Get capital letter without turning on caps lock
  • 32,281 Answers
Press and hold down the Shift key then press the letter you require.
Posted on Dec 30, 2012
milind_mhc
  • 10 Answers
SOURCE: compaq presario c700 keyboard mulfunction
First U Uninstall your Keyboar driver if U install on your computer.
Restart it.
Posted on Jan 21, 2009
AndreaBl
  • 218 Answers
SOURCE: Caps Lock stays in this mode and types capital
hi there,
have you tried cleaning your keypad with a brush?
also check your onscreen keyboard, if it has the same effect.
lastly, go to your control panel, then to your keyboard options and check if everything is in order. there could be that you have added another option to your keyboard's list of languages.
Posted on Jun 26, 2010
ftw1952
  • 10319 Answers
SOURCE: my cap lock won't lock, however I can get a
Gently removed the CAP LOCK KEY and inspect for dirt or a broken retaining clip. If dirty blow it out. If the clip is broken the key will not work I'm afraid to tell you
Posted on Jul 17, 2010
  • 88 Answers
SOURCE: caps lock is off but
Unplug the laptop and remove the battery, leave for 30 mins and try again.
hope it helps
Posted on Aug 31, 2010
  • 6771 Answers
SOURCE: shift + l won't make capital L
You will need to change the laptop keyboard, go to www.ebay.com Type: make and model of laptop, and refine search to keyboard.
Posted on May 03, 2012
Caps are on all the time
Press the
"caps lock" key once to take it off capital letters. If that doesn't work, get an external keyboard and plug it in and try it. That should do it.
Apr 08, 2014 | Compaq Presario CQ56-115DX Laptop
I CANT FIGURE OUT HOW TO TURN CAPS LOCK OFF
please click on caps lock button if led lights means it will type capital press again caps lock if led turned off means small letters simple.
Feb 16, 2014 | Dell Computers & Internet
How do I get the caps lock light to turn on and off?
Unlock the Caps on Computers The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files. This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words. When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function. Open a word processing program. Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document. If lower case letters appear in the document, Caps are successfully unlocked. Proceed if the text is in All-Caps. Hold down "Shift" on the keyboard. Press the letter "P." A lower case "p" appears in the document. Release the "Shift" button. Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T." Press "Enter" on the keyboard. The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off. Restart the computer to save the setting.
Enable the Caps Lock Key The "Caps Lock" key is loved by some and disliked by others. The key turns all letters into capitals as you type. While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized. The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock." If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key. If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels. Updating the registry for the keyboard will enable the "Caps Lock" key. Open the Notepad program. Type the following: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout] "Scancode Map"=- Select "Save As" from the "File" drop down menu. Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window. Type "enable.reg" without quotes in the "File name:" field and click "Save." Minimize all open windows to view the desktop. Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled. b> Manually Update the Registry b> Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor. Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings. Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
b> b> b> Disable the Caps Lock Key in Windows Your computer's Caps Lock key has likely only collected dust since you first brought the machine home. The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often. Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
Restart your computer before beginning the process of disabling your Caps Lock key. Download the registry file necessary to disable your Caps Lock key. You have the option to disable your Caps Lock key or change the key to a number of different keystrokes. For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key. Double-click the registry file you have downloaded. A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry. Select "Yes" to install the registry file. Restart your computer, once again, to complete the registry change. Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key.
Feb 04, 2013 | ASUS R503u-rh21
CAP LIGHT DOES NOT COME ON
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key. Hope this helps
Jan 21, 2013 | Acer Computers & Internet
My email address is not allowing me to login christianmingle,com website, but I just rest my password
The most common mistake people make with passwords is having the Caps-Lock key on while typing some or all of the password.
Caps-Lock should ALWAYS be off and you should not use it even to create capital letters (Use the Shift key instead).
You may have to request another reset, then make sure you are entering your new password without Caps-Lock on.
Also, if you are using numbers in your password and entering the numbers from your numeric keypad, make sure your Num-Lock key is turned ON.
Jan 20, 2013 | christianmingle.com Computers & Internet
How to tell if caps lock is on
Some keyboards will have a light that goes on when caps lock is turned on
Type the following:
"Scancode Map"=-
Hope this helps
Nov 05, 2012 | Computers & Internet
HOW DO I CONNECT MY APPLE IPHONE TO PLUSNET WIRELESS
To type capital letters, press the shift key which is the up arrow in the bottom left corner of the screen, and then press the key for your desired letter. If you would like caps lock, double-tap the shift key. Note that the caps lock will be deactivated if you change to the number keyboard or symbol keyboard.
Jun 23, 2012 | Apple iPhone (16 GB) Smartphone
KEYBOARD ONLY PRINTS CAPITAL LETTERS . HOW DO I RETURN TO LOWER CASE LETTERS ?
Try pressing the Caps Lock key, (the Caps Lock LED will then turn off) this will return the letters to lower case.
Jul 27, 2011 | Computers & Internet
Capital letters
You can either turn on CAPS Lock or hold the shift key while typing. Have you already tried this?
Jan 30, 2008 | NorStar Refurbished OTM 1.x Billing...
Computers & Internet Logo
David Payne
David Payne
