelled FIRST TIME INSTALLATION and select it pressing the enter key. You will then be prompted to delete all channels, using the left arrow key to select yes and press enter to execute. The television will reset and prompt you to commence an AUTO SEARCH. Follow these instructions to tune in channels.picture
Digital Television requires much more from existing aerial systems. Having more than one digital TV may reduce signal quality and strength depending on how the aerial system is set up. It is therefore recommended that if you decide to use more than one digital television you use a booster and or at least make sure you are using a digital ready aerial. Using an existing Aerial that is split may reduce signal strength depending on how many times it is split. Please see the diagram below. The best solution when using an existing aerial is to purchase a booster device. Aerial Splitting - Why a booster is recommended. A booster is used to apply a small current that boosts the existing signal. A booster can be purchased from all main TV/HI-FI - consumer electronic product retailers.
Jan 16, 2010 | Televison & Video
I need an instruction maunal for a Bush DVD142TV
download available at safemanuals.com (diplodocs)
Mar 13, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Bush 2874ntxs aerial problem
i messed around with the remote, searched for my 5 channels and found them on uhf, stored and now i can look at my tv, thanks, gra.
Jul 04, 2008 | Bush 5693D 24" TV
Televison & Video Logo
282 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
